Good day
i'm new in zoneminder and i can't make it work with teh axis cameras.
INFO
Zoneminder: 1.29.0
OS Base: ubuntu 15.10
Camera: M3007-P axis
i have several more inside axis (M1054, P1343, P5532, Q6032-e, P1354-e, P5512-e, M1025) and i tried and tried with each model and i can't see anything.
inside the logs, returns me the error ofr FAILED AUTH. i don't know where, because if i try using the user and password in any browser it works.
hope you can help me.
thanks.
ZONEMINDER+AXIS
ZONEMINDER+AXIS
- Capture2.PNG (26.23 KiB) Viewed 1697 times
- Capture1.PNG (23.38 KiB) Viewed 1697 times
Re: ZONEMINDER+AXIS
Hello
Did you solved this? I'm going to purchase an M3007-PV and would be sure it will work.
Thanks,
Thanks,
