...zms doesn't want to start
dadwarf
Post by dadwarf »
I have checked all the logs without seeing any errors (syslog, messages, zmwatch.log ...), my webcam works well (i try "zmu -d0 -q -v" and xawtv), all zm daemons are running (zmc, zmdc.pl, zmfilter.pl, zmaudit.pl, zmupdate.pl) but Zone Minder Console stays "stopped" when i try to start it...
what i'm doing wrong ? :(
(i'm on Slackware 10.1 with a usb webcam)
Help !
I found after all one error in zmdc.log :
'zmc -d 1' crashed at 05/06/30 15:43:26, exit status 255
is it a clue ?
lazyleopard
Post by lazyleopard »
Depending on the settings of your syslog daemon the appropriate error messages may go into other files than syslog or messages, so check to see which files in /var/log/ have been modified recently.
If you're still not getting any messages then the next thing to check is permissions. Which user:group is running which zm* process, who owns the zm* log files and log directory, etc..
It might also be worth checking the web server's logs...
Rick Hewett
