Zoneminder stops working on USB cams - lots of errors
bomberb17
Post by bomberb17 »
Hello, my setup is ZM 1.29 on ODROID XU4, Ubuntu server 16.04LTS with 3x USB cameras. Two of these USB cameras monitor the same room, but one of them has infrared night vision, so only one of these work, depending the time of the day. So essentially I have 2 USB cams working simultaneously.
I have them at Modect @ 320x240 resolution, 10fps.
The events/images directories are on a external USB 3.0 hard disk.
The problem is that ZM suddenly stops working, and I see on the log that I get a lot of warning errors.
I attach the last piece of the log file below.
Can you help me find a solution?
2016-06-24 18:39:25.425909 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 11 seconds ago, zma may have gone away]
2016-06-24 18:39:26.717280 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14608 at 16/06/24 18:39:26]
2016-06-24 18:39:28.017289 zma_m2[14608].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:39:28.963115 zma_m2[14608].INF-zm_monitor.cpp/625 [Saloni: 594 - Closing event 148, shutting down]
2016-06-24 18:39:30.154920 zmdc[14518].INF-zmdc.pl ['zma -m 2' exited normally]
2016-06-24 18:39:35.032030 zmdc[14518].INF-zmdc.pl [Starting pending process, zma -m 2]
2016-06-24 18:39:35.800610 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:39:35, pid = 14808]
2016-06-24 18:39:35.808930 zmdc[14808].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:39:35]
2016-06-24 18:39:37.308021 undef[14808].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:39:38.148739 zma_m2[14808].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:39:50.834459 zma_m2[14808].INF-zm_monitor.cpp/1605 [Saloni: 121 - Gone into alarm state]
2016-06-24 18:39:51.792242 zma_m2[14808].INF-zm_monitor.cpp/1651 [Saloni: 121 - Opening new event 149, alarm start]
2016-06-24 18:39:53.530844 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 78, image 4798, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:39:54.414478 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 79, image 4799, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:39:58.754318 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 72, image 4872, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:39:59.152703 zma_m2[14808].INF-zm_monitor.cpp/1695 [Saloni: 125 - Gone into alert state]
2016-06-24 18:39:59.876995 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 78, image 4878, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:40:01.534844 zma_m2[14808].INF-zm_monitor.cpp/1686 [Saloni: 126 - Gone back into alarm state]
2016-06-24 18:40:02.957345 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 18, image 4898, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:40:07.382538 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 28, image 4988, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:40:08.590407 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 30, image 4990, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:40:09.618865 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 5000 - Capturing at 10.87 fps]
2016-06-24 18:40:12.049979 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 78, image 5038, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:40:16.814447 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 1, image 5121, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:40:17.543756 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 7 seconds ago, zma may have gone away]
2016-06-24 18:40:22.789640 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 7 seconds (1466782822-1466782815)]
2016-06-24 18:40:23.537870 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 6, image 5286, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:40:24.396284 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 9 seconds ago, zma may have gone away]
2016-06-24 18:40:24.396910 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:40:26.574020 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14808 at 16/06/24 18:40:26]
2016-06-24 18:40:27.232590 zma_m2[14808].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:40:28.852868 zmc_dvideo2[14627].INF-zm_monitor.cpp/3131 [Eisodos: 3000 - Capturing at 7.94 fps]
2016-06-24 18:40:28.895888 zma_m2[14808].INF-zm_monitor.cpp/625 [Saloni: 132 - Closing event 149, shutting down]
2016-06-24 18:40:31.478376 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 8, image 5448, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:40:32.200638 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 11 seconds ago, zma may have gone away]
2016-06-24 18:40:32.488579 zma_m3[14647].INF-zm_monitor.cpp/1287 [Eisodos: 3000 - Analysing at 7.81 fps]
2016-06-24 18:40:32.919250 zmdc[14518].INF-zmdc.pl ['zma -m 2' exited normally]
2016-06-24 18:40:42.100360 zmdc[14518].INF-zmdc.pl [Starting pending process, zma -m 2]
2016-06-24 18:40:42.364870 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:40:42, pid = 14820]
2016-06-24 18:40:42.373840 zmdc[14820].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:40:42]
2016-06-24 18:40:43.187028 undef[14820].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:40:43.825715 zma_m2[14820].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:41:46.533665 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 6000 - Capturing at 10.31 fps]
2016-06-24 18:42:13.234403 zma_m2[14820].INF-zm_monitor.cpp/1605 [Saloni: 732 - Gone into alarm state]
2016-06-24 18:42:13.952685 zma_m2[14820].INF-zm_monitor.cpp/1651 [Saloni: 732 - Opening new event 150, alarm start]
2016-06-24 18:42:16.137268 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 57, image 6297, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:19.810644 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 1, image 6401, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:23.633839 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 33, image 6513, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:26.865595 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 49, image 6609, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:27.161411 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 55, image 6615, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:28.309660 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 75, image 6635, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:29.429279 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 19, image 6659, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:30.296893 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 32, image 6672, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:31.814820 zma_m2[14820].INF-zm_monitor.cpp/1695 [Saloni: 754 - Gone into alert state]
2016-06-24 18:42:33.096861 zma_m2[14820].INF-zm_monitor.cpp/1686 [Saloni: 757 - Gone back into alarm state]
2016-06-24 18:42:34.757968 zma_m2[14820].INF-zm_monitor.cpp/1695 [Saloni: 758 - Gone into alert state]
2016-06-24 18:42:34.861489 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 54, image 6774, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:36.193076 zma_m2[14820].INF-zm_monitor.cpp/1686 [Saloni: 759 - Gone back into alarm state]
