Can not change saved states via web after update to 1.30.0 (command line works)
emailej
Post by emailej »
After updating from 1.28 to 1.30.0 everything is working beautifully EXCEPT I can no longer change states using the web interface (zoneminder-MP opensuse 13.2 system package 1.30.0-11.1 ).  I should qualify that by saying I can change states to :"stop, start, and restart" but none of my saved states work. It does work if done on command line like
 ~>sudo zmpkg.pl outdoor_MD
Then the state change proceeds but I do get the message output at terminal:
 ~>INFO: when db is correctly installed and you just reinstalled rpm, then answer all questions with 'n'
no lockfile found, proceed anyway? [y/N]: N
I did do "zm_database_init" after the upgrade and everything seemed fine.
The only thing looking odd in zm logfile is some errors similar to the one below - but im not sure its related:
2016-08-23 17:47:53.013380 zmdc 7420 ERR 'zma -m 26' exited abnormally, exit status 255 zmdc.pl
2016-08-23 17:47:52.988887 zma_m26 7614 ERR Shared data not initialised by capture daemon for monitor Side_Gate_QC1_LR zm_monitor.cpp 442
I'm not sure where else to look so any help in the right direction would be greatly appreciated. More log file below and happy to post addition info if it helps.
Thanks!
2016-08-23 17:34:01.366200 zmwatch[6254].INF-zmwatch.pl [Watchdog pausing for 30 seconds]
2016-08-23 17:34:01.369289 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:01.384030 zmdc[6265].INF-zmdc.pl ['zmupdate.pl -c' started at 16/08/23 17:34:01]
2016-08-23 17:34:01.384090 zmdc[6016].INF-zmdc.pl ['zmupdate.pl -c' starting at 16/08/23 17:34:01, pid = 6265]
2016-08-23 17:34:01.545824 zma_m18[6131].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:01.586500 zmdc[6016].INF-zmdc.pl ['zmtelemetry.pl' starting at 16/08/23 17:34:01, pid = 6276]
2016-08-23 17:34:01.586880 zmdc[6276].INF-zmdc.pl ['zmtelemetry.pl' started at 16/08/23 17:34:01]
2016-08-23 17:34:01.848060 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:01.973276 zma_m16[6087].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:02.040111 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:02.400007 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:02.583592 zma_m18[6131].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:02.875486 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:03.017303 zma_m16[6087].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:03.067713 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:03.426343 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:03.617948 zma_m18[6131].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:03.901092 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:04.042754 zma_m16[6087].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:04.118244 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:04.451209 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:04.643094 zma_m18[6131].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:04.926287 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:05.076418 zma_m16[6087].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:05.143323 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:05.509626 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:05.668086 zma_m18[6131].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:05.951205 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:06.093109 zma_m16[6087].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:06.159987 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:06.526388 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:06.684685 zma_m18[6131].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:06.967892 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:07.109869 zma_m16[6087].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:07.176991 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:07.543303 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:07.701646 zma_m18[6131].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:07.993107 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:08.135697 zma_m16[6087].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:08.202643 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:08.569004 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:08.727286 zma_m18[6131].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:09.027471 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:09.160838 zma_m16[6087].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:09.227692 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:09.593929 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:09.762142 zma_m18[6131].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:34:10.052169 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:10.195606 zma_m16[6087].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:34:10.252583 zma_m19[6162].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:10.618911 zma_m20[6193].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:11.085876 zma_m26[6224].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:34:11.279221 zma_m19[6162].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:34:11.661674 zma_m20[6193].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:34:12.111521 zma_m26[6224].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:36:07.309722 zmc_m7[6056].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 1000 - Capturing at 7.75 fps]
