internet <==> modem <==> router1 <==> router2 <==> server
| | v | | | v
| v laptops | | v router3 <--> cams
v phones | v router4 <--> cams
xbox v router5 <--> cams
router6 <--> cams
My problem is that I need to set up various brands of IP cameras remotely, because troubleshooting over the phone is terrible. I've set up remote access to each router and to the server. My original plan was to have them plug cameras one by one into router2 by ethernet, and I would do the rest. I figured they would get DHCP addresses, I would forward a port to the camera, then log in and set everything up. But it's not working! I can ping the camera, and check that it has port 80 open (or 81 on some models) by scanning with for example:
nmap 192.168.2.105
Anything obvious I'm missing? I can add a lot more detail about the subnets/DHCP/ports/whatever if that helps. Also open to asking other places, like maybe SuperUser or the DD-WRT forum. But I thought you guys would have more experience setting up cameras.
