D-link DCS2050L Blue Screen no PTZ on ZM 1.30
linuxnutt
Post by linuxnutt »
Need a Little help,
I have installed ZM 1.30 on Mint 18 Sarah (essentially its Ubuntu 16.04 LTS ).
I'm attempting to setup a D-Link DCS5020L but keep getting BlueScreen in the camera display.
I'm following this guide to setup the monitor:
https://wiki.zoneminder.com/D-Link#DCS- ... _DCS-5025L
One issue I having is I'm not able to save my setup as described above:
Source Tab
Remote Host Name: user:pass@IP Address of Camera, I get the following error
Host must be set to a valid ip address or hostname, do not include http:// I forced to only use the IP address.
Here is my monitor configuration using
http://192.168.1.20/zm/api/controls.json
"Monitor": {
"Id": "6",
"Name": "Camera-DCS5020L-5M6",
"ServerId": "0",
"Type": "Remote",
"Function": "Modect",
"Enabled": "1",
"LinkedMonitors": "",
"Triggers": "",
"Device": "\/dev\/video0",
"Channel": "0",
"Format": "255",
"V4LMultiBuffer": false,
"V4LCapturesPerFrame": "1",
"Protocol": "http",
"Method": "simple",
"Host": "192.168.1.6",
"Port": "80",
"SubPath": "",
"Path": "\/video.cgi",
"Options": "",
"User": "",
"Pass": "",
"Width": "640",
"Height": "480",
"Colours": "3",
"Palette": "0",
"Orientation": "0",
"Deinterlacing": "0",
"RTSPDescribe": false,
"Brightness": "-1",
"Contrast": "-1",
"Hue": "-1",
"Colour": "-1",
"EventPrefix": "Event-",
"LabelFormat": "%N - %d\/%m\/%y %H:%M:%S",
"LabelX": "0",
"LabelY": "0",
"LabelSize": "1",
"ImageBufferCount": "50",
"WarmupCount": "25",
"PreEventCount": "25",
"PostEventCount": "25",
"StreamReplayBuffer": "1000",
"AlarmFrameCount": "1",
"SectionLength": "600",
"FrameSkip": "0",
"MotionFrameSkip": "0",
"AnalysisFPS": "0.00",
"AnalysisUpdateDelay": "0",
"MaxFPS": "0.00",
"AlarmMaxFPS": "0.00",
"FPSReportInterval": "1000",
"RefBlendPerc": "6",
"AlarmRefBlendPerc": "6",
"Controllable": "1",
"ControlId": "26",
"ControlDevice": "admin:H@p!2#1)@192.168.1.6",
"ControlAddress": "192.168.1.6",
"AutoStopTimeout": "0.00",
"TrackMotion": "0",
"TrackDelay": "0",
"ReturnLocation": "-1",
"ReturnDelay": "0",
"DefaultView": "Events",
"DefaultRate": "100",
"DefaultScale": "100",
"SignalCheckColour": "#0000c0",
"WebColour": "red",
"Exif": false,
"Sequence": "5"
linuxnutt
Re: D-link DCS2050L Blue Screen no PTZ on ZM 1.30
Post by linuxnutt »
Sorry, I did not finish this post and yet it submitted before I was done. Need help getting this right. So any help would be appreciated.
Here are the errors.
Date/Time
Component Server PID Level Message File Line
2016-08-12 00:28:24.755376 zmc_m6 19205 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 00:28:24.784650 zmc_m6 19205 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 00:28:24.867064 zmc_m6 19205 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 00:28:24.902000 zmc_m6 19205 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 00:28:24.967871 zmc_m6 19205 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 00:28:25.016597 zmc_m6 19205 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 00:28:25.088797 zmc_m6 19205 ERR Failed authentication: zm_remote_camera_http.cpp 741
The failed to get authentication is a problem I've checked the camera user and password and they are correct as in the post above.
linuxnutt
Post by linuxnutt »
I keep adding info as I discover it in the hopes that someone will be familiar with the problem and tell me how to fix it. I'm able to get camera images using this url:
http://192.168.1.6/video.cgi
Yet when I try to enter this on the Source Tab remote host name and/or remote host path in different ways. I still get a blue screen.
Remote host name: 192.168.1.6/video.cgi I still get this error:
Remote host path: 192.168.1.6/video.cgi
Anyone seen this yet?
mattionline
Post by mattionline »
You get the blue screen when there is a temporary connection problem or the camera solution is different with the solution you configured at the camera in zoneminder.