2016-08-23 17:37:30.162980 zmc_m18[6115].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 1000 - Capturing at 4.74 fps]
2016-08-23 17:37:30.321895 zmc_m16[6070].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 1000 - Capturing at 4.72 fps]
2016-08-23 17:37:30.573969 zma_m18[6131].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 1000 - Analysing at 4.74 fps]
2016-08-23 17:37:30.729295 zma_m16[6087].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 1000 - Analysing at 4.72 fps]
2016-08-23 17:37:30.773414 zmc_m17[6101].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 1000 - Capturing at 4.74 fps]
2016-08-23 17:37:31.546456 zmc_m19[6147].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 1000 - Capturing at 4.72 fps]
2016-08-23 17:37:31.959813 zma_m19[6162].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 1000 - Analysing at 4.72 fps]
2016-08-23 17:37:32.021861 zmc_m20[6177].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 1000 - Capturing at 4.72 fps]
2016-08-23 17:37:32.430167 zmc_m26[6207].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 1000 - Capturing at 4.72 fps]
2016-08-23 17:37:32.451163 zma_m20[6193].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 1000 - Analysing at 4.72 fps]
2016-08-23 17:37:32.859316 zma_m26[6224].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 1000 - Analysing at 4.72 fps]
2016-08-23 17:38:16.672912 zmc_m7[6056].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 2000 - Capturing at 7.75 fps]
2016-08-23 17:40:25.483268 zmc_m7[6056].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 3000 - Capturing at 7.75 fps]
2016-08-23 17:40:50.840802 zmc_m18[6115].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 2000 - Capturing at 5.00 fps]
2016-08-23 17:40:51.030536 zmc_m16[6070].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 2000 - Capturing at 4.98 fps]
2016-08-23 17:40:51.263198 zma_m18[6131].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 2000 - Analysing at 4.98 fps]
2016-08-23 17:40:51.422374 zmc_m17[6101].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 2000 - Capturing at 4.98 fps]
2016-08-23 17:40:51.452569 zma_m16[6087].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 2000 - Analysing at 4.98 fps]
2016-08-23 17:40:52.219253 zmc_m19[6147].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 2000 - Capturing at 4.98 fps]
2016-08-23 17:40:52.629466 zma_m19[6162].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 2000 - Analysing at 4.98 fps]
2016-08-23 17:40:52.711960 zmc_m20[6177].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 2000 - Capturing at 5.00 fps]
2016-08-23 17:40:53.112269 zmc_m26[6207].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 2000 - Capturing at 4.98 fps]
2016-08-23 17:40:53.122619 zma_m20[6193].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 2000 - Analysing at 4.98 fps]
2016-08-23 17:40:53.536063 zma_m26[6224].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 2000 - Analysing at 4.98 fps]
2016-08-23 17:42:34.252497 zmc_m7[6056].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 4000 - Capturing at 7.75 fps]
2016-08-23 17:44:11.559128 zmc_m18[6115].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 3000 - Capturing at 4.98 fps]
2016-08-23 17:44:11.739411 zmc_m16[6070].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 3000 - Capturing at 5.00 fps]
2016-08-23 17:44:11.965282 zma_m18[6131].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 3000 - Analysing at 5.00 fps]
2016-08-23 17:44:12.088930 zmc_m17[6101].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 3000 - Capturing at 4.98 fps]
2016-08-23 17:44:12.162759 zma_m16[6087].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 3000 - Analysing at 4.98 fps]
2016-08-23 17:44:12.894166 zmc_m19[6147].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 3000 - Capturing at 5.00 fps]
2016-08-23 17:44:13.308445 zma_m19[6162].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 3000 - Analysing at 4.98 fps]
2016-08-23 17:44:13.418202 zmc_m20[6177].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 3000 - Capturing at 4.98 fps]
2016-08-23 17:44:13.819960 zmc_m26[6207].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 3000 - Capturing at 5.00 fps]
2016-08-23 17:44:13.847669 zma_m20[6193].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 3000 - Analysing at 5.00 fps]
2016-08-23 17:44:14.253156 zma_m26[6224].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 3000 - Analysing at 4.98 fps]
2016-08-23 17:44:43.855492 zmc_m7[6056].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 5000 - Capturing at 7.75 fps]
2016-08-23 17:46:30.965720 zmsystemctl[7176].INF-zmsystemctl.pl [Redirecting command through systemctl]
