I upgraded from 1.28 to 1.29 with minimal issues other than problems with the SSL certification.
My ZM server is also my home network firewall (shorewall) and media server not using a domain. When connecting from inside the network I am
seeing issues with the bookmarked URLs where the my previous http://<hostname>/zm redirects to https://zm which can't be found. Editing the bookmarks to https://<hostname>/zm works OK other than having to accept the "unsafe" certificate. (I have updated the local cert with genkey)
But I now see the URL as HTTPS: where the https is in red with a slash through it (Chrome). In Firefox if I enter https://<hostname>/zm, Firefox
exits but using the server IP address instead of the hostname works OK. (client boxes are all Windows with hosts file name resolution).
All of the above is workable with a little help to family members having to change the bookmarks. But we also monitor the ZM system remotely.
My home Roadrunner account has a variable IP so I have always used DNSexit for dynamic dns resolution. It has a url of <user>.linkpc.net:xxxx/zm which port forwards to the zm installation. This worked fine with http in 1.28. Now when I enter the url I get an error page where the url redirects to
https://zm which can't be resolved. Entering it as https://<user>.linkpc.net:xxxx/zm responds with error
"SSL_ERROR_RX_RECORD_TOO_LONG
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified."
So I am open to suggestions (and perhaps ridicule
Thanks!
KK