Do you connected the camera via wlan?
It's also possible that you have wrong zoneminder settings
My Personal Blog: https://mattionline.de
linuxnutt
Post by linuxnutt »
Thanks for the response,
I'm getting a blue screen all of the time. I'm directly connected via cable to my router and on the same network as the zoneminder
server a 192.168.1.0/24 network. No Internet connection involved.
I've followed the setup instructions here, http://zoneminder.readthedocs.io/en/lat ... untu-16-04, for a fresh PPA install of Zoneminder 1.30 on a clean install of Mint 18 (Ubuntu 16.04). I have 4 other monitors connected and running fine as far as the video connectivity is concerned. 2- Foscams FI9805P, FI9831P (PTZ still not working), FI9821W (PTZ still not working) and finally the D-Link DCS-5020L (no video and no PTZ working). I'm concerned right now with getting help in trouble shooting the Blue screen for DCS-5020L. I will worry about the PTZ issue next. I've been using ZM since 2010 I have another system running ZM 1.25 everything working fine.
Another way of asking my question is simply does anyone have a working configuration of a DCS5020L on ZM1.30. Following these instructions, https://wiki.zoneminder.com/D-Link#DCS- ... _DCS-5025L , It is not working for me.
Here is my setup:
Source Type : Remote
Remote Protocol: HTTP
Remote Method: Simple
Remote Host: 192.168.1.6 "IP address of the DCS5020L" Note I'm not able to save this according to the instructions "Remote Host Name: user:pass@IP Address of Camera" I get this error- Host must be set to a valid ip address or hostname, do not include http://.
>>>>>>>>This seems to be a bug in ZM 1.30, so if someone has experience with a work around. Please let me know! <<<<<<<<
Remote Host port:80
Remote Host Path: /video.cgi
Target Colorspace: 24 bit color
Capture width:640
Capture Height (pixels): 480
Except it's working fine here. I can enter the parameters, exactly as you've shown them, into a new monitor without any issue.
So before you scream "omg bug", let's get some real data, rather than make general statements this or that isn't working.
Start by providing screenshots of your monitor config. If it isn't accepting a particular configuration then show us a screen shot of that.
Show us the contents of your zoneminder log. We need to see the entire, unedited log contents, from the moment you start zoneminder up until you see errors appear or you see "Capturing at XXX" messages. Do NOT try to open the monitor during this test.
Assemble the full stream url by hand (e.g. http://user:pass@192.168.1.6/video.cgi), paste it into Firefox, and verify you indeed get a stream. Once you get a stream in your browser, verify the resolution is 640x480 as it has to match, exactly, what you enter into ZoneMinder.
Also, please confirm exactly what make and model camera you have. The title says DCS2050L, but you mention DCS5020L in the body of you message.
Let's talk about the PTZ control after the video works. If the script was indeed written for zoneminder 1.25, it needs to be modified to work with the latest ZoneMinder.
linuxnutt
Post by linuxnutt »
Ok first thanks for replying I appreciate the support! Love the product! Using your comments will address each in turn a step at a time. Comments in line below.
1) Start by providing screenshots of your monitor config.
My camera is a:
D-Link-
DCS5020L:
General Tab:
Source Tab:
Here is the error I get when I save the configuration:
I'm forced to remove the “admin:test123@" before saving. So I had to save just "192.168.1.6” without giving me the above error. As a result I'm gettting "Failed authentication" on the error logs
OMG its working I'm able to save it right now. While preparing these screenshots I was able to save the configuration. So now that I’m totally embarrassed here with egg on my face I of course now have images.
Computers will infuriate, and invariably, without regard discriminate, embarrass, and in general make a lier and ass out of you. Knniggett there is no explaining it except that, you of course you said, "it was working for you”, and now in putting this all together saving the screen shoots I was in fact able to save the configuration with the “admin:test123@192.168.1.6" value for Remote Host Name, and wallah - It worked I started getting images. But I’m glad I did in fact previously save the error I was getting to prove that I was getting this error. I do not know why I was suddenly able to save it. Before I tried it numerous times except to get the error. I know you are thinking the error is between the screen and the back of my seat, but I swearer it was not working.. why write this post in the first place?