2016-08-23 17:46:31.153530 zmpkg[7183].INF-zmpkg.pl [Sanity checking States table...]
2016-08-23 17:46:31.235660 zmpkg[7183].INF-zmpkg.pl [Command: stop]
2016-08-23 17:46:31.594170 zmdc[6016].INF-zmdc.pl ['zma -m 16' sending stop to pid 6087 at 16/08/23 17:46:31]
2016-08-23 17:46:31.625675 zma_m16[6087].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:31.625740 zmdc[6016].INF-zmdc.pl ['zmc -m 26' sending stop to pid 6207 at 16/08/23 17:46:31]
2016-08-23 17:46:31.684410 zmdc[6016].INF-zmdc.pl ['zma -m 16' exited normally]
2016-08-23 17:46:31.709588 zmc_m26[6207].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:31.709640 zmdc[6016].INF-zmdc.pl ['zmc -m 17' sending stop to pid 6101 at 16/08/23 17:46:31]
2016-08-23 17:46:31.759771 zmc_m17[6101].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:31.759810 zmdc[6016].INF-zmdc.pl ['zmc -m 7' sending stop to pid 6056 at 16/08/23 17:46:31]
2016-08-23 17:46:31.810310 zmdc[6016].INF-zmdc.pl ['zmc -m 26' exited normally]
2016-08-23 17:46:31.835400 zmdc[6016].INF-zmdc.pl ['zmc -m 17' exited normally]
2016-08-23 17:46:31.860655 zmc_m7[6056].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:31.860710 zmdc[6016].INF-zmdc.pl ['zmfilter.pl' sending stop to pid 6228 at 16/08/23 17:46:31]
2016-08-23 17:46:31.885774 zmc_m7[6056].ERR-zm_remote_camera_http.cpp/175 [Select error: Interrupted system call]
2016-08-23 17:46:31.911020 zmdc[6016].INF-zmdc.pl ['zma -m 18' sending stop to pid 6131 at 16/08/23 17:46:31]
2016-08-23 17:46:31.936149 zmc_m7[6056].ERR-zm_remote_camera_http.cpp/451 [Unable to extract subheader data]
2016-08-23 17:46:31.961480 zmdc[6016].INF-zmdc.pl ['zmfilter.pl' exited, signal 14]
2016-08-23 17:46:31.986529 zmc_m7[6056].ERR-zm_remote_camera_http.cpp/1141 [Unable to get response, disconnecting]
2016-08-23 17:46:32.011874 zma_m18[6131].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:32.012020 zmdc[6016].INF-zmdc.pl ['zma -m 20' sending stop to pid 6193 at 16/08/23 17:46:32]
2016-08-23 17:46:32.070650 zmdc[6016].INF-zmdc.pl ['zmc -m 7' exited normally]
2016-08-23 17:46:32.095840 zmdc[6016].INF-zmdc.pl ['zma -m 18' exited normally]
2016-08-23 17:46:32.121731 zma_m20[6193].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:32.121820 zmdc[6016].INF-zmdc.pl ['zmaudit.pl -c' sending stop to pid 6240 at 16/08/23 17:46:32]
2016-08-23 17:46:32.155380 zmdc[6016].INF-zmdc.pl ['zma -m 20' exited normally]
2016-08-23 17:46:32.172360 zmdc[6016].INF-zmdc.pl ['zmc -m 20' sending stop to pid 6177 at 16/08/23 17:46:32]
2016-08-23 17:46:32.189260 zmdc[6016].INF-zmdc.pl ['zmaudit.pl -c' exited, signal 14]
2016-08-23 17:46:32.206042 zmc_m20[6177].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:32.206140 zmdc[6016].INF-zmdc.pl ['zmc -m 16' sending stop to pid 6070 at 16/08/23 17:46:32]
2016-08-23 17:46:32.239708 zmc_m16[6070].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:32.239740 zmdc[6016].INF-zmdc.pl ['zmc -m 19' sending stop to pid 6147 at 16/08/23 17:46:32]
2016-08-23 17:46:32.273560 zmdc[6016].INF-zmdc.pl ['zmc -m 20' exited normally]
2016-08-23 17:46:32.290377 zmc_m19[6147].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:32.290480 zmdc[6016].INF-zmdc.pl ['zmwatch.pl' sending stop to pid 6254 at 16/08/23 17:46:32]
2016-08-23 17:46:32.324050 zmdc[6016].INF-zmdc.pl ['zmc -m 16' exited normally]
2016-08-23 17:46:32.349310 zmdc[6016].INF-zmdc.pl ['zmc -m 19' exited normally]
2016-08-23 17:46:32.374560 zmdc[6016].INF-zmdc.pl ['zma -m 19' sending stop to pid 6162 at 16/08/23 17:46:32]
2016-08-23 17:46:32.407990 zmdc[6016].INF-zmdc.pl ['zmwatch.pl' exited, signal 14]
2016-08-23 17:46:32.433143 zma_m19[6162].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:32.433220 zmdc[6016].INF-zmdc.pl ['zma -m 26' sending stop to pid 6224 at 16/08/23 17:46:32]
2016-08-23 17:46:32.483560 zmdc[6016].INF-zmdc.pl ['zma -m 19' exited normally]
2016-08-23 17:46:32.508766 zma_m26[6224].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:32.508850 zmdc[6016].INF-zmdc.pl ['zmc -m 18' sending stop to pid 6115 at 16/08/23 17:46:32]
2016-08-23 17:46:32.559070 zmdc[6016].INF-zmdc.pl ['zma -m 26' exited normally]
2016-08-23 17:46:32.584313 zmc_m18[6115].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-08-23 17:46:32.584360 zmdc[6016].INF-zmdc.pl ['zmupdate.pl -c' sending stop to pid 6265 at 16/08/23 17:46:32]
2016-08-23 17:46:32.634640 zmdc[6016].INF-zmdc.pl ['zmtelemetry.pl' sending stop to pid 6276 at 16/08/23 17:46:32]
2016-08-23 17:46:32.659850 zmdc[6016].INF-zmdc.pl ['zmc -m 18' exited normally]
2016-08-23 17:46:32.685150 zmdc[6016].INF-zmdc.pl ['zmupdate.pl -c' exited, signal 14]
2016-08-23 17:46:32.715140 zmdc[6016].INF-zmdc.pl ['zmtelemetry.pl' exited, signal 14]
2016-08-23 17:46:42.905060 zmdc[6016].INF-zmdc.pl [Server shutdown at 16/08/23 17:46:42]
2016-08-23 17:46:55.510479 web_php[2028].INF-zm/includes/functions.php/53 [Login successful for user "admin"]
2016-08-23 17:47:46.556510 zmsystemctl[7382].INF-zmsystemctl.pl [Redirecting command through systemctl]
2016-08-23 17:47:46.752700 zmpkg[7389].INF-zmpkg.pl [Sanity checking States table...]
