root@eyeinthesky:/home/linenoise# systemctl status zoneminder.service
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2016-07-08 16:46:31 CDT; 16h ago
Process: 3523 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255)
Jul 08 16:46:21 eyeinthesky sudo[3537]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl startup
Jul 08 16:46:21 eyeinthesky sudo[3537]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Jul 08 16:46:21 eyeinthesky zmpkg.pl[3523]: Use of uninitialized value $Config{"ZM_PATH_SOCKS"} in concatenation (.) or string at /usr/bin/zmdc.pl line 72.
Jul 08 16:46:21 eyeinthesky zmpkg.pl[3523]: Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Logger.pm line 155.
Jul 08 16:46:21 eyeinthesky zmpkg.pl[3523]: Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Logger.pm line 205.
Jul 08 16:46:31 eyeinthesky sudo[3537]: pam_unix(sudo:session): session closed for user www-data
Jul 08 16:46:31 eyeinthesky systemd[1]: zoneminder.service: Control process exited, code=exited status=255
Jul 08 16:46:31 eyeinthesky systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Jul 08 16:46:31 eyeinthesky systemd[1]: zoneminder.service: Unit entered failed state.
Jul 08 16:46:31 eyeinthesky systemd[1]: zoneminder.service: Failed with result 'exit-code'.
I really haven't tried anything but some light googling to try and resolve this, but didn't turn up with anything substantial. Thanks for any help or suggestions.
Look specialy at step 10 with paths and confirm that your are correct.
These are old procedures for Ubuntu 14X. You were on the right WIKI page for a new install. Just make sure you follow the instructions as they are written and Zoneminder will work. I recommend you start with a fresh install of Ubuntu server.
Active: failed (Result: exit-code) since Sat 2016-07-09 23:49:50 CDT; 40s ago
Process: 18229 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255)
Jul 09 23:49:40 eyeinthesky sudo[18244]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl startu
Jul 09 23:49:40 eyeinthesky sudo[18244]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Jul 09 23:49:40 eyeinthesky zmpkg.pl[18229]: Use of uninitialized value $Config{"ZM_PATH_SOCKS"} in concatenation (.) or string at /usr/bin/zmdc.
Jul 09 23:49:40 eyeinthesky zmpkg.pl[18229]: Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Logger.pm l
Jul 09 23:49:50 eyeinthesky sudo[18244]: pam_unix(sudo:session): session closed for user www-data
Jul 09 23:49:50 eyeinthesky systemd[1]: zoneminder.service: Control process exited, code=exited status=255
Jul 09 23:49:50 eyeinthesky systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Jul 09 23:49:50 eyeinthesky systemd[1]: zoneminder.service: Unit entered failed state.
Jul 09 23:49:50 eyeinthesky systemd[1]: zoneminder.service: Failed with result 'exit-code'.
bb
Thank you, I did start from scratch. I just nuked the VM and am starting again.
I did not properly change AllowOverride for /var/www. I did it for the first one "/" which you would think would have accomplished the same thing, just completely insecure. Maybe an apache failsafe? It started fine this time. Thank you.