Here is the ZM log it shows the errors up to saving the monitor configurations, and capture thereafter,
System Log
Updated: Fri 12th Aug, 2:45pm State: alarm Total: 1064701 Available: 1064701 Displaying: 200
Filter log - Component
Server PID Level File Line
Date/Time
2016-08-12 14:44:53.004741 zmc_m3 32467 INF Camera-FI9831P-3M3: 46000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:44:52.122271 zma_m1 7244 INF Camera-FI9805P-1M1: 444000 - Analysing at 9.26 fps zm_monitor.cpp 1287
2016-08-12 14:44:51.617865 zma_m3 7280 INF Camera-FI9831P-3M3: 1456000 - Analysing at 25.00 fps zm_monitor.cpp 1287
2016-08-12 14:44:32.201297 zma_m6 472 INF Camera-DCS5020L-5M6: 9000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:44:32.103280 zmc_m6 468 INF Camera-DCS5020L-5M6: 9000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:44:30.769449 zmc_m1 32476 INF Camera-FI9805P-1M1: 17000 - Capturing at 9.71 fps zm_monitor.cpp 3116
2016-08-12 14:44:20.035757 zmc_m5 19321 INF Camera-FI9821W-4M5: 442000 - Capturing at 8.26 fps zm_monitor.cpp 3116
2016-08-12 14:44:19.908100 zmc_m3 32467 INF Camera-FI9831P-3M3: 45000 - Capturing at 28.57 fps zm_monitor.cpp 3116
2016-08-12 14:44:11.221605 zma_m3 7280 INF Camera-FI9831P-3M3: 1455000 - Analysing at 25.00 fps zm_monitor.cpp 1287
2016-08-12 14:44:08.399738 zma_m2 7258 INF Camera-FI9805P-2M2: 478000 - Analysing at 9.80 fps zm_monitor.cpp 1287
2016-08-12 14:44:03.784242 zmc_m2 32463 INF Camera-FI9805P-2M2: 17000 - Capturing at 9.90 fps zm_monitor.cpp 3116
2016-08-12 14:43:58.929215 zma_m6 472 INF Camera-DCS5020L-5M6: 8000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:43:58.834611 zmc_m6 468 INF Camera-DCS5020L-5M6: 8000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:43:44.428293 zmc_m3 32467 INF Camera-FI9831P-3M3: 44000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:43:31.068737 zma_m3 7280 INF Camera-FI9831P-3M3: 1454000 - Analysing at 28.57 fps zm_monitor.cpp 1287
2016-08-12 14:43:25.673045 zma_m6 472 INF Camera-DCS5020L-5M6: 7000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:43:25.575617 zmc_m6 468 INF Camera-DCS5020L-5M6: 7000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:43:17.705106 zma_m5 7692 INF Camera-FI9821W-4M5: 1073000 - Analysing at 8.33 fps zm_monitor.cpp 1287
2016-08-12 14:43:11.128311 zmc_m3 32467 INF Camera-FI9831P-3M3: 43000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:43:04.433780 zma_m1 7244 INF Camera-FI9805P-1M1: 443000 - Analysing at 9.43 fps zm_monitor.cpp 1287
2016-08-12 14:42:56.802282 zma_m3 7280 INF Camera-FI9831P-3M3: 1453000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:42:52.406557 zma_m6 472 INF Camera-DCS5020L-5M6: 6000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:42:52.319134 zmc_m6 468 INF Camera-DCS5020L-5M6: 6000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:42:47.447973 zmc_m1 32476 INF Camera-FI9805P-1M1: 16000 - Capturing at 10.00 fps zm_monitor.cpp 3116
2016-08-12 14:42:37.982437 zmc_m3 32467 INF Camera-FI9831P-3M3: 42000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:42:26.385545 zma_m2 7258 INF Camera-FI9805P-2M2: 477000 - Analysing at 10.00 fps zm_monitor.cpp 1287
2016-08-12 14:42:25.625463 zms 484 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:42:22.767869 zmc_m2 32463 INF Camera-FI9805P-2M2: 16000 - Capturing at 10.10 fps zm_monitor.cpp 3116
2016-08-12 14:42:22.547985 zma_m3 7280 INF Camera-FI9831P-3M3: 1452000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:42:19.254536 zmc_m5 19321 INF Camera-FI9821W-4M5: 441000 - Capturing at 8.33 fps zm_monitor.cpp 3116
2016-08-12 14:42:19.142980 zma_m6 472 INF Camera-DCS5020L-5M6: 5000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:42:19.050467 zmc_m6 468 INF Camera-DCS5020L-5M6: 5000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:42:04.519777 zmc_m3 32467 INF Camera-FI9831P-3M3: 41000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:42:00.250267 zma_m1 7244 INF Camera-FI9805P-1M1: 442356 - Closing event 565, alarm end zm_monitor.cpp 1707
2016-08-12 14:42:00.195065 zma_m1 7244 INF Camera-FI9805P-1M1: 442356 - Left alarm state (565) - 90(39) images zm_monitor.cpp 1702
2016-08-12 14:41:58.024925 zma_m1 7244 INF Camera-FI9805P-1M1: 442331 - Gone into alert state zm_monitor.cpp 1695
2016-08-12 14:41:57.676455 zma_m1 7244 INF Camera-FI9805P-1M1: 442329 - Gone back into alarm state zm_monitor.cpp 1686
2016-08-12 14:41:57.468731 zma_m1 7244 INF Camera-FI9805P-1M1: 442328 - Gone into alert state zm_monitor.cpp 1695
2016-08-12 14:41:48.280687 zma_m3 7280 INF Camera-FI9831P-3M3: 1451000 - Analysing at 28.57 fps zm_monitor.cpp 1287
