Can someone post a good ZM-script example?
flyvert
Post by flyvert »
The script on the wiki FAQ (http://zoneminder.readthedocs.org/en/la ... s-an-alarm) leaves room for a number of improvements.
- Polling every monitor every second is not very elegant.
- Same alarm will give continuous triggering until idle.
- Current example seem platform specific (it won't run on Debian Jessie until some changes are made. Once worked around, there are further warnings about uninitialized variables in some internal function: "Use of uninitialized value $last_event_id in numeric ne (!=) at /usr/share/perl5/ZoneMinder/Memory.pm line 610.")
I would like to see a script example where:
- Some resource lean callback, WaitForAlarm(), etc function is made available.
- One callback, triggering, etc instead of continuous (I believe many would prefer a single callback per alarm to fire a custom script, etc.)
Have someone made this on his/her own and is willing to share some code, etc?
Re: Can someone post a good ZM-script example?
Here is a script that monitors events via zmTrigger.pl This is modified to run some tests but it works and perhaps will inspire a direction to go to find what you seek.
#!/bin/bash
# Turn lights on when ZM starts recording an event and turn off when ZM stops.
# Or do whatever such as trigger sirens, blink lights, text-to-speech, etc.
# Monitor output from zmtrigger.pl. When ZM starts recording an event
# zmtrigger.pl outputs a line like this where the first parameter is the
# camera number.
# 2|on|1300323788|298
# When ZM stops recording an event zmtrigger.pl outputs a line like this.
# 2|off|1300323801|298
# The following table shows the 5 sample ZM cameras and corresponding
# X10 commands to control lights. mochad is used in this example to turn
# lights on/off but heyu or br or any other command line program.
# Location Cam  Command
# Garage    1   pl b2
# Kitchen   2   pl b1
# Test      3
# Living    4   pl b1
# Front Dr  5   pl b1
LIGHT[1]="pl A1"
LIGHT[2]="pl b1"
LIGHT[3]="pl b1"
LIGHT[4]="pl b1"
LIGHT[5]="pl b1"
LIGHT[6]="pl A6 "
# mochad listens on this host and port
#MOCHADHOST=192.168.1.254
#MOCHADPORT=1099
# zmtrigger.pl listens on this host and port
ZMHOST=192.168.0.9
#ZMHOST=localhost
ZMPORT=6802
CURL='/usr/bin/curl'
#RVMHTTP="http://localhost:8008/?house=A&unit=1&command=ON"
#OFFHTTP="http://localhost:8008/?house=A&unit=1&command=OFF"
RVMHTTP="http://192.168.0.9:8008/?house=A&unit=1&command=ON"
OFFHTTP="http://192.168.0.9:8008/?house=A&unit=1&command=OFF"
CURLARGS="-f -s -S -k"
# Connect TCP socket to ZoneMinder zmtrigger.pl
exec 6<>/dev/tcp/${ZMHOST}/${ZMPORT}
# Read ZM events from zmtrigger.pl
while read <&6
do
    # Show the line on standard output just for debugging.
    echo "${REPLY}" >&1
    case "${REPLY}" in
        *\|on\|*)
            CAM=${REPLY%%|*}        # extract camera number
            cmd=${LIGHT[${CAM}]}    # get the X10 command
            if [ "x${cmd}" != "x" ]
            then
#               echo "${cmd} on" >/dev/tcp/${MOCHADHOST}/${MOCHADPORT}
                echo "${cmd} on"
                raw="$($CURL $CURLARGS $RVMHTTP)"
                echo $raw
            fi
        *\|off\|*)
            then
#                echo "${cmd} off" >/dev/tcp/${MOCHADHOST}/${MOCHADPORT}
                 echo "${cmd} off"
                 echo $raw
            fi
    esac
done
asker
Post by asker »
If you are looking at doing something with events, also take a look at the event server - it taps into shared memory to report events, so it notifies as soon as the event occurs (nearly) https://github.com/pliablepixels/zmeventserver
Please read before posting:
ES docs
zmNinja docs
flyvert
Post by flyvert »
rockedge wrote:Here is a script that monitors events via zmTrigger.pl This is modified to run some tests but it works and perhaps will inspire a direction to go to find what you seek.
Thanks. Exactly what I was asking for! :D
flyvert
Post by flyvert »
asker wrote:If you are looking at doing something with events, also take a look at the event server - it taps into shared memory to report events, so it notifies as soon as the event occurs (nearly) https://github.com/pliablepixels/zmeventserver
Thanks for the hint - will have a go at this at earliest opportunity.
