Problem adding new Monitor
duffbeerisgood
Post by duffbeerisgood »
New install of zoneminder and everything seems to be working correctly however when I try to add a new Monitor I get errors in the logs:
2016-04-26 20:06:10.512652 web_js 892 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-289595s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-04-26 20:06:10.426947 web_php 893 ERR socket_sendto( /var/run/zm/zms-289595s.sock ) failed: No such file or directory /config/data/zoneminder/includes/functions.php 2330
2016-04-26 20:05:21.351215 zmc_m1 957 INF mini: 1000 - Capturing at 12.66 fps zm_monitor.cpp 2907
2016-04-26 20:04:02.776312 zmc_m1 957 INF Priming capture from rtsp://user:pass@192.168.11.203:88/videoMain zm_ffmpeg_camera.cpp 98
2016-04-26 20:04:02.701816 zmc_m1 957 INF Starting Capture zmc.cpp 195
2016-04-26 20:04:01.927770 zmdc 957 INF 'zmc -m 1' started at 16/04/26 20:04:01 zmdc.pl
2016-04-26 20:04:01.927760 zmdc 804 INF 'zmc -m 1' starting at 16/04/26 20:04:01, pid = 957 zmdc.pl
2016-04-26 20:04:01.909820 zmdc 804 INF Starting pending process, zmc -m 1 zmdc.pl
2016-04-26 20:04:01.890070 zmdc 804 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-04-26 20:04:01.719070 zmwatch 839 ERR Memory map file '/dev/shm/zm.mmap.1' does not exist. zmc might not be running. zmwatch.pl
2016-04-26 20:04:01.307390 zmdc 804 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-04-26 20:04:01.180240 zmdc 934 INF 'zmc -m 1' started at 16/04/26 20:04:01 zmdc.pl
2016-04-26 20:04:01.180230 zmdc 804 INF 'zmc -m 1' starting at 16/04/26 20:04:01, pid = 934 zmdc.pl
2016-04-26 20:04:01.047050 zmdc 804 WAR Can't find process with command of 'zmc -m 1' zmdc.pl
2016-04-26 20:04:00.940320 zmdc 804 WAR Can't find process with command of 'zma -m 1' zmdc.pl
Any Ideas? I can provide additinl info if helpful.....
Re: Problem adding new Monitor
You likely do not have the resolution right in Zoneminder.
Camera info (my guess is Foscam?) and the settings you are using in ZM would be helpful...
duffbeerisgood
Thanks for the response? Are these errors common if the resolution is off?I have tried two different cameras both foscam, with similar results.
The fist is a FI9803EP and I used the settings:
FFmpeg
rtsp://user:pass@192.168.11.204:88/videoMain
RTP/RTSP
32 bit colour
Capture width: 800
Capture height: 450
The second is the wireless 1080IP cam or C2 model and I used:
FFmpeg
RTP/RTSP
32 bit colour
1280
720
I got the recommend settings form the WIKI. I also verified the source path is correct, as I can connect with it form VLC and view the stream.
duffbeerisgood
I don't think its a problem with the resolution I think something is going wrong with connection to the sockets.....
2016-04-27 09:08:33.985519 web_js 4780 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-351716s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-04-27 09:08:33.900311 web_php 4780 ERR socket_sendto( /var/run/zm/zms-351716s.sock ) failed: No such file or directory /config/data/zoneminder/includes/functions.php 2330
2016-04-27 09:08:13.898505 web_js 4780 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-351716s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-04-27 09:08:13.811497 web_php 4781 ERR socket_sendto( /var/run/zm/zms-351716s.sock ) failed: No such file or directory /config/data/zoneminder/includes/functions.php 2330
I am running in a container pulled form https://hub.docker.com/r/aptalca/zoneminder-1.29/ however have not seen any reports of similar issues??
duffbeerisgood
Re: RESOLVED! Problem adding new Monitor
USERERROR!!! I was running the old version of the container ie 1.28 and using the instructions for the new version 1.29 so I think my paths were all jacked up. Thanks for the help sorry for the noob mistake! zoneminder is pretty cool!!