2016-08-23 17:47:46.775580 zmpkg[7389].INF-zmpkg.pl [Command: start]
2016-08-23 17:47:47.211410 zmdc[7420].INF-zmdc.pl [Server starting at 16/08/23 17:47:47]
2016-08-23 17:47:50.217750 zmpkg[7389].INF-zmpkg.pl [Single server configuration detected. Starting up services.]
2016-08-23 17:47:50.392810 zmdc[7420].INF-zmdc.pl ['zmc -m 7' starting at 16/08/23 17:47:50, pid = 7450]
2016-08-23 17:47:50.392820 zmdc[7450].INF-zmdc.pl ['zmc -m 7' started at 16/08/23 17:47:50]
2016-08-23 17:47:50.478460 zmdc[7420].ERR-zmdc.pl ['zmc -m 7' exited abnormally, exit status 255]
2016-08-23 17:47:50.502600 zmdc[7420].INF-zmdc.pl [Starting pending process, zmc -m 7]
2016-08-23 17:47:50.531250 zmdc[7420].INF-zmdc.pl ['zmc -m 7' starting at 16/08/23 17:47:50, pid = 7458]
2016-08-23 17:47:50.531350 zmdc[7458].INF-zmdc.pl ['zmc -m 7' started at 16/08/23 17:47:50]
2016-08-23 17:47:50.603850 zmdc[7420].INF-zmdc.pl ['zmc -m 16' starting at 16/08/23 17:47:50, pid = 7463]
2016-08-23 17:47:50.604020 zmdc[7463].INF-zmdc.pl ['zmc -m 16' started at 16/08/23 17:47:50]
2016-08-23 17:47:50.662637 zmc_m7[7458].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-08-23 17:47:50.685970 zmdc[7420].ERR-zmdc.pl ['zmc -m 16' exited abnormally, exit status 255]
2016-08-23 17:47:50.762510 zmdc[7420].INF-zmdc.pl [Starting pending process, zmc -m 16]
2016-08-23 17:47:50.851710 zmdc[7420].INF-zmdc.pl ['zmc -m 16' starting at 16/08/23 17:47:50, pid = 7475]
2016-08-23 17:47:50.851720 zmdc[7475].INF-zmdc.pl ['zmc -m 16' started at 16/08/23 17:47:50]
2016-08-23 17:47:50.876260 zmdc[7420].INF-zmdc.pl ['zma -m 16' starting at 16/08/23 17:47:50, pid = 7478]
2016-08-23 17:47:50.876610 zmdc[7478].INF-zmdc.pl ['zma -m 16' started at 16/08/23 17:47:50]
2016-08-23 17:47:50.939101 zma_m16[7478].ERR-zm_monitor.cpp/442 [Shared data not initialised by capture daemon for monitor Back_Door1_QC2_LR]
2016-08-23 17:47:50.969860 zmdc[7420].ERR-zmdc.pl ['zma -m 16' exited abnormally, exit status 255]
2016-08-23 17:47:50.989420 zmdc[7420].INF-zmdc.pl [Starting pending process, zma -m 16]
2016-08-23 17:47:51.019760 zmdc[7420].INF-zmdc.pl ['zma -m 16' starting at 16/08/23 17:47:51, pid = 7489]
2016-08-23 17:47:51.019790 zmdc[7489].INF-zmdc.pl ['zma -m 16' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.049732 zmc_m16[7475].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-08-23 17:47:51.067740 zmdc[7420].INF-zmdc.pl ['zmc -m 17' starting at 16/08/23 17:47:51, pid = 7493]
2016-08-23 17:47:51.068150 zmdc[7493].INF-zmdc.pl ['zmc -m 17' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.098442 zmc_m16[7475].INF-zm_ffmpeg_camera.cpp/104 [Priming capture from rtsp://******:######@192.168.10.13/cam/realmonitor?channel=2&subtype=1]
2016-08-23 17:47:51.117943 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:51.123523 zmc_m16[7475].WAR-zm_ffmpeg_camera.cpp/267 [Unable to parse ffmpeg option 0 '', expecting key=value]
2016-08-23 17:47:51.131790 zmdc[7420].ERR-zmdc.pl ['zmc -m 17' exited abnormally, exit status 255]
2016-08-23 17:47:51.174020 zmdc[7420].INF-zmdc.pl [Starting pending process, zmc -m 17]
2016-08-23 17:47:51.202760 zmdc[7420].INF-zmdc.pl ['zmc -m 17' starting at 16/08/23 17:47:51, pid = 7504]
2016-08-23 17:47:51.202790 zmdc[7504].INF-zmdc.pl ['zmc -m 17' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.247990 zmdc[7508].INF-zmdc.pl ['zmc -m 18' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.248590 zmdc[7420].INF-zmdc.pl ['zmc -m 18' starting at 16/08/23 17:47:51, pid = 7508]
2016-08-23 17:47:51.321630 zmdc[7420].ERR-zmdc.pl ['zmc -m 18' exited abnormally, exit status 255]
2016-08-23 17:47:51.349980 zmdc[7420].INF-zmdc.pl [Starting pending process, zmc -m 18]
2016-08-23 17:47:51.380230 zmdc[7420].INF-zmdc.pl ['zmc -m 18' starting at 16/08/23 17:47:51, pid = 7518]
2016-08-23 17:47:51.380270 zmdc[7518].INF-zmdc.pl ['zmc -m 18' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.406011 zmc_m17[7504].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-08-23 17:47:51.434013 zmc_m17[7504].INF-zm_ffmpeg_camera.cpp/104 [Priming capture from rtsp://******:######@192.168.10.13/cam/realmonitor?channel=3&subtype=1]
2016-08-23 17:47:51.456400 zmdc[7420].INF-zmdc.pl ['zma -m 18' starting at 16/08/23 17:47:51, pid = 7523]
2016-08-23 17:47:51.456690 zmdc[7523].INF-zmdc.pl ['zma -m 18' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.459072 zmc_m17[7504].WAR-zm_ffmpeg_camera.cpp/267 [Unable to parse ffmpeg option 0 '', expecting key=value]
2016-08-23 17:47:51.519193 zma_m18[7523].ERR-zm_monitor.cpp/442 [Shared data not initialised by capture daemon for monitor Front_Window_QC4_LR]