2016-06-24 18:42:37.299062 zmc_dvideo2[14627].INF-zm_monitor.cpp/3131 [Eisodos: 4000 - Capturing at 7.75 fps]
2016-06-24 18:42:37.569001 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 10, image 6810, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:38.100855 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 14, image 6814, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:39.734819 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 62, image 6862, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:40.145085 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 69, image 6869, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:40.889792 zma_m3[14647].INF-zm_monitor.cpp/1287 [Eisodos: 4000 - Analysing at 7.81 fps]
2016-06-24 18:42:41.193750 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 7, image 6887, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:42.689632 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 35, image 6915, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:43.853337 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 59, image 6939, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:44.277078 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 64, image 6944, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:45.524726 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 8, image 6968, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:46.421105 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 22, image 6982, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:47.253939 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 7000 - Capturing at 16.39 fps]
2016-06-24 18:42:51.017791 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 32, image 7072, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:51.877028 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 34, image 7074, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:54.217485 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 2, image 7122, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:55.222217 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 8, image 7128, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:56.581386 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 28, image 7148, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:57.716495 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 52, image 7172, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:42:58.581983 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 65, image 7185, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:43:00.612902 zma_m2[14820].INF-zm_monitor.cpp/1695 [Saloni: 779 - Gone into alert state]
2016-06-24 18:43:10.670484 zma_m2[14820].INF-zm_monitor.cpp/1702 [Saloni: 804 - Left alarm state (150) - 97(43) images]
2016-06-24 18:43:10.917468 zma_m2[14820].INF-zm_monitor.cpp/1707 [Saloni: 804 - Closing event 150, alarm end]
2016-06-24 18:43:14.970116 zma_m2[14820].INF-zm_monitor.cpp/1605 [Saloni: 854 - Gone into alarm state]
2016-06-24 18:43:16.465161 zma_m2[14820].INF-zm_monitor.cpp/1651 [Saloni: 854 - Opening new event 151, alarm start]
2016-06-24 18:43:18.013547 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 3, image 7443, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:43:21.301079 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 4, image 7524, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:43:22.591003 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 8 seconds ago, zma may have gone away]
2016-06-24 18:43:26.850340 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 7 seconds (1466783006-1466782999)]
2016-06-24 18:43:27.554770 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:43:28.787060 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14820 at 16/06/24 18:43:28]
2016-06-24 18:43:29.193233 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 6, image 7686, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:43:30.128778 zma_m2[14820].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:43:30.837199 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 11 seconds ago, zma may have gone away]
2016-06-24 18:43:34.147529 zma_m2[14820].INF-zm_monitor.cpp/625 [Saloni: 857 - Closing event 151, shutting down]
2016-06-24 18:43:35.464587 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 8, image 7768, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:43:35.571560 zmdc[14518].INF-zmdc.pl ['zma -m 2' exited normally]
2016-06-24 18:43:36.015220 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 1466783016 seconds ago, zma may have gone away]
2016-06-24 18:43:46.751500 zmwatch[14668].ERR-zmwatch.pl [Error getting last capture time for  Saloni]
2016-06-24 18:43:47.231430 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:43:47.796990 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:43:47, pid = 14853]
2016-06-24 18:43:47.797000 zmdc[14853].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:43:47]
2016-06-24 18:43:48.162191 undef[14853].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:43:50.176387 zma_m2[14853].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:44:03.747531 zma_m2[14853].INF-zm_monitor.cpp/1605 [Saloni: 106 - Gone into alarm state]
2016-06-24 18:44:04.422364 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 8000 - Capturing at 12.99 fps]
2016-06-24 18:44:04.472697 zma_m2[14853].INF-zm_monitor.cpp/1651 [Saloni: 106 - Opening new event 152, alarm start]
2016-06-24 18:44:06.505211 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 59, image 8059, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:09.689829 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 60, image 8060, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:12.410304 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 54, image 8134, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:16.714951 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 12, image 8252, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:17.965285 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 40, image 8280, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:21.765247 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 72, image 8392, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:22.439211 zma_m2[14853].WAR-zm_monitor.cpp/1315 [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
2016-06-24 18:44:22.465103 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 6, image 8406, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:22.690127 zma_m2[14853].INF-zm_monitor.cpp/1695 [Saloni: 117 - Gone into alert state]
2016-06-24 18:44:31.868339 zma_m2[14853].INF-zm_monitor.cpp/1702 [Saloni: 142 - Left alarm state (152) - 61(11) images]
2016-06-24 18:44:32.107060 zma_m2[14853].INF-zm_monitor.cpp/1707 [Saloni: 142 - Closing event 152, alarm end]
2016-06-24 18:44:32.916885 zma_m2[14853].INF-zm_monitor.cpp/1605 [Saloni: 156 - Gone into alarm state]
2016-06-24 18:44:33.628964 zma_m2[14853].INF-zm_monitor.cpp/1651 [Saloni: 156 - Opening new event 153, alarm start]
