Using Remote ZM streams as a source for a central zm server
somepdguy
Post by somepdguy »
Hi Phil,
Is this patch in 1.21.2 (from reading the notes I think it is?)??
I have upgraded both ends and it works from the park to my home but not to the datacenter server. Same thing, a broken image or black screen
I am getting this on the server
==> /tmp/zmdc.log <==
Corrupt JPEG data: 3 extraneous bytes before marker 0xd8
Invalid JPEG file structure: two SOI markers
'zmc -m 1' crashed at 05/06/30 12:48:34, exit status 1
'zmc -m 1' starting at 05/06/30 12:48:34, pid = 20272
'zmc -m 1' started at 05/06/30 12:48:34
Corrupt JPEG data: 25 extraneous bytes before marker 0xd8
'zmc -m 1' crashed at 05/06/30 12:48:36, exit status 1
Starting pending process, zmc -m 1
'zmc -m 1' starting at 05/06/30 12:48:41, pid = 20286
'zmc -m 1' started at 05/06/30 12:48:41
Corrupt JPEG data: 32 extraneous bytes before marker 0xd8
'zmc -m 1' crashed at 05/06/30 12:48:41, exit status 1
'zmc -m 1' starting at 05/06/30 12:48:51, pid = 20296
'zmc -m 1' started at 05/06/30 12:48:51
Corrupt JPEG data: 100 extraneous bytes before marker 0xd8
'zmc -m 1' crashed at 05/06/30 12:48:53, exit status 1
'zmc -m 1' starting at 05/06/30 12:49:13, pid = 20317
'zmc -m 1' started at 05/06/30 12:49:13
Any ideas :\
Sorry about this :\
zoneminder
Site Admin
Post by zoneminder »
Have you tried the zms <-> nph-zms switch, or vice versa?
Phil
somepdguy
yes
Post by somepdguy »
yes that was one of the first things I did
Would you like/mind having ssh access to the box/es?
Pete
zoneminder
Site Admin
No problem. Just PM or mail the details to me and I'll try and have a look over the weekend.
Phil
jameswilson
Post by jameswilson »
Did this get resolved?
somepdguy
No
Post by somepdguy »
No.
jameswilson
the reason i ask is because i have had something similar if i overload the braodband. 1 4 x cams set 2 fps sometimes broken images. if i lower the bandwidth requirements its fine
James