2016-08-23 17:47:51.547490 zmdc[7420].ERR-zmdc.pl ['zma -m 18' exited abnormally, exit status 255]
2016-08-23 17:47:51.568530 zmdc[7420].INF-zmdc.pl [Starting pending process, zma -m 18]
2016-08-23 17:47:51.590018 zmc_m18[7518].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-08-23 17:47:51.590290 zmdc[7420].INF-zmdc.pl ['zma -m 18' starting at 16/08/23 17:47:51, pid = 7535]
2016-08-23 17:47:51.590330 zmdc[7535].INF-zmdc.pl ['zma -m 18' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.602137 zmc_m18[7518].INF-zm_ffmpeg_camera.cpp/104 [Priming capture from rtsp://******:######1@192.168.10.13/cam/realmonitor?channel=4&subtype=1]
2016-08-23 17:47:51.644154 zmc_m18[7518].WAR-zm_ffmpeg_camera.cpp/267 [Unable to parse ffmpeg option 0 '', expecting key=value]
2016-08-23 17:47:51.644320 zmdc[7420].INF-zmdc.pl ['zmc -m 19' starting at 16/08/23 17:47:51, pid = 7539]
2016-08-23 17:47:51.644330 zmdc[7539].INF-zmdc.pl ['zmc -m 19' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.657137 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:51.713950 zmdc[7420].ERR-zmdc.pl ['zmc -m 19' exited abnormally, exit status 255]
2016-08-23 17:47:51.728850 zmdc[7420].INF-zmdc.pl [Starting pending process, zmc -m 19]
2016-08-23 17:47:51.748490 zmdc[7420].INF-zmdc.pl ['zmc -m 19' starting at 16/08/23 17:47:51, pid = 7549]
2016-08-23 17:47:51.749710 zmdc[7549].INF-zmdc.pl ['zmc -m 19' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.835530 zmdc[7420].INF-zmdc.pl ['zma -m 19' starting at 16/08/23 17:47:51, pid = 7556]
2016-08-23 17:47:51.835690 zmdc[7556].INF-zmdc.pl ['zma -m 19' started at 16/08/23 17:47:51]
2016-08-23 17:47:51.895668 zma_m19[7556].ERR-zm_monitor.cpp/442 [Shared data not initialised by capture daemon for monitor BackDoor_Pool_QC5_LR]
2016-08-23 17:47:51.925160 zmdc[7420].ERR-zmdc.pl ['zma -m 19' exited abnormally, exit status 255]
2016-08-23 17:47:51.946730 zmdc[7420].INF-zmdc.pl [Starting pending process, zma -m 19]
2016-08-23 17:47:51.956450 zmc_m19[7549].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-08-23 17:47:51.975280 zmdc[7420].INF-zmdc.pl ['zma -m 19' starting at 16/08/23 17:47:51, pid = 7564]
2016-08-23 17:47:51.975450 zmdc[7564].INF-zmdc.pl ['zma -m 19' started at 16/08/23 17:47:51]
2016-08-23 17:47:52.007488 zmc_m19[7549].INF-zm_ffmpeg_camera.cpp/104 [Priming capture from rtsp://******:######@192.168.10.13/cam/realmonitor?channel=5&subtype=1]
2016-08-23 17:47:52.060900 zmdc[7420].INF-zmdc.pl ['zmc -m 20' starting at 16/08/23 17:47:52, pid = 7569]
2016-08-23 17:47:52.060910 zmdc[7569].INF-zmdc.pl ['zmc -m 20' started at 16/08/23 17:47:52]
2016-08-23 17:47:52.089076 zmc_m19[7549].WAR-zm_ffmpeg_camera.cpp/267 [Unable to parse ffmpeg option 0 '', expecting key=value]
2016-08-23 17:47:52.094736 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:52.148774 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:52.154060 zmdc[7420].ERR-zmdc.pl ['zmc -m 20' exited abnormally, exit status 255]
2016-08-23 17:47:52.198260 zmdc[7420].INF-zmdc.pl [Starting pending process, zmc -m 20]
2016-08-23 17:47:52.226780 zmdc[7420].INF-zmdc.pl ['zmc -m 20' starting at 16/08/23 17:47:52, pid = 7580]
2016-08-23 17:47:52.227760 zmdc[7580].INF-zmdc.pl ['zmc -m 20' started at 16/08/23 17:47:52]
2016-08-23 17:47:52.272270 zmdc[7584].INF-zmdc.pl ['zma -m 20' started at 16/08/23 17:47:52]
2016-08-23 17:47:52.272270 zmdc[7420].INF-zmdc.pl ['zma -m 20' starting at 16/08/23 17:47:52, pid = 7584]
2016-08-23 17:47:52.367198 zma_m20[7584].ERR-zm_monitor.cpp/442 [Shared data not initialised by capture daemon for monitor Front_Door_QC6_LR]
2016-08-23 17:47:52.422619 zmc_m20[7580].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-08-23 17:47:52.462260 zmdc[7420].ERR-zmdc.pl ['zma -m 20' exited abnormally, exit status 255]
2016-08-23 17:47:52.482690 zmc_m20[7580].INF-zm_ffmpeg_camera.cpp/104 [Priming capture from rtsp://******:#####1@192.168.10.13/cam/realmonitor?channel=6&subtype=1]
2016-08-23 17:47:52.507980 zmdc[7420].INF-zmdc.pl [Starting pending process, zma -m 20]
2016-08-23 17:47:52.541420 zmc_m20[7580].WAR-zm_ffmpeg_camera.cpp/267 [Unable to parse ffmpeg option 0 '', expecting key=value]
2016-08-23 17:47:52.571130 zmdc[7420].INF-zmdc.pl ['zma -m 20' starting at 16/08/23 17:47:52, pid = 7596]
2016-08-23 17:47:52.571240 zmdc[7596].INF-zmdc.pl ['zma -m 20' started at 16/08/23 17:47:52]
2016-08-23 17:47:52.613590 zmdc[7420].INF-zmdc.pl ['zmc -m 26' starting at 16/08/23 17:47:52, pid = 7599]
2016-08-23 17:47:52.613630 zmdc[7599].INF-zmdc.pl ['zmc -m 26' started at 16/08/23 17:47:52]