2016-06-24 18:44:35.289304 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 7, image 8567, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:38.330470 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 6 seconds (1466783078-1466783072)]
2016-06-24 18:44:38.685192 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 7, image 8647, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:44:39.551060 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:44:43.374539 zmc_dvideo2[14627].INF-zm_monitor.cpp/3131 [Eisodos: 5000 - Capturing at 7.94 fps]
2016-06-24 18:44:44.282459 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 12 seconds ago, zma may have gone away]
2016-06-24 18:44:44.314278 zma_m2[14853].INF-zm_monitor.cpp/1695 [Saloni: 157 - Gone into alert state]
2016-06-24 18:44:44.606700 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14853 at 16/06/24 18:44:44]
2016-06-24 18:44:45.954420 zma_m2[14853].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:44:47.312371 zma_m3[14647].INF-zm_monitor.cpp/1287 [Eisodos: 5000 - Analysing at 7.87 fps]
2016-06-24 18:44:49.727221 zma_m2[14853].INF-zm_monitor.cpp/625 [Saloni: 158 - Closing event 153, shutting down]
2016-06-24 18:44:51.395510 zmdc[14518].INF-zmdc.pl ['zma -m 2' exited normally]
2016-06-24 18:45:01.906790 zmwatch[14668].ERR-zmwatch.pl [Error getting last capture time for  Saloni]
2016-06-24 18:45:02.149860 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:45:02.974520 zmdc[14867].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:45:02]
2016-06-24 18:45:02.979720 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:45:02, pid = 14867]
2016-06-24 18:45:03.552375 undef[14867].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:45:03.945837 zma_m2[14867].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:45:05.874329 zma_m2[14867].INF-zm_monitor.cpp/1605 [Saloni: 026 - Gone into alarm state]
2016-06-24 18:45:09.860616 zma_m2[14867].INF-zm_monitor.cpp/1651 [Saloni: 026 - Opening new event 154, alarm start]
2016-06-24 18:45:10.733078 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 33, image 8913, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:12.116011 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 34, image 8914, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:15.333036 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 29, image 8989, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:15.993101 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 9000 - Capturing at 14.08 fps]
2016-06-24 18:45:20.161356 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 59, image 9099, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:22.329126 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 75, image 9115, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:23.257011 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 4, image 9124, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:27.997919 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 32, image 9232, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:31.720796 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 58, image 9338, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:35.883964 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 79, image 9439, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:39.183925 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 79, image 9519, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:41.426777 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 8 seconds ago, zma may have gone away]
2016-06-24 18:45:43.977940 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 9 seconds (1466783143-1466783134)]
2016-06-24 18:45:45.445230 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:45:46.696810 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14867 at 16/06/24 18:45:46]
2016-06-24 18:45:48.080759 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 31, image 9711, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:45:48.307095 zma_m2[14867].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:45:48.968018 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 7 seconds ago, zma may have gone away]
2016-06-24 18:45:54.309590 zmdc[14518].WAR-zmdc.pl ['zma -m 2' has not stopped at 16/06/24 18:45:54. Sending KILL to pid 14867]
2016-06-24 18:45:54.859740 zmdc[14518].INF-zmdc.pl ['zma -m 2' crashed, signal 8]
2016-06-24 18:46:00.005167 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 10000 - Capturing at 22.22 fps]
2016-06-24 18:46:05.587860 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 24 seconds (1466783165-1466783141)]
2016-06-24 18:46:06.188640 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:46:07.455280 zmdc[14881].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:46:07]
2016-06-24 18:46:07.455510 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:46:07, pid = 14881]
2016-06-24 18:46:08.432113 undef[14881].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:46:08.818519 zma_m2[14881].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:46:11.621544 zma_m2[14881].INF-zm_monitor.cpp/1605 [Saloni: 029 - Gone into alarm state]
2016-06-24 18:46:12.808075 zma_m2[14881].INF-zm_monitor.cpp/1651 [Saloni: 029 - Opening new event 155, alarm start]
2016-06-24 18:46:14.478025 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 36, image 10356, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:15.073229 zma_m2[14881].INF-zm_monitor.cpp/1695 [Saloni: 030 - Gone into alert state]
2016-06-24 18:46:16.124649 zma_m2[14881].INF-zm_monitor.cpp/1686 [Saloni: 033 - Gone back into alarm state]
2016-06-24 18:46:18.593081 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 48, image 10448, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:18.650363 zma_m2[14881].INF-zm_monitor.cpp/1695 [Saloni: 036 - Gone into alert state]
2016-06-24 18:46:18.933855 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 54, image 10454, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:20.103759 zma_m2[14881].INF-zm_monitor.cpp/1686 [Saloni: 038 - Gone back into alarm state]
2016-06-24 18:46:21.023913 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 2, image 10482, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:21.586963 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 8, image 10488, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:25.632869 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 42, image 10602, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:26.310105 zma_m2[14881].WAR-zm_monitor.cpp/1315 [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