2016-08-12 14:41:48.202376 zma_m1 7244 INF Camera-FI9805P-1M1: 442291 - Opening new event 565, alarm start zm_monitor.cpp 1651
2016-08-12 14:41:48.071150 zma_m1 7244 INF Camera-FI9805P-1M1: 442291 - Gone into alarm state zm_monitor.cpp 1605
2016-08-12 14:41:45.871525 zma_m6 472 INF Camera-DCS5020L-5M6: 4000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:41:45.779319 zmc_m6 468 INF Camera-DCS5020L-5M6: 4000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:41:31.232274 zmc_m3 32467 INF Camera-FI9831P-3M3: 40000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:41:18.922200 zma_m1 7244 INF Camera-FI9805P-1M1: 442000 - Analysing at 9.62 fps zm_monitor.cpp 1287
2016-08-12 14:41:17.992776 zma_m5 7692 INF Camera-FI9821W-4M5: 1072000 - Analysing at 8.40 fps zm_monitor.cpp 1287
2016-08-12 14:41:13.482537 zma_m3 7280 INF Camera-FI9831P-3M3: 1450000 - Analysing at 27.78 fps zm_monitor.cpp 1287
2016-08-12 14:41:12.599627 zma_m6 472 INF Camera-DCS5020L-5M6: 3000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:41:12.514756 zmc_m6 468 INF Camera-DCS5020L-5M6: 3000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:41:07.525719 zmc_m1 32476 INF Camera-FI9805P-1M1: 15000 - Capturing at 10.00 fps zm_monitor.cpp 3116
2016-08-12 14:41:06.990692 web_php 27174 ERR /usr/bin/zmcontrol.pl --panstep=21 --command=moveRelRight --id=6=> /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-12 14:41:06.926320 zmcontrol 510 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-12 14:41:06.882840 zmcontrol 510 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-12 14:40:58.076117 zmc_m3 32467 INF Camera-FI9831P-3M3: 39000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:40:50.094176 zma_m1 7244 INF Camera-FI9805P-1M1: 441708 - Closing event 564, alarm end zm_monitor.cpp 1707
2016-08-12 14:40:50.031825 zma_m1 7244 INF Camera-FI9805P-1M1: 441708 - Left alarm state (564) - 84(34) images zm_monitor.cpp 1702
2016-08-12 14:40:47.158404 zma_m1 7244 INF Camera-FI9805P-1M1: 441683 - Gone into alert state zm_monitor.cpp 1695
2016-08-12 14:40:46.099049 zma_m2 7258 INF Camera-FI9805P-2M2: 476000 - Analysing at 9.90 fps zm_monitor.cpp 1287
2016-08-12 14:40:43.792946 zmc_m2 32463 INF Camera-FI9805P-2M2: 15000 - Capturing at 9.90 fps zm_monitor.cpp 3116
2016-08-12 14:40:39.364260 zma_m6 472 INF Camera-DCS5020L-5M6: 2000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:40:39.264469 zmc_m6 468 INF Camera-DCS5020L-5M6: 2000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:40:39.202123 zma_m1 7244 INF Camera-FI9805P-1M1: 441649 - Opening new event 564, alarm start zm_monitor.cpp 1651
2016-08-12 14:40:39.108718 zma_m1 7244 INF Camera-FI9805P-1M1: 441649 - Gone into alarm state zm_monitor.cpp 1605
2016-08-12 14:40:37.079631 zma_m3 7280 INF Camera-FI9831P-3M3: 1449000 - Analysing at 28.57 fps zm_monitor.cpp 1287
2016-08-12 14:40:24.627874 zmc_m3 32467 INF Camera-FI9831P-3M3: 38000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:40:19.423791 zmc_m5 19321 INF Camera-FI9821W-4M5: 440000 - Capturing at 8.33 fps zm_monitor.cpp 3116
2016-08-12 14:40:06.108916 zma_m6 472 INF Camera-DCS5020L-5M6: 1000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:40:05.990766 zmc_m6 468 INF Camera-DCS5020L-5M6: 1000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:40:02.561549 zma_m3 7280 INF Camera-FI9831P-3M3: 1448000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:39:51.318698 zmc_m3 32467 INF Camera-FI9831P-3M3: 37000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:39:34.228141 zma_m1 7244 INF Camera-FI9805P-1M1: 441000 - Analysing at 10.00 fps zm_monitor.cpp 1287
2016-08-12 14:39:33.000359 zma_m6 472 INF In mode 3/1, warming up zma.cpp 142
2016-08-12 14:39:32.814180 zmdc 7199 INF 'zma -m 6' starting at 16/08/12 14:39:32, pid = 472 zmdc.pl
2016-08-12 14:39:32.811870 zmdc 472 INF 'zma -m 6' started at 16/08/12 14:39:32 zmdc.pl
2016-08-12 14:39:32.635538 zmc_m6 468 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-12 14:39:32.406510 zmdc 468 INF 'zmc -m 6' started at 16/08/12 14:39:32 zmdc.pl
2016-08-12 14:39:32.404920 zmdc 7199 INF 'zmc -m 6' starting at 16/08/12 14:39:32, pid = 468 zmdc.pl
2016-08-12 14:39:32.104970 zmdc 7199 INF 'zmc -m 6' exited normally zmdc.pl
2016-08-12 14:39:32.048682 zmc_m6 386 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:39:32.006840 zmc_m6 386 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-08-12 14:39:31.940138 zmc_m6 386 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-08-12 14:39:31.875756 zmc_m6 386 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:39:31.779270 zmdc 7199 INF 'zmc -m 6' sending stop to pid 386 at 16/08/12 14:39:31 zmdc.pl
