Upgraded iOS, Windows Desktop, and Mac Desktop versions of zmNinja from v117 to v119. Using ZoneMinder 1.29.0.
Video footage playback has stopped working after the upgrade (just shows grey screen). Did not work in either Event or Timeline.
Brian
No video footage (v119 zmNinja)
Re: No video footage (v119 zmNinja)
Please make sure you are on 1.1.92
If you can't see video, please send me the logs
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
I have confirmed I'm using 1.1.92D.
I determined the problem was nph-zms was turned OFF in Developer Settings in v1.1.7. If it's left OFF during the upgrade to v1.1.92, it will cause the problem of no event video footage playback.
To fix iOS versions of zmNinja, I deleted the app and reinstalled it.
To fix Windows versions of zmNinja, I deleted all files in the zmNinja directory, installed v1.1.7, turned ON nph-zms in Developer Settings, deleted all the files in zmNinja directory, installed v1.1.92.
Now event video footage playback works again.