2016-06-24 18:46:26.325209 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 56, image 10616, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:29.629538 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 60, image 10700, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:30.098125 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 68, image 10708, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:31.051786 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 4, image 10724, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:34.253176 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 6, image 10806, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:35.230327 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 26, image 10826, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:36.348723 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 50, image 10850, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:37.216664 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 63, image 10863, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:40.681377 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 79, image 10959, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:41.026732 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 5, image 10965, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:42.149065 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 25, image 10985, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:42.912248 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 11000 - Capturing at 23.81 fps]
2016-06-24 18:46:43.207777 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 45, image 11005, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:44.728152 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 69, image 11029, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:46.561211 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 31, image 11071, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:47.508820 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 51, image 11091, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:48.661492 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 75, image 11115, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:49.513980 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 8, image 11128, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:46:49.833668 zmc_dvideo2[14627].INF-zm_monitor.cpp/3131 [Eisodos: 6000 - Capturing at 7.94 fps]
2016-06-24 18:46:51.511353 zma_m2[14881].INF-zm_monitor.cpp/1695 [Saloni: 073 - Gone into alert state]
2016-06-24 18:46:53.926829 zma_m3[14647].INF-zm_monitor.cpp/1287 [Eisodos: 6000 - Analysing at 7.94 fps]
2016-06-24 18:46:59.526960 zma_m2[14881].INF-zm_monitor.cpp/1686 [Saloni: 094 - Gone back into alarm state]
2016-06-24 18:47:00.969215 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 13, image 11293, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:01.207217 zma_m2[14881].INF-zm_monitor.cpp/1695 [Saloni: 095 - Gone into alert state]
2016-06-24 18:47:02.147350 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 16, image 11296, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:12.729878 zma_m2[14881].INF-zm_monitor.cpp/1702 [Saloni: 120 - Left alarm state (155) - 116(40) images]
2016-06-24 18:47:13.424332 zma_m2[14881].INF-zm_monitor.cpp/1707 [Saloni: 120 - Closing event 155, alarm end]
2016-06-24 18:47:14.238172 zma_m2[14881].INF-zm_monitor.cpp/1605 [Saloni: 136 - Gone into alarm state]
2016-06-24 18:47:14.968286 zma_m2[14881].INF-zm_monitor.cpp/1651 [Saloni: 136 - Opening new event 156, alarm start]
2016-06-24 18:47:16.659842 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 16, image 11456, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:17.259247 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 18, image 11458, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:19.336433 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 66, image 11506, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:20.141952 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 70, image 11510, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:21.565268 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 18, image 11538, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:25.057081 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 42, image 11642, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:28.919673 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 65, image 11745, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:29.793961 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 75, image 11755, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:33.684769 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 13, image 11853, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:35.579143 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 24, image 11864, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:39.051544 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 48, image 11968, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:41.145154 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 12000 - Capturing at 16.95 fps]
2016-06-24 18:47:43.678611 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 69, image 12069, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:45.475594 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 2, image 12082, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:49.317376 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 29, image 12189, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:51.136171 zma_m2[14881].WAR-zm_monitor.cpp/1315 [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
2016-06-24 18:47:51.139954 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 43, image 12203, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:54.436643 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 47, image 12287, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:56.091621 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 55, image 12295, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:47:58.200444 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 71, image 12311, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:02.504528 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 0, image 12400, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:03.099404 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 2, image 12402, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:05.630997 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 50, image 12450, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:09.896645 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 62, image 12542, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:12.949249 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 68, image 12548, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:16.061962 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 68, image 12628, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:17.858760 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 6 seconds ago, zma may have gone away]
2016-06-24 18:48:18.504980 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 7 seconds (1466783298-1466783291)]
2016-06-24 18:48:21.121061 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 14, image 12654, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:21.173560 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:48:22.855170 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14881 at 16/06/24 18:48:22]