2016-08-23 17:47:52.650454 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:52.678205 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:52.747540 zmdc[7420].ERR-zmdc.pl ['zmc -m 26' exited abnormally, exit status 255]
2016-08-23 17:47:52.861300 zmdc[7420].INF-zmdc.pl [Starting pending process, zmc -m 26]
2016-08-23 17:47:52.889370 zmdc[7420].INF-zmdc.pl ['zmc -m 26' starting at 16/08/23 17:47:52, pid = 7611]
2016-08-23 17:47:52.889470 zmdc[7611].INF-zmdc.pl ['zmc -m 26' started at 16/08/23 17:47:52]
2016-08-23 17:47:52.914860 zmdc[7420].INF-zmdc.pl ['zma -m 26' starting at 16/08/23 17:47:52, pid = 7614]
2016-08-23 17:47:52.914870 zmdc[7614].INF-zmdc.pl ['zma -m 26' started at 16/08/23 17:47:52]
2016-08-23 17:47:52.988887 zma_m26[7614].ERR-zm_monitor.cpp/442 [Shared data not initialised by capture daemon for monitor Side_Gate_QC1_LR]
2016-08-23 17:47:53.013380 zmdc[7420].ERR-zmdc.pl ['zma -m 26' exited abnormally, exit status 255]
2016-08-23 17:47:53.036280 zmdc[7420].INF-zmdc.pl [Starting pending process, zma -m 26]
2016-08-23 17:47:53.075000 zmdc[7420].INF-zmdc.pl ['zma -m 26' starting at 16/08/23 17:47:53, pid = 7625]
2016-08-23 17:47:53.075010 zmdc[7625].INF-zmdc.pl ['zma -m 26' started at 16/08/23 17:47:53]
2016-08-23 17:47:53.086126 zmc_m26[7611].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-08-23 17:47:53.107490 zmdc[7420].INF-zmdc.pl ['zmfilter.pl' starting at 16/08/23 17:47:53, pid = 7629]
2016-08-23 17:47:53.108420 zmdc[7629].INF-zmdc.pl ['zmfilter.pl' started at 16/08/23 17:47:53]
2016-08-23 17:47:53.136712 zmc_m26[7611].INF-zm_ffmpeg_camera.cpp/104 [Priming capture from rtsp://******:#####1@192.168.10.13/cam/realmonitor?channel=1&subtype=1]
2016-08-23 17:47:53.139427 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:53.173035 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:53.178981 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:53.203590 zmc_m26[7611].WAR-zm_ffmpeg_camera.cpp/267 [Unable to parse ffmpeg option 0 '', expecting key=value]
2016-08-23 17:47:53.312970 zmdc[7420].INF-zmdc.pl ['zmaudit.pl -c' starting at 16/08/23 17:47:53, pid = 7641]
2016-08-23 17:47:53.313230 zmdc[7641].INF-zmdc.pl ['zmaudit.pl -c' started at 16/08/23 17:47:53]
2016-08-23 17:47:53.413360 zmfilter[7629].INF-zmfilter.pl [Scanning for events]
2016-08-23 17:47:53.511670 zmdc[7420].INF-zmdc.pl ['zmwatch.pl' starting at 16/08/23 17:47:53, pid = 7655]
2016-08-23 17:47:53.511680 zmdc[7655].INF-zmdc.pl ['zmwatch.pl' started at 16/08/23 17:47:53]
2016-08-23 17:47:53.689740 zmwatch[7655].INF-zmwatch.pl [Watchdog starting]
2016-08-23 17:47:53.713580 zmwatch[7655].INF-zmwatch.pl [Watchdog pausing for 30 seconds]
2016-08-23 17:47:53.713770 zmdc[7420].INF-zmdc.pl ['zmupdate.pl -c' starting at 16/08/23 17:47:53, pid = 7667]
2016-08-23 17:47:53.713780 zmdc[7667].INF-zmdc.pl ['zmupdate.pl -c' started at 16/08/23 17:47:53]
2016-08-23 17:47:53.775746 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:53.775838 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:53.928820 zmdc[7678].INF-zmdc.pl ['zmtelemetry.pl' started at 16/08/23 17:47:53]
2016-08-23 17:47:53.929110 zmdc[7420].INF-zmdc.pl ['zmtelemetry.pl' starting at 16/08/23 17:47:53, pid = 7678]
2016-08-23 17:47:54.203611 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:54.228932 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:54.228986 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:54.805561 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:54.830926 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:55.256124 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:55.272790 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:55.272812 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:55.822611 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:55.847790 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:56.297474 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:56.331145 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:56.331175 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:56.847815 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:56.873058 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:57.322827 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:57.364679 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:57.392773 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:57.872822 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:57.897951 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:58.347701 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:58.389636 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:58.414881 