2016-08-12 14:39:31.508340 zmdc 7199 INF 'zma -m 6' exited normally zmdc.pl
2016-08-12 14:39:31.464158 zma_m6 389 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:39:31.421720 zmdc 7199 INF 'zma -m 6' sending stop to pid 389 at 16/08/12 14:39:31 zmdc.pl
2016-08-12 14:39:31.054710 zmdc 7199 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2016-08-12 14:39:28.602307 zma_m3 7280 INF Camera-FI9831P-3M3: 1447000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:39:27.612330 zmc_m1 32476 INF Camera-FI9805P-1M1: 14000 - Capturing at 10.00 fps zm_monitor.cpp 3116
2016-08-12 14:39:18.122196 zmc_m3 32467 INF Camera-FI9831P-3M3: 36000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:39:18.043443 zma_m5 7692 INF Camera-FI9821W-4M5: 1071000 - Analysing at 8.33 fps zm_monitor.cpp 1287
2016-08-12 14:39:05.260413 zma_m2 7258 INF Camera-FI9805P-2M2: 475000 - Analysing at 10.00 fps zm_monitor.cpp 1287
2016-08-12 14:39:02.946760 zmc_m2 32463 INF Camera-FI9805P-2M2: 14000 - Capturing at 10.10 fps zm_monitor.cpp 3116
2016-08-12 14:39:02.270410 zma_m6 389 INF Camera-DCS5020L-5M6: 1000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:39:01.629768 zmc_m6 386 INF Camera-DCS5020L-5M6: 1000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:38:54.502546 zma_m3 7280 INF Camera-FI9831P-3M3: 1446000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:38:44.712434 zmc_m3 32467 INF Camera-FI9831P-3M3: 35000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:38:29.527395 zma_m6 389 INF In mode 3/1, warming up zma.cpp 142
2016-08-12 14:38:28.482032 zma_m6 389 WAR Waiting for capture daemon zm_monitor.cpp 503
2016-08-12 14:38:28.363650 zmc_m6 386 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-12 14:38:28.322880 zmdc 389 INF 'zma -m 6' started at 16/08/12 14:38:28 zmdc.pl
2016-08-12 14:38:28.321320 zmdc 7199 INF 'zma -m 6' starting at 16/08/12 14:38:28, pid = 389 zmdc.pl
2016-08-12 14:38:28.263190 zmdc 7199 INF Starting pending process, zma -m 6 zmdc.pl
2016-08-12 14:38:28.121250 zmdc 7199 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2016-08-12 14:38:28.037650 zmdc 7199 INF 'zmc -m 6' starting at 16/08/12 14:38:28, pid = 386 zmdc.pl
2016-08-12 14:38:28.012620 zmdc 386 INF 'zmc -m 6' started at 16/08/12 14:38:28 zmdc.pl
2016-08-12 14:38:27.955941 zma_m6 383 ERR Shared data not initialised by capture daemon for monitor Camera-DCS5020L-5M6 zm_monitor.cpp 442
2016-08-12 14:38:27.905460 zmdc 7199 INF Starting pending process, zmc -m 6 zmdc.pl
2016-08-12 14:38:27.729980 zmdc 383 INF 'zma -m 6' started at 16/08/12 14:38:27 zmdc.pl
2016-08-12 14:38:27.727660 zmdc 7199 INF 'zma -m 6' starting at 16/08/12 14:38:27, pid = 383 zmdc.pl
2016-08-12 14:38:27.685450 zmdc 7199 INF 'zmc -m 6' exited normally zmdc.pl
2016-08-12 14:38:27.614349 zmc_m6 376 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:27.577013 zmc_m6 376 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-08-12 14:38:27.543587 zmc_m6 376 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-08-12 14:38:27.510173 zmc_m6 376 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:38:27.439270 zmdc 7199 INF 'zmc -m 6' sending stop to pid 376 at 16/08/12 14:38:27 zmdc.pl
2016-08-12 14:38:27.123302 zmc_m6 376 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-12 14:38:26.991570 zmwatch 7319 INF Restarting capture daemon for Camera-DCS5020L-5M6, shared data not valid zmwatch.pl
2016-08-12 14:38:26.930560 zmdc 376 INF 'zmc -m 6' started at 16/08/12 14:38:26 zmdc.pl
2016-08-12 14:38:26.928710 zmdc 7199 INF 'zmc -m 6' starting at 16/08/12 14:38:26, pid = 376 zmdc.pl
2016-08-12 14:38:26.649410 zmdc 7199 INF 'zmc -m 6' exited normally zmdc.pl
2016-08-12 14:38:26.541663 zmc_m6 22978 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:38:26.532995 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:26.464540 zmdc 7199 INF 'zmc -m 6' sending stop to pid 22978 at 16/08/12 14:38:26 zmdc.pl
2016-08-12 14:38:26.458005 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:26.420924 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:26.341004 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:26.300524 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:26.181187 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:26.142830 zmdc 7199 INF 'zma -m 6' exited normally zmdc.pl
2016-08-12 14:38:26.133532 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:26.055783 zma_m6 22982 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:38:26.016106 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.932610 zmdc 7199 INF 'zma -m 6' sending stop to pid 22982 at 16/08/12 14:38:25 zmdc.pl