2016-06-24 18:48:23.755157 zma_m2[14881].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:48:24.487120 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 19, image 12739, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:25.407500 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 5 seconds ago, zma may have gone away]
2016-06-24 18:48:26.864038 zma_m2[14881].INF-zm_monitor.cpp/625 [Saloni: 184 - Closing event 156, shutting down]
2016-06-24 18:48:28.044900 zmdc[14518].INF-zmdc.pl ['zma -m 2' exited normally]
2016-06-24 18:48:38.553910 zmwatch[14668].ERR-zmwatch.pl [Error getting last capture time for  Saloni]
2016-06-24 18:48:38.793110 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:48:39.576910 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:48:39, pid = 14915]
2016-06-24 18:48:39.576930 zmdc[14915].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:48:39]
2016-06-24 18:48:39.936817 undef[14915].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:48:40.555209 zma_m2[14915].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:48:43.669115 zma_m2[14915].INF-zm_monitor.cpp/1605 [Saloni: 038 - Gone into alarm state]
2016-06-24 18:48:45.854270 zma_m2[14915].INF-zm_monitor.cpp/1651 [Saloni: 038 - Opening new event 157, alarm start]
2016-06-24 18:48:46.040743 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 13000 - Capturing at 15.38 fps]
2016-06-24 18:48:47.100879 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 48, image 13008, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:50.101240 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 7 seconds (1466783330-1466783323)]
2016-06-24 18:48:50.371813 zma_m2[14915].INF-zm_monitor.cpp/1695 [Saloni: 039 - Gone into alert state]
2016-06-24 18:48:50.830230 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:48:52.268633 zma_m2[14915].INF-zm_monitor.cpp/1686 [Saloni: 040 - Gone back into alarm state]
2016-06-24 18:48:52.340450 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14915 at 16/06/24 18:48:52]
2016-06-24 18:48:53.200410 zma_m2[14915].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:48:53.300476 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 51, image 13091, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:55.790561 zmc_dvideo2[14627].INF-zm_monitor.cpp/3131 [Eisodos: 7000 - Capturing at 7.94 fps]
2016-06-24 18:48:56.613335 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 51, image 13171, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:48:57.698004 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 7 seconds ago, zma may have gone away]
2016-06-24 18:48:59.202480 zmdc[14518].WAR-zmdc.pl ['zma -m 2' has not stopped at 16/06/24 18:48:59. Sending KILL to pid 14915]
2016-06-24 18:49:00.418126 zma_m3[14647].INF-zm_monitor.cpp/1287 [Eisodos: 7000 - Analysing at 7.87 fps]
2016-06-24 18:49:00.518680 zmdc[14518].INF-zmdc.pl ['zma -m 2' crashed, signal 8]
2016-06-24 18:49:12.193610 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 22 seconds (1466783352-1466783330)]
2016-06-24 18:49:12.768180 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:49:13.567770 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:49:13, pid = 14920]
2016-06-24 18:49:13.567790 zmdc[14920].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:49:13]
2016-06-24 18:49:14.115746 undef[14920].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:49:14.757773 zma_m2[14920].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:49:21.309400 web_js[14437].WAR-?view=events [Adjusting to minimum width when getting popup size for tag 'event' - getPopupSize()]
2016-06-24 18:49:21.824442 web_js[14437].WAR-?view=events [Adjusting to minimum height when getting popup size for tag 'event' - getPopupSize()]
2016-06-24 18:49:22.767254 undef[14921].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:49:42.037748 web_php[14437].ERR-/usr/share/zoneminder/www/includes/functions.php/2371 [Timed out waiting for msg /var/run/zm/zms-693392s.sock]
2016-06-24 18:49:42.350347 web_js[14437].ERR-?view=event [getCmdResponse stream error: Timed out waiting for msg /var/run/zm/zms-693392s.sock - checkStreamForErrors()]
2016-06-24 18:49:44.234275 web_js[14437].WAR-?view=events [Adjusting to minimum width when getting popup size for tag 'event' - getPopupSize()]
2016-06-24 18:49:44.764777 zms[14921].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:49:44.785578 undef[14931].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:49:45.339014 web_js[14437].WAR-?view=events [Adjusting to minimum height when getting popup size for tag 'event' - getPopupSize()]
2016-06-24 18:49:57.125841 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 14000 - Capturing at 14.08 fps]
2016-06-24 18:50:06.824848 undef[14935].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:50:07.881654 zms[14931].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:50:17.206942 zms[14935].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:50:24.274922 zma_m2[14920].INF-zm_monitor.cpp/1605 [Saloni: 573 - Gone into alarm state]
2016-06-24 18:50:25.243035 zma_m2[14920].INF-zm_monitor.cpp/1651 [Saloni: 573 - Opening new event 158, alarm start]
2016-06-24 18:50:25.253908 web_js[14386].WAR-?view=events [Adjusting to minimum width when getting popup size for tag 'event' - getPopupSize()]
2016-06-24 18:50:25.669341 undef[14938].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:50:25.831809 web_js[14386].WAR-?view=events [Adjusting to minimum height when getting popup size for tag 'event' - getPopupSize()]
2016-06-24 18:50:27.147884 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 50, image 14290, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:50:27.188929 zma_m2[14920].INF-zm_monitor.cpp/1695 [Saloni: 574 - Gone into alert state]
2016-06-24 18:50:27.419203 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 51, image 14291, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:50:28.861187 zma_m2[14920].INF-zm_monitor.cpp/1686 [Saloni: 575 - Gone back into alarm state]
2016-06-24 18:50:30.511733 zma_m2[14920].INF-zm_monitor.cpp/1695 [Saloni: 576 - Gone into alert state]
2016-06-24 18:50:37.133934 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 5, image 14405, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:50:40.479837 zms[14938].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:50:41.423500 zma_m2[14920].INF-zm_monitor.cpp/1686 [Saloni: 584 - Gone back into alarm state]
2016-06-24 18:50:43.735997 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 21, image 14501, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:50:43.832189 zma_m2[14920].INF-zm_monitor.cpp/1695 [Saloni: 585 - Gone into alert state]
2016-06-24 18:50:44.061018 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 23, image 14503, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:50:48.791175 zma_m2[14920].INF-zm_monitor.cpp/1686 [Saloni: 586 - Gone back into alarm state]
2016-06-24 18:50:50.509394 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 71, image 14551, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:50:50.578902 web_js[14386].WAR- [Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize()]