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:58.897751 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:58.923002 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:59.372702 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:59.414523 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:59.431455 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:59.914472 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:47:59.939691 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:00.389480 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:00.431278 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:00.448263 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:00.931037 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:00.956247 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:01.423125 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:01.456897 zma_m16[7489].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:01.481905 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:01.956412 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:01.981498 zma_m18[7535].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:02.447921 zma_m19[7564].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:02.490905 zma_m16[7489].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:48:02.506748 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:02.981279 zma_m20[7596].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:03.047159 zma_m18[7535].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:48:03.489143 zma_m19[7564].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:48:03.539728 zma_m26[7625].WAR-zm_monitor.cpp/503 [Waiting for capture daemon]
2016-08-23 17:48:04.017462 zma_m20[7596].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:48:04.565807 zma_m26[7625].INF-zma.cpp/142 [In mode 3/1, warming up]
2016-08-23 17:49:59.540976 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 1000 - Capturing at 7.75 fps]
2016-08-23 17:51:22.238958 zmc_m16[7475].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 1000 - Capturing at 4.74 fps]
2016-08-23 17:51:22.481345 zmc_m17[7504].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 1000 - Capturing at 4.74 fps]
2016-08-23 17:51:22.666588 zma_m16[7489].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 1000 - Analysing at 4.74 fps]
2016-08-23 17:51:22.724967 zmc_m18[7518].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 1000 - Capturing at 4.74 fps]
2016-08-23 17:51:23.039526 zmc_m19[7549].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 1000 - Capturing at 4.72 fps]
2016-08-23 17:51:23.135796 zma_m18[7535].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 1000 - Analysing at 4.72 fps]
2016-08-23 17:51:23.465761 zma_m19[7564].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 1000 - Analysing at 4.74 fps]
2016-08-23 17:51:23.526289 zmc_m20[7580].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 1000 - Capturing at 4.74 fps]
2016-08-23 17:51:23.937235 zma_m20[7596].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 1000 - Analysing at 4.74 fps]
2016-08-23 17:51:24.330908 zmc_m26[7611].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 1000 - Capturing at 4.74 fps]
2016-08-23 17:51:24.738740 zma_m26[7625].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 1000 - Analysing at 4.74 fps]
2016-08-23 17:52:08.453560 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 2000 - Capturing at 7.75 fps]
2016-08-23 17:54:18.045151 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 3000 - Capturing at 7.69 fps]
2016-08-23 17:54:43.768913 zmc_m16[7475].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 2000 - Capturing at 4.98 fps]
2016-08-23 17:54:43.942154 zmc_m17[7504].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 2000 - Capturing at 4.98 fps]
2016-08-23 17:54:44.200655 zma_m16[7489].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 2000 - Analysing at 4.95 fps]
2016-08-23 17:54:44.247543 zmc_m18[7518].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 2000 - Capturing at 4.95 fps]
2016-08-23 17:54:44.537630 zmc_m19[7549].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 2000 - Capturing at 4.98 fps]
2016-08-23 17:54:44.654073 zma_m18[7535].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 2000 - Analysing at 4.98 fps]
2016-08-23 17:54:44.960017 zma_m19[7564].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 2000 - Analysing at 4.98 fps]
2016-08-23 17:54:45.050722 zmc_m20[7580].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 2000 - Capturing at 4.95 fps]
