I am working my way through an automated setup of a zoneminder server. It looks like there is no API for setting up Filters. Is this correct, and are there any plans to add this in the future?
Thanks!
Zoneminder API and Filters
Re: Zoneminder API and Filters
As a somewhat horrible workaround, I guess I can use mysql to insert filters, using /usr/share/zoneminder/db/zm_create.sql as a guide.
Since I'm using Ansible, I might even just fix the version at 1.29 and include a modified zm_create.sql for use in install.
(And this would also work for adding additional users)
correct, no APIs for filters. I don't have any current plans to add APIs for filters, but anyone who can do a PR can.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
I was able to set up filters like by creating a pared down version of zm_create.sql, and loading it as an additional step (and FYI: it overwrites all existing filters, too).
The file I created has the default filter plus a delete unarchived 7day old footage filter.
And then use this with:
Or in the case of using ansible:
-- MySQL dump 10.13 Distrib 5.6.13, for Linux (i686)
-- Host: localhost Database: zm
-- Server version 5.6.13
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8 */;
/*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */;
/*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
/*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
/*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */;
-- Current Database: `zm`
USE `zm`;
-- Table structure for table `Filters`
DROP TABLE IF EXISTS `Filters`;
CREATE TABLE `Filters` (
`Name` varchar(64) NOT NULL default '',
`Query` text NOT NULL,
`AutoArchive` tinyint(3) unsigned NOT NULL default '0',
`AutoVideo` tinyint(3) unsigned NOT NULL default '0',
`AutoUpload` tinyint(3) unsigned NOT NULL default '0',
`AutoEmail` tinyint(3) unsigned NOT NULL default '0',
`AutoMessage` tinyint(3) unsigned NOT NULL default '0',
`AutoExecute` tinyint(3) unsigned NOT NULL default '0',
`AutoExecuteCmd` tinytext,
`AutoDelete` tinyint(3) unsigned NOT NULL default '0',
`Background` tinyint(1) unsigned NOT NULL default '0',
PRIMARY KEY (`Name`)
) ENGINE=InnoDB;
-- Add a sample filter to purge the oldest 100 events when the disk is 95% full
insert into Filters values ('PurgeWhenFull','{"sort_field":"Id","terms":[{"val":0,"attr":"Archived","op":"="},{"cnj":"and","val":95,"attr":"DiskPercent","op":">="}],"limit":100,"sort_asc":1}',0,0,0,0,0,0,'',1,1);
insert into Filters values ('Purge1WeekOld','{"terms":[{"attr":"Archived","op":"=","val":"0"},{"cnj":"and","attr":"DateTime","op":"<","val":"7 day ago"}],"sort_field":"DateTime","sort_asc":"1","limit":"100"}',0,0,0,0,0,0,'',1,1);
mysql -uYOURUSER -pYOURPASS < /usr/share/zoneminder/db/zm_reset_filters.sql
# Always overwrite the filters
- name: Copy mysql code for filters to host
copy:
src=files/zm_reset_filters.sql
dest=/usr/share/zoneminder/db/zm_reset_filters.sql
owner=root
group=root
mode=0644
force=yes
- name: Reset the Zoneminder filters in the database
shell: mysql -u{{ mysqlusr }} -p{{ mysqlpwd }} < /usr/share/zoneminder/db/zm_reset_filters.sql
