No events displayed
m3lab
No events displayed
Post by m3lab »
Hi folks,
ZM is a GREAT "piece" of software and I'm using it since 2011 on various hardare and software ...
Now at home I've installed it on a Raspberry PI 2 with Jessie and nginx ...
It runs VERY WELL till last week where there was a php5 update. Now, system records all events but I cannot see them and ZM logs something like:
web_js		1187	ERR	getCmdResponse stream error: socket_sendto( /var/run/zm/zms-086015s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=event
web_php		1186	ERR	socket_sendto( /var/run/zm/zms-086015s.sock ) failed: No such file or directory	includes/functions.php	2371
/var/run/zm directory contains only zm.pid and zmdc.sock
Some suggestion(s)?
Thanks in advance,
m
m3lab
Re: No events displayed (more info ...)
Post by m3lab »
I can see event(s) from Console (i.e. hour or day ...)
When I click on the "camera-name" entry in Console it shows the live but clicking on event entry produces the above error ...
Any hints?
thanks in advance,
m.
SteveGilvarry
Post by SteveGilvarry »
Normally both live and event view are affected by socket_sendto. Normal checks are apache cgi-bin alias and zms_path, but in your case maybe you have moved the location of events and apache cannot access it. Something would should in apache logs for that I suspect.
Yes I encountered this with a permissions/owner problem with the event and image directories.
m3lab
Re: No events displayed - update
Post by m3lab »
Starting from yesterday no events could be seen ...
I've double checked zms_paths and permissions but they are ok ...
Maybe, and I say maybe, it could be related to nginx but it seems that all other stuff wroks fine!
Any other hint(s)?
thanks in advance,
m.
tob
Post by tob »
Did you figure this out?
I have the same problem and I already have checked the paths and permissions.. my zoneminder setup is running on nginx too and erverything else seems to work just fine.
tob
Post by tob »
To answer my self:
with nginx one has to follow this guide https://chiralsoftware.com/content/zone ... s-it-works espaciallz the part on fcgiwrap.
