Fowled instruction at "https://wiki.zoneminder.com/Raspbian" too install ZoneMinder 1.29 on Raspberry Pi 3.
with following configuration:
Source Type Remote
Remote Protocol RTSP
Remote Method RTP/RTSP
Remote Host Name userid:password@192.168.1.247
Remote Host Port 554
Remote Host Path /Streaming/Channels/1
Get the following errors from "less /var/log/syslog | grep zm". Same configuration works in other apps. Any help is appreciated
Apr 23 15:41:30 raspberrypi zmc[2907]: INF [Starting Capture version 1.29.0]
Apr 23 15:41:32 raspberrypi zmc[2907]: ERR [Invalid SDP address type 'IP6' in connection info 'IN IP6 ::']
Apr 23 15:41:40 raspberrypi zmc[2907]: FAT [No RTSP sources]
Apr 23 15:41:40 raspberrypi zmdc[2259]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Apr 23 15:44:20 raspberrypi zmdc[2259]: INF [Starting pending process, zmc -m 1]
Apr 23 15:44:20 raspberrypi zmdc[2927]: INF ['zmc -m 1' started at 16/04/23 15:44:20]
Apr 23 15:44:20 raspberrypi zmdc[2259]: INF ['zmc -m 1' starting at 16/04/23 15:44:20, pid = 2927]
Apr 23 15:44:20 raspberrypi zmc[2927]: INF [Starting Capture version 1.29.0]
Apr 23 15:44:22 raspberrypi zmc[2927]: ERR [Invalid SDP address type 'IP6' in connection info 'IN IP6 ::']
Apr 23 15:44:30 raspberrypi zmc[2927]: FAT [No RTSP sources]
Apr 23 15:44:30 raspberrypi zmdc[2259]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Raspberry Pi 3 - Errors with Hikvision SWNHD-825CAM
