mobile phone access is always redirected to login screen
Re: Nokia 6610 cannot see images
RedB wrote:Hi All - Love ZoneMinder!
On my Nokia 6610, I can get to the status page ( Status, Load, Monitor listing, Function & Events)
If I select a Monitor 'row' I get a screen with the Monitor Name, Function and Events numbers.
Selecting anything on this screen returns "File Format Not Known" and returns me to the first status page.
Anyone have any idea why I can't view an image?
Alough I think the 'cookie' settings listed on this forum were RE login, I have set them all as 'True' anyway - made no difference.
I have the same problem with or without wurfl and a SonyEricsson K700i or K500i (with good parameter in zm.php) :
I can get to the status page ( Status, Load, Monitor listing, Function & Events) but selecting anything on this screen returns "File Format Not Known" and returns me to the first status page.
Hi Guys,
The usual problem in this case (where the first page works and nothing else or nothing works) is that the carrier has a proxy server filtering the incoming data / requests. We have even found a couple here in Australia that block everything except if you have a specific business account for the mobile and that gives proper internet access.
If you where to contact the carrier with the problem and the plan that you are on says that you have internet access then complain to them that it is false marketing and that their firewalls and proxies are stopping you from doing your business etc.
They may even open the firewall to your IP if you ask the right people. We did that and got it all working for another product.
But you are right in that they want there share in the end and they control the access in any case.
Regards,
Deano
Regards,
Deano
- zoneminder
- Site Admin
- Contact:
You could try setting
in your php.ini file if it isn't already. Although the script sets it sometimes it doesn't want to stick unless changed in the main ini file.
Phil
session.use_trans_sid = 1
Phil
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
Setting your proxy may not have any affect....
The setting of Proxy use on your own handset may not have any effect at all as it is the FW and Proxy setup of the carrier that over rides the end user connection.
Think transpartent proxy servers.
Here in Australia most people are not able to reach the net directly unless they have a specific business type account for their mobile.
You would have to talk to your carrier and find out what packages provide real internet access without the limits that are usually set in place.
Regards,
Deano
Regards,
Deano
Did somebody resolves it ?
Hi all,
I have the same problem with a SonyEricsson T630.
Has anybody solves that ?
Thanks.
Sebastien.
Thanks.
Sebastien.
- zoneminder
- Site Admin
- Contact:
xHTML with a Sony Ericsson T630
Hi Phil,
I've configured it myself in zm.php.
I've modified the following:
// This is an example of using fixed device strings to just match your phone etc
$devices = array(
array( 'name'=>"Motorola V600", 'ua_match'=>"MOT-V600", 'format'=>"xhtml", 'cookies'=>false, 'width'=>176, 'height'=>220 ),
array( 'name'=>"Motorola V600", 'ua_match'=>"MOT-A820", 'format'=>"xhtml", 'cookies'=>false, 'width'=>176, 'height'=>220 ),
array( 'name'=>"T630", 'ua_match'=>"SonyEricssonT630", 'format'=>"xhtml", 'cookies'=>true, 'width'=>128, 'height'=>160 )
Cheers,
Sebastien.
$devices = array(
Cheers,
Sebastien.
- zoneminder
- Site Admin
- Contact:
T630
Hi Phil,
The HTTP_USER_AGENT matches coz I've tried with the phone before proceeding with the modifications and the HTML pages sent to the phone at this time were different.
I've first started with the cookies set to false: in this case, when I click on any link within the main page, I returned back to the login screen (I think this behaviour what also previously described in this thread).
What else?
TIA,
Sebastien.
What else?
TIA,
Sebastien.