2016-08-12 14:38:25.861250 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.696239 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.658440 zmdc 7199 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2016-08-12 14:38:25.653230 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.570998 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.530574 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.462339 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.428939 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.354118 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.245431 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.169724 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.069658 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.977201 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.845295 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.747931 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.701993 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.634584 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.601065 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.529378 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.490443 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.408995 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.373152 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.293295 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.250656 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.189492 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.126729 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.049631 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.008815 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.932683 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.893423 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.789660 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.717225 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.640123 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.595844 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.513625 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.476450 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.396689 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.357911 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.279736 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.196758 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.121151 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.081383 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.004175 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.965336 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.887201 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.851090 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.720237 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.689609 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.619745 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.584704 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.519451 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.479052 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.410822 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.377472 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.310528 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.278549 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.210217 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.177326 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.109928 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.077305 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.009614 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:21.977185 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:21.909323 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:21.877256 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:21.779779 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:21.726743 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
I will have to make two post to cover this one topic as I'm having issues uploading images, Please see 2 of 2 below
linuxnutt
Post by linuxnutt »
2 of 2
Sorry for the previous post it didn't turn out the way I wanted it. I think I have the hang of the interface now.
I said I was having issues getting the upload to work correctly for me anyway here is the missing Source Tab
That said, I would like to look at the PTZ not working since I now have image capture working. Here is my Control Tab.