2016-06-24 18:50:51.142391 undef[14948].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:50:53.534068 zms[14948].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:50:54.596510 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 11 seconds (1466783454-1466783443)]
2016-06-24 18:50:54.779011 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 71, image 14631, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:50:54.905160 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:50:55.380063 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 12 seconds ago, zma may have gone away]
2016-06-24 18:50:56.147910 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14920 at 16/06/24 18:50:56]
2016-06-24 18:50:57.039651 zma_m2[14920].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:50:59.657034 zma_m2[14920].INF-zm_monitor.cpp/625 [Saloni: 587 - Closing event 158, shutting down]
2016-06-24 18:51:01.391773 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 76, image 14796, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:51:02.036700 zmdc[14518].INF-zmdc.pl ['zma -m 2' exited normally]
2016-06-24 18:51:02.319876 zmc_dvideo2[14627].INF-zm_monitor.cpp/3131 [Eisodos: 8000 - Capturing at 7.87 fps]
2016-06-24 18:51:06.271287 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 1466783466 seconds ago, zma may have gone away]
2016-06-24 18:51:10.431590 zmdc[14518].INF-zmdc.pl ['zma -m 3' sending stop to pid 14647 at 16/06/24 18:51:10]
2016-06-24 18:51:10.444939 zma_m3[14647].INF-zm_monitor.cpp/1287 [Eisodos: 8000 - Analysing at 7.69 fps]
2016-06-24 18:51:10.911484 zma_m3[14647].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:51:11.429590 zmdc[14518].INF-zmdc.pl ['zma -m 3' exited normally]
2016-06-24 18:51:12.258380 zmdc[14518].INF-zmdc.pl ['zmc -d /dev/video2' sending stop to pid 14627 at 16/06/24 18:51:12]
2016-06-24 18:51:12.507046 zmc_dvideo2[14627].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:51:12.847410 zmdc[14518].INF-zmdc.pl ['zmc -d /dev/video2' exited normally]
2016-06-24 18:51:13.660300 zmdc[14518].INF-zmdc.pl ['zmc -d /dev/video2' starting at 16/06/24 18:51:13, pid = 14963]
2016-06-24 18:51:13.660330 zmdc[14963].INF-zmdc.pl ['zmc -d /dev/video2' started at 16/06/24 18:51:13]
2016-06-24 18:51:14.257472 undef[14963].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:51:14.530740 zmdc[14967].INF-zmdc.pl ['zma -m 3' started at 16/06/24 18:51:14]
2016-06-24 18:51:14.535100 zmdc[14518].INF-zmdc.pl ['zma -m 3' starting at 16/06/24 18:51:14, pid = 14967]
2016-06-24 18:51:14.742216 zmc_dvideo2[14963].INF-zm_local_camera.cpp/351 [Selected capture palette: YUV 4:2:2 (YUYV) (YUYV)]
2016-06-24 18:51:15.114055 undef[14967].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:51:15.231395 zmc_dvideo2[14963].INF-zm_local_camera.cpp/412 [No direct match for the selected palette (]
2016-06-24 18:51:15.716927 zma_m3[14967].ERR-zm_monitor.cpp/442 [Shared data not initialised by capture daemon for monitor Eisodos]
2016-06-24 18:51:16.003958 zmc_dvideo2[14963].INF-zmc.cpp/250 [Starting Capture version 1.29.0]
2016-06-24 18:51:16.210900 zmdc[14518].ERR-zmdc.pl ['zma -m 3' exited abnormally, exit status 255]
2016-06-24 18:51:16.319450 zmwatch[14668].ERR-zmwatch.pl [Error getting last capture time for  Saloni]
2016-06-24 18:51:16.686634 zmc_dvideo2[14963].WAR-zm_local_camera.cpp/1786 [Hue control is not supported]
2016-06-24 18:51:16.909590 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:51:16.909970 zmdc[14518].INF-zmdc.pl [Starting pending process, zma -m 3]
2016-06-24 18:51:17.645000 zmdc[14518].INF-zmdc.pl ['zma -m 3' starting at 16/06/24 18:51:17, pid = 14979]
2016-06-24 18:51:17.654530 zmdc[14979].INF-zmdc.pl ['zma -m 3' started at 16/06/24 18:51:17]
2016-06-24 18:51:17.961940 zmdc[14981].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:51:17]
2016-06-24 18:51:17.971440 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:51:17, pid = 14981]
2016-06-24 18:51:18.239057 undef[14979].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:51:18.666300 zmwatch[14668].ERR-zmwatch.pl [Error getting last capture time for  Eisodos]
2016-06-24 18:51:18.753905 undef[14981].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:51:18.901462 zma_m3[14979].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:51:19.088040 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Eisodos]
2016-06-24 18:51:19.109830 zma_m2[14981].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:51:20.104690 zmdc[14518].INF-zmdc.pl ['zma -m 3' sending stop to pid 14979 at 16/06/24 18:51:20]
2016-06-24 18:51:20.812560 zma_m3[14979].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:51:21.294560 zmdc[14518].INF-zmdc.pl ['zma -m 3' exited normally]
2016-06-24 18:51:22.676910 zma_m2[14981].INF-zm_monitor.cpp/1605 [Saloni: 031 - Gone into alarm state]
2016-06-24 18:51:24.236103 zma_m2[14981].INF-zm_monitor.cpp/1651 [Saloni: 031 - Opening new event 159, alarm start]
2016-06-24 18:51:25.811585 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 33, image 14993, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:51:26.028820 zmdc[14518].INF-zmdc.pl [Starting pending process, zma -m 3]
2016-06-24 18:51:27.075740 zmdc[14990].INF-zmdc.pl ['zma -m 3' started at 16/06/24 18:51:27]
2016-06-24 18:51:27.081120 zmdc[14518].INF-zmdc.pl ['zma -m 3' starting at 16/06/24 18:51:27, pid = 14990]
2016-06-24 18:51:27.101267 zmc_dvideo1[14607].INF-zm_monitor.cpp/3131 [Saloni: 15000 - Capturing at 11.11 fps]
2016-06-24 18:51:27.948129 undef[14990].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:51:28.469390 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14981 at 16/06/24 18:51:28]
2016-06-24 18:51:29.196691 zma_m3[14990].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:51:29.875579 zma_m2[14981].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:51:30.745526 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 34, image 15074, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:51:31.751620 zmc_dvideo1[14607].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 9 seconds ago, zma may have gone away]
2016-06-24 18:51:32.037300 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 10 seconds (1466783492-1466783482)]
2016-06-24 18:51:32.465949 zma_m2[14981].INF-zm_monitor.cpp/625 [Saloni: 033 - Closing event 159, shutting down]
2016-06-24 18:51:33.167920 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:51:34.846640 zmdc[14518].INF-zmdc.pl ['zma -m 2' exited normally]
2016-06-24 18:51:34.875220 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:51:34, pid = 14993]
2016-06-24 18:51:34.893240 zmdc[14993].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:51:34]
2016-06-24 18:51:35.356580 zmdc[14518].INF-zmdc.pl ['zmc -d /dev/video1' sending stop to pid 14607 at 16/06/24 18:51:35]
2016-06-24 18:51:35.723958 undef[14993].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:51:35.841258 zmc_dvideo1[14607].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:51:36.348574 zma_m2[14993].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:51:36.660890 zmdc[14518].INF-zmdc.pl ['zmc -d /dev/video1' exited normally]
