No video in events
DrHappyAngry
No video in events
Post by DrHappyAngry »
I had an older version, 1.26 I think running on the same box with Ubuntu 14.04, but the mushkin ssd died after a year (Gonna stick with intel from now on).
Now I'm running Ubuntu 16.04 server and used the source based install directions https://zoneminder.readthedocs.org/en/s ... rom-source
Got everything working after adding sql_mode = NO_ENGINE_SUBSTITUTION to the mysql config. The only problem is when I open an event, I see one frame of the video, and then just get a countdown to the next event, no playback of the video. I can see video from the live feed, just not in the events.
Re: No video in events
Why do things the hard way and have problems?
DrHappyAngry
At this point I'm invested in the config, since apache will have to be reconfigured to use the packages. I also would like to keep control of the upgrade process, so an apt-get dist-upgrade doesn't require running a bunch of sql and fixing other busted stuff when ZM gets upgraded along with the rest of the system packages. I generally shun packaged versions of web apps like this and owncloud, since you can't always count on packaged versions to get updates in a timely manner.
Asides from using packages I don't see anything different about that guide, so this should work fine. I have no errors logged.