The DCS5020L script from my server in /usr/share/perl5/ZoneMinder/Control/DCS5020L.pl is the same one listed in the workup here:
https://wiki.zoneminder.com/D-Link_DCS- ... rol_Script
If I need to modify the DCS5020L.pm perl “pm" script to work with the new ZM.. I’m not sure how I have do this.
Getting this perl script to work would be beneficial as I have 3 other PTZ Foscams FI8918W, FI9821W and FI9831P and I'd like to get their PTZ working, so I hope to apply lesson learned on this DSC5020L to them.
Appreciate the help!
I can only see the first screenshot. The others don't show. Not sure what that is about, but it probably doesn't matter now since you've got it working.
Pro Tip: set your colorspace to 32bit on all your cameras for a performance boost
PTZ scripts for all your Foscam cameras are already in ZoneMinder. I use the 9821W for my development so I know it works well with no problems. If it doesn't work for you, then that you probably aren't populating the control tab the right way. I don't have it in front of me at the moment, so I can't tell you what is should be.
Copy the control script for the DCS-5020L into the folder for all your other control scripts.
On my system, control scripts are in /usr/share/perl5/vendor_perl/ZoneMinder/Control/
Now check the syntax of the script to make sure there are no problems:
sudo perl /path/to/your/script/DCS5020L.pl
If the code checks out, then it will return with no output whatsoever. If you get a message then you need to show us that.
linuxnutt
Post by linuxnutt »
Sorry, I do not have PTZ control. Here is the output of the sudo perl /path/ to/ DCS5020L.pl file:
sudo perl /usr/share/perl5/ZoneMinder/Control/DCS5020L.pl
I do not get any errors
To associate the New DCS5020L control I followed the information given here:
https://wiki.zoneminder.com/How_to_cont ... eras_-_PTZ
and special attention to follow the steps in these headings - I hope this wiki page is correct.
How to set up ZM to recognize the script
The proper way
How to associate a camera to your new control.
To create the new DCS5020L control values I used this post:
with these settings:
PTZ Settings:
Main: Type: Remote, Protocol: DCS5020L, Name: DCS5020L, Can Wake, Can Sleep, Can Reset
Move: Can Move, Can Move Diagonally, Can Move Mapped, Can Move Relative
Pan: Can Pan, Min Pan Step 1, Max Pan Step 30
Tilt: Can Tilt, Min Tilt Step 1, Max Pan Step 30
Presets: Has Presets, Number: 24, Has Home Preset
I have compared my PTZ settings to these and they are the same. I would post screen shots except I'm not able to upload more than three files and then I see only two screen shots in the post. I have sent an email to Administrator using the "contact us" icon.
I get this error when I use my mouse to push right &gt;<br />arrow in the PTZ control link..
I get this error when I use my mouse to push right >
I hope this gives more info to determine why I'm having difficulty with the PTZ controls.
Thanks,
Steve
AKA Linuxnutt
linuxnutt
Post by linuxnutt »
Here is the zm log to go along with the monitor error display when trying to control the camera.
Error:
Log output:
System Log
Updated: Tue 16th Aug, 12:21am State: alarm Total: 1098136 Available: 1218 Displaying: 102
Date/Time
2016-08-16 00:21:17.583450 zmcontrol 30344 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-16 00:21:17.504850 zmcontrol 30344 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-16 00:20:09.090130 zmcontrol 30337 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-16 00:20:09.033830 zmcontrol 30337 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-15 23:38:14.439790 zmcontrol 29810 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-15 23:38:14.379060 zmcontrol 29810 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-15 21:48:18.065370 zmcontrol 27727 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-15 21:48:18.031400 zmcontrol 27727 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-15 17:30:01.892850 zmcontrol 24359 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-15 17:30:01.845170 zmcontrol 24359 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-15 17:19:24.846830 zmcontrol 24208 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-15 17:19:24.786980 zmcontrol 24208 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-15 17:19:12.889760 zmcontrol 24205 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-15 17:19:12.827780 zmcontrol 24205 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-15 17:14:52.860270 zmcontrol 24112 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-15 17:14:52.804060 zmcontrol 24112 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-12 01:52:55.807620 zmcontrol 21728 INF Control server 5/FI9821W_Y2k exiting at 16/08/12 01:52:55 zmcontrol.pl
2016-08-12 01:22:55.677340 zmcontrol 21728 ERR Error check failed: '500 No Host option provided' zmcontrol.pl
2016-08-12 01:22:55.642730 zmcontrol 21728 ERR Error check failed: '500 No Host option provided' zmcontrol.pl
2016-08-12 01:22:55.509010 zmcontrol 21728 ERR Error check failed: '500 No Host option provided' zmcontrol.pl
2016-08-12 01:22:54.425610 zmcontrol 21728 INF Control server 5/FI9821W_Y2k starting at 16/08/12 01:22:54 zmcontrol.pl
2016-08-12 01:22:54.228990 zmcontrol 21725 INF Starting control server 5/FI9821W_Y2k zmcontrol.pl