2016-06-24 18:51:37.407800 zmdc[14518].INF-zmdc.pl ['zmc -d /dev/video1' starting at 16/06/24 18:51:37, pid = 15000]
2016-06-24 18:51:37.407820 zmdc[15000].INF-zmdc.pl ['zmc -d /dev/video1' started at 16/06/24 18:51:37]
2016-06-24 18:51:38.230504 undef[15000].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:51:38.474680 zmc_dvideo1[15000].INF-zm_local_camera.cpp/351 [Selected capture palette: YUV 4:2:2 (YUYV) (YUYV)]
2016-06-24 18:51:38.498650 zmdc[14518].INF-zmdc.pl ['zma -m 2' already running at 16/06/24 18:51:34, pid = 14993]
2016-06-24 18:51:38.959120 zmc_dvideo1[15000].INF-zm_local_camera.cpp/412 [No direct match for the selected palette (]
2016-06-24 18:51:39.518143 zmc_dvideo1[15000].INF-zmc.cpp/250 [Starting Capture version 1.29.0]
2016-06-24 18:51:40.024051 zmc_dvideo1[15000].WAR-zm_local_camera.cpp/1786 [Hue control is not supported]
2016-06-24 18:51:48.561301 zma_m2[14993].INF-zm_monitor.cpp/1605 [Saloni: 033 - Gone into alarm state]
2016-06-24 18:51:51.373904 zma_m2[14993].INF-zm_monitor.cpp/1651 [Saloni: 033 - Opening new event 160, alarm start]
2016-06-24 18:51:51.618300 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 32, image 112, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:51:54.551478 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 32, image 192, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:51:55.666030 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 7 seconds (1466783515-1466783508)]
2016-06-24 18:51:58.239508 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 10 seconds ago, zma may have gone away]
2016-06-24 18:51:58.239660 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:51:59.954720 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 14993 at 16/06/24 18:51:59]
2016-06-24 18:52:01.299101 zma_m2[14993].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:52:02.151684 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 33, image 273, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:03.664872 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 15 seconds ago, zma may have gone away]
2016-06-24 18:52:04.392956 zma_m2[14993].INF-zm_monitor.cpp/625 [Saloni: 035 - Closing event 160, shutting down]
2016-06-24 18:52:07.301300 zmdc[14518].WAR-zmdc.pl ['zma -m 2' has not stopped at 16/06/24 18:52:07. Sending KILL to pid 14993]
2016-06-24 18:52:09.104550 zmdc[14518].INF-zmdc.pl ['zma -m 2' crashed, signal 8]
2016-06-24 18:52:10.853820 zmdc[14518].INF-zmdc.pl [Starting pending process, zma -m 2]
2016-06-24 18:52:11.490530 zmdc[14518].INF-zmdc.pl ['zma -m 2' starting at 16/06/24 18:52:11, pid = 15027]
2016-06-24 18:52:11.507320 zmdc[15027].INF-zmdc.pl ['zma -m 2' started at 16/06/24 18:52:11]
2016-06-24 18:52:13.931916 undef[15027].INF-zm_config.cpp/139 [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
2016-06-24 18:52:15.709808 zma_m2[15027].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-06-24 18:52:21.048337 zma_m2[15027].INF-zm_monitor.cpp/1605 [Saloni: 039 - Gone into alarm state]
2016-06-24 18:52:23.200919 zma_m2[15027].INF-zm_monitor.cpp/1651 [Saloni: 039 - Opening new event 161, alarm start]
2016-06-24 18:52:24.297541 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 59, image 699, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:29.231170 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 60, image 780, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:30.098332 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 64, image 784, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:35.608823 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 13, image 893, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:39.155265 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 21, image 981, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:41.428348 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 23, image 983, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:42.922126 zmc_dvideo1[15000].INF-zm_monitor.cpp/3131 [Saloni: 1000 - Capturing at 15.87 fps]
2016-06-24 18:52:45.751205 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 75, image 1035, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:49.751428 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 1, image 1121, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:51.361684 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 5, image 1125, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:53.232442 zma_m2[15027].WAR-zm_monitor.cpp/1315 [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
2016-06-24 18:52:53.247434 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 33, image 1153, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:52:57.160241 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 35, image 1235, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:53:00.179202 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 35, image 1315, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:53:00.777907 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 5 seconds ago, zma may have gone away]
2016-06-24 18:53:07.374703 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 60, image 1420, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:53:10.969866 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 0, image 1520, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:53:12.099928 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 5 seconds ago, zma may have gone away]
2016-06-24 18:53:16.267098 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 2, image 1602, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:53:17.736248 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 8 seconds ago, zma may have gone away]
2016-06-24 18:53:20.876510 zmwatch[14668].INF-zmwatch.pl [Analysis daemon for  Saloni needs restarting, time since last analysis 6 seconds (1466783600-1466783594)]
2016-06-24 18:53:22.339749 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 52, image 1732, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:53:22.684340 zmwatch[14668].INF-zmwatch.pl [Restarting analysis daemon for  Saloni]
2016-06-24 18:53:23.387566 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 6 seconds ago, zma may have gone away]
2016-06-24 18:53:24.690710 zmdc[14518].INF-zmdc.pl ['zma -m 2' sending stop to pid 15027 at 16/06/24 18:53:24]
2016-06-24 18:53:26.204196 zma_m2[15027].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:53:28.801827 zma_m2[15027].INF-zm_monitor.cpp/625 [Saloni: 060 - Closing event 161, shutting down]
2016-06-24 18:53:30.658800 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3100 [Buffer overrun at index 60, image 1900, slow down capture, speed up analysis or increase ring buffer size]
2016-06-24 18:53:31.623332 zmc_dvideo1[15000].WAR-zm_monitor.cpp/3106 [Last image read from shared memory 10 seconds ago, zma may have gone away]
2016-06-24 18:53:32.207720 zmdc[14518].WAR-zmdc.pl ['zma -m 2' has not stopped at 16/06/24 18:53:32. Sending KILL to pid 15027]
2016-06-24 18:53:33.281390 zmdc[14518].INF-zmdc.pl ['zma -m 2' exited normally]
2016-06-24 18:53:34.311860 zmpkg[15030].INF-zmpkg.pl [Sanity checking States table...]
