camera not displayed
mattionline
Post by mattionline »
i watched the camera yesterday and there was a white screen, so the camera was not displayed. There were also no recordings made in the past.
When i clicked on the camera at "Source" and pressed the save button, the camera was reconnected into zoneminder and the live picture was displayed.
Today i got the same problem as yesterday. Do you have any ideas what this could be?
I have installed zoneminder 1.29.0-wily from iconnors ubuntu ppa
Here are the logs:
In the first image you see the last log entries from the camera after the disconnect (white picture)
The second was while the camera was "white"
At the third picture it was the time when i reconnected the camera with the "Source" save button
The camera models are different, so this shouldnt be the problem. And while the downtime in zoneminder i was able to watch them directly through the integrated webserver in the camera. This issue also happened at another location with other camera models (ubuntu ppa version is the same).
My Personal Blog: https://mattionline.de
mattionline
Re: camera not displayed
update: at a second server with a different location this also happened the last few days. so this should be a software problem.
I would be happy if you give me some advice to find a solution for this issue
You likely do not have your camera configured properly. From your log it appears that the connection to the camera is never made. Would be great for you to provide some more info about your setup? Which setup did you use from the WIKI?
mattionline
But after i reconnect the camera via "Source" it works for a few hours - one day.
I have installed zoneminder this way:
http://zoneminder.readthedocs.io/en/sta ... buntu-15-x
The mentioned camera is this one: Foscam FI9805E
Configured that way:
If you need any other information like the zone configuration please let me know
juggalo818
Post by juggalo818 »
help i have a problem i am trying to add cameras (SP 005) to zoneminder but it just wont take them i can see the stream @ http://192.168.0.107:81/videostream.cgi but it wont add how can i add them??
nextworks
Post by nextworks »
I am having the same issues I think with ZM 1.29.0 in debian installed with
https://wiki.zoneminder.com/Debian_8.1_ ... e_Easy_Way
I have set up a number of ZM deploys over the years, but now with newer cameras, i get the white screen after a while.
I have 2 similar systems using this camera: FI9805EP
All works great, then after 10 min - or 10 hours, one or several of the cameras goes to just a while screen (no image). No broken image icon, just white. I connect to the camera directly (not through ZM) and it's fine, so the camera is working.
I am just taking stills, using Remote/Modect and /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=XXX&pwd=YYY for example.
I restart ZM and all is well... for a little while. Then cameras start dropping again.
I'll follow up with logs once I see a camera go white again.
This happens w/ 2 clients, on different networks. Both networks are all gigabit, plenty of available bandwidth, fast/new ZM servers with plenty of memory, disk, cpu available.
nextworks
Post by nextworks »
As per mattionline:
I get the same thing. When a camera goes white, I click the IP in source, re-save the existing settings, and the camera is back (for a while at least).
Here is what I see when a camera goes white:
And here is the log of what happened when it went white. (The red arrow is when I reset it.)
nextworks
Post by nextworks »
Let's try that again.
nextworks
Post by nextworks »
Is it just me or are images not showing up in the forum?
mattionline
nextworks wrote:Is it just me or are images not showing up in the forum?
its not just you.
try to get the camera stream over rtp/rtsp instead of the http picture. that solved my problem.
here i got some other investigations about error messages. maybe this will help you a bit to understand it:
https://blog.mattionline.de/zoneminder-error-meanings/
nextworks
Post by nextworks »
Thank you. I am converting all cams to rtp/rtsp now. Time will tell if I get the white out. Again, I really appreciate the post.
nextworks
Post by nextworks »
rtp/rtsp did the trick. Thank you again.
For others reading this...
See attached. u and p are in red.
(If the image appears that is)