2016-08-12 01:22:21.221440 zmcontrol 21715 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-12 01:22:21.168350 zmcontrol 21715 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:37.075190 zmcontrol 28102 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:37.009530 zmcontrol 28102 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.761380 zmcontrol 28067 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.679530 zmcontrol 28067 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.564870 zmcontrol 28066 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.522790 zmcontrol 28069 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.492200 zmcontrol 28066 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.439180 zmcontrol 28069 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.428000 zmcontrol 28087 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.361510 zmcontrol 28087 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.288510 zmcontrol 28080 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.240990 zmcontrol 28088 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.239880 zmcontrol 28083 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.238250 zmcontrol 28089 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.236440 zmcontrol 28079 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.199300 zmcontrol 28080 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.165510 zmcontrol 28089 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.150410 zmcontrol 28088 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.054020 zmcontrol 28079 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:36.050520 zmcontrol 28071 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.049390 zmcontrol 28076 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:36.044220 zmcontrol 28083 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:35.996440 zmcontrol 28071 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:35.961720 zmcontrol 28076 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:28.726230 zmcontrol 28017 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:28.664790 zmcontrol 28017 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:28.644320 zmcontrol 28022 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:28.643740 zmcontrol 28014 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:28.561820 zmcontrol 28022 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:28.536990 zmcontrol 28014 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:28.410030 zmcontrol 28011 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:28.365730 zmcontrol 28018 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:28.338910 zmcontrol 28011 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:28.330460 zmcontrol 28012 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:28.295780 zmcontrol 28018 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:28.264080 zmcontrol 28012 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:28.201580 zmcontrol 28009 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:28.138440 zmcontrol 28009 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:27.551110 zmcontrol 28006 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:27.474090 zmcontrol 28006 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:31:20.723900 zmcontrol 27988 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:31:20.663500 zmcontrol 27988 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:26:54.941510 zmcontrol 27413 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:26:54.773440 zmcontrol 27413 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:26:04.180970 zmcontrol 27297 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:26:04.126570 zmcontrol 27297 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:25:46.848500 zmcontrol 27252 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:25:46.795470 zmcontrol 27252 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:36.321660 zmcontrol 27104 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:36.253940 zmcontrol 27104 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:03.395450 zmcontrol 27030 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:03.293760 zmcontrol 27030 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:03.257480 zmcontrol 27031 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:03.205830 zmcontrol 27016 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:03.198360 zmcontrol 27031 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:03.135450 zmcontrol 27016 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:03.123770 zmcontrol 27014 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:03.075140 zmcontrol 27007 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:03.051330 zmcontrol 27014 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:03.022460 zmcontrol 27004 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:03.002470 zmcontrol 27007 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:02.966430 zmcontrol 27004 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:02.619800 zmcontrol 27012 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:02.588690 zmcontrol 27006 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:02.571490 zmcontrol 27012 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:02.524430 zmcontrol 27006 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:02.460170 zmcontrol 26998 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:02.380180 zmcontrol 26998 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:24:02.215960 zmcontrol 27000 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:24:02.105790 zmcontrol 27000 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:23:55.821780 zmcontrol 26992 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:23:55.761660 zmcontrol 26974 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:23:55.726120 zmcontrol 26992 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:23:55.714150 zmcontrol 26978 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-11 21:23:55.691750 zmcontrol 26974 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-11 21:23:55.671540 zmcontrol 26976 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
This error means exactly what it says. ZoneMinder can't find your control script.
Make sure you:
- placed the script into the same folder as all your other scripts
- make sure the web user account has read permission to the script
- You have to name the script "DCS5020L.pm". It is case sensitive!
- In the web console, under the PTZ definition, make sure the "protocol" field says DCS5020L
For future troubleshooting, you can sometimes get better output from ZoneMinder by executing ptz commands from the command line rather than the web browser:
sudo zmcontrol.pl --panstep=22 --command=moveRight --id=6
