zmNinja 1.1.94 upgrade. App malfunction
linforpros
Post by linforpros »
I just upgraded zmNinja. It shows version 1.1.94.
It is completely unusable. I have rebooted the phone.
The zmNinja's UI looks like it is missing some formatting.
It does log in to the server but the user interface looks like some crippled browser window.
Is this known to the larger audience?
best regards
LinforPros
asker
Re: zmNinja 1.1.94 upgrade. App malfunction
Post by asker »
Yup. Just pushed 1.1.95.
I hear people are burning effigies.
Please read before posting:
ES docs
zmNinja docs
linforpros
asker wrote:Yup. Just pushed 1.1.95.
I did not have any figurines to burn but made some phone calls to friends to not upgrade, so they remain on the safe side of the game :D
Thank you for pushing the corrected version 1.1.95
Suggestion:
[*]The wizard, if it fails because of not finding cgi-bin-zm, quits without any informative messages. The user is left without knowing if at least some settings have been preserved or not.
I noticed that one has to restart the config manually after that.
[*]Also, the paths settings play interesting tricks on the user. If you forget to add /zm, then go on to cgi-bin path field and enter the correct one. then go back to server setting to add th /zm - your cgi-bin-zm path will reset to watever there was as default - which did not work for me. I had to reenter the correct cgi-bin-zm path. "me thinks" th fields should act independently after the root "/". So it does not become a cat and mouse game.
best regards
LinforPros