2016-06-24 18:53:37.054370 zmpkg[15030].INF-zmpkg.pl [Command: stop]
2016-06-24 18:53:38.334629 zmc_dvideo2[14963].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:53:38.337244 zmc_dvideo1[15000].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-06-24 18:53:38.338046 zma_m3[14990].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
SteveGilvarry
Re: Zoneminder stops working on USB cams - lots of errors
Post by SteveGilvarry »
Looks like performance related issue, reduce fps to 5 and see if get's better.
bomberb17
Post by bomberb17 »
I had a previous setup on the exactly same machine, running Ubuntu 14.04 and Zoneminder 1.25 without any problems.
I had dropped to 4fps but the problem was the same.
I now changed Buffers settings to:
Image buffer size -> 250
Warmup Grames & Pre event image count -> 50
Post Event image count -> 75
Stream Replay Image buffer ->1000
Alarm Frame Count -> 3
And it works somewhat smoother. Not getting these errors again, but I am getting these errors now:
zmwatch ERR Error getting last capture time for xxxxxx zmwatch.pl
and sometimes Zoneminder just goes to stop mode.
bomberb17
Post by bomberb17 »
I am still having problems. If noone is at home, zoneminder works fine.
If there's some motion though, it stops with no reason.
Here's the log
Jul 10 13:05:02 odroid-server zma_m3[21579]: INF [Eisodos: 35000 - Analysing at 3.97 fps]
Jul 10 13:05:02 odroid-server rsyslogd-2007: action 'action 9' suspended, next retry is Sun Jul 10 13:06:32 2016 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jul 10 13:05:31 odroid-server zma_m2[22062]: INF [Saloni: 1357 - Left alarm state (869) - 147(22) images]
Jul 10 13:05:32 odroid-server zma_m2[22062]: INF [Saloni: 1357 - Closing event 869, alarm end]
Jul 10 13:05:33 odroid-server zma_m2[22062]: INF [Saloni: 1440 - Gone into prealarm state]
Jul 10 13:05:34 odroid-server zma_m2[22062]: INF [Saloni: 1442 - Gone into alarm state]
Jul 10 13:05:36 odroid-server zma_m2[22062]: INF [Saloni: 1442 - Opening new event 870, alarm start]
Jul 10 13:05:39 odroid-server zmwatch[12722]: INF [Analysis daemon for  Saloni needs restarting, time since last analysis 6 seconds (1468145139-1468145133)]
Jul 10 13:05:39 odroid-server zmwatch[12722]: INF [Restarting analysis daemon for  Saloni]
Jul 10 13:05:41 odroid-server zmdc[12575]: INF ['zma -m 2' sending stop to pid 22062 at 16/07/10 13:05:41]
Jul 10 13:05:44 odroid-server zma_m3[21579]: INF [Eisodos: 35154 - Gone into prealarm state]
Jul 10 13:05:44 odroid-server zmc_dvideo1[12666]: INF [Saloni: 638000 - Capturing at 11.49 fps]
Jul 10 13:05:45 odroid-server zma_m2[22062]: INF [Got signal 15 (Terminated), exiting]
Jul 10 13:05:47 odroid-server zma_m2[22062]: INF [Saloni: 1445 - Closing event 870, shutting down]
Jul 10 13:05:49 odroid-server zmc_dvideo1[12666]: WAR [Buffer overrun at index 148, image 638148, slow down capture, speed up analysis or increase ring buffer size]
Jul 10 13:05:50 odroid-server zmdc[12575]: WAR ['zma -m 2' has not stopped at 16/07/10 13:05:50. Sending KILL to pid 22062]
Jul 10 13:05:50 odroid-server zmdc[12575]: INF ['zma -m 2' exited normally]
Jul 10 13:05:51 odroid-server systemd[1]: zoneminder.service: Main process exited, code=exited, status=4/NOPERMISSION
Jul 10 13:05:51 odroid-server zmpkg[22073]: INF [Sanity checking States table...]
Jul 10 13:05:52 odroid-server zmpkg[22073]: INF [Command: stop]
Jul 10 13:05:54 odroid-server systemd[1]: zoneminder.service: Control process exited, code=exited status=1
Jul 10 13:05:55 odroid-server zma_m3[21579]: INF [Got signal 15 (Terminated), exiting]
Jul 10 13:05:56 odroid-server zmc_dvideo1[12666]: INF [Got signal 15 (Terminated), exiting]
Jul 10 13:05:56 odroid-server zmc_dvideo2[12685]: INF [Got signal 15 (Terminated), exiting]
Jul 10 13:05:56 odroid-server systemd[1]: zoneminder.service: Unit entered failed state.
Jul 10 13:05:56 odroid-server systemd[1]: zoneminder.service: Failed with result 'exit-code'.
Your hardware still cannot keep up the way it is currently configured, as shown by this error:
I thought you said you reduced the frame rate to 4? That is not what this says:
So first, make sure all three of you cameras are really set to 4fps, at all times.
These small computers are limited in ways normal pc users don't usually have to worry about.
Especially since your Odriod has a gigabit ethernet nic, I'd use a small NAS to record events to. If you don't have or don't want to buy a NAS, then move all your USB devices, except for the hard drive, onto the USB 2.0 port. You will need a USB hub of course since you've only got one USB 2.0 port. This will keep slower moving data off your USB 3.0 bus.
What disk is your database running on? Is that disk an sd card? That could slow you down.
What does your memory and cpu load look like?
