Filters Date/time
otv5125
Filters Date/time
Post by otv5125 »
Hello!
I have a problem with zoneminder server filters.
Exactly, "Date/Time" filter has preset to "less than or equal to" with value of "-20 days". "Delete all matches" checked on. After "submit" command activation, all records (events) to be deleted are listed correctly, but "Execute" command activation results in nothing. All records (events) are untouched.
Log messages, applied to "filters" contain the following error messages "Error parsing date/time '-20 days', skipping filter '20 days qq'". The screenshots attached to this mail message.
Thanks in advance.
unnamed (1).png (11.78 KiB) Viewed 54804 times
Re: Filters Date/time
Hope you can see the image of my purge filter
otv5125
Post by otv5125 »
Error
Gary S
Post by Gary S »
The only significant difference I see between mine and yours is that yours is set to "Date" and mine is set to "Date/Time". Mine works.
ac7ss
Post by ac7ss »
Same trouble here. Perhaps a script or tool needs to be installed?
ac7ss
Post by ac7ss »
I found a solution, instead of using "-20 days" (Which does work in a view), use "20 days ago" as this seems to parse just fine.
otv5125
Post by otv5125 »
ac7ss wrote:I found a solution, instead of using "-20 days" (Which does work in a view), use "20 days ago" as this seems to parse just fine.
Thank you, this filter work!
steelskin
Post by steelskin »
I had the same problem, "-20 days" works when you use the submit button in filter but it isn't parsed by the background daemon. ie I get the filter -20 days unable to parse error.
As was mentioned above using 20 days ago worked for me too in both the submit & daemon. :D
I'm using zoneminder 1.30.0.