2016-08-23 17:54:45.484365 zma_m20[7596].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 2000 - Analysing at 4.95 fps]
2016-08-23 17:54:45.856298 zmc_m26[7611].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 2000 - Capturing at 4.98 fps]
2016-08-23 17:54:46.281295 zma_m26[7625].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 2000 - Analysing at 4.95 fps]
2016-08-23 17:56:26.841927 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 4000 - Capturing at 7.81 fps]
2016-08-23 17:58:04.474355 zmc_m16[7475].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 3000 - Capturing at 4.98 fps]
2016-08-23 17:58:04.620416 zmc_m17[7504].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 3000 - Capturing at 4.98 fps]
2016-08-23 17:58:04.894801 zma_m16[7489].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 3000 - Analysing at 5.00 fps]
2016-08-23 17:58:04.957895 zmc_m18[7518].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 3000 - Capturing at 5.00 fps]
2016-08-23 17:58:05.217180 zmc_m19[7549].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 3000 - Capturing at 4.98 fps]
2016-08-23 17:58:05.382541 zma_m18[7535].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 3000 - Analysing at 4.98 fps]
2016-08-23 17:58:05.634344 zma_m19[7564].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 3000 - Analysing at 4.98 fps]
2016-08-23 17:58:05.758557 zmc_m20[7580].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 3000 - Capturing at 5.00 fps]
2016-08-23 17:58:06.192163 zma_m20[7596].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 3000 - Analysing at 4.98 fps]
2016-08-23 17:58:06.560871 zmc_m26[7611].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 3000 - Capturing at 4.98 fps]
2016-08-23 17:58:06.970873 zma_m26[7625].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 3000 - Analysing at 5.00 fps]
2016-08-23 17:58:35.776999 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 5000 - Capturing at 7.75 fps]
2016-08-23 18:00:44.559709 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 6000 - Capturing at 7.75 fps]
2016-08-23 18:01:26.267431 zmc_m16[7475].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 4000 - Capturing at 4.95 fps]
2016-08-23 18:01:26.383499 zmc_m17[7504].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 4000 - Capturing at 4.95 fps]
2016-08-23 18:01:26.682632 zma_m16[7489].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 4000 - Analysing at 4.95 fps]
2016-08-23 18:01:26.751840 zmc_m18[7518].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 4000 - Capturing at 4.95 fps]
2016-08-23 18:01:26.982974 zmc_m19[7549].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 4000 - Capturing at 4.98 fps]
2016-08-23 18:01:27.159456 zma_m18[7535].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 4000 - Analysing at 4.95 fps]
2016-08-23 18:01:27.398983 zma_m19[7564].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 4000 - Analysing at 4.95 fps]
2016-08-23 18:01:27.556832 zmc_m20[7580].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 4000 - Capturing at 4.95 fps]
2016-08-23 18:01:27.983280 zma_m20[7596].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 4000 - Analysing at 4.98 fps]
2016-08-23 18:01:28.356016 zmc_m26[7611].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 4000 - Capturing at 4.95 fps]
2016-08-23 18:01:28.782314 zma_m26[7625].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 4000 - Analysing at 4.95 fps]
2016-08-23 18:02:54.431789 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 7000 - Capturing at 7.69 fps]
2016-08-23 18:02:55.482930 zmaudit[7641].INF-zmaudit.pl [Deleted 182 log table entries by time]
2016-08-23 18:04:07.311212 web_js[2026].ERR-?view=log [Export request failed: 500 / Internal Server Error - exportFail()]
2016-08-23 18:04:46.976387 zmc_m16[7475].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 5000 - Capturing at 5.00 fps]
2016-08-23 18:04:47.039399 zmc_m17[7504].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 5000 - Capturing at 4.98 fps]
2016-08-23 18:04:47.399496 zma_m16[7489].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 5000 - Analysing at 4.98 fps]
2016-08-23 18:04:47.448111 zmc_m18[7518].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 5000 - Capturing at 4.98 fps]
2016-08-23 18:04:47.641515 zmc_m19[7549].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 5000 - Capturing at 4.98 fps]
2016-08-23 18:04:47.883288 zma_m18[7535].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 5000 - Analysing at 5.00 fps]
2016-08-23 18:04:48.069199 zma_m19[7564].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 5000 - Analysing at 4.98 fps]
2016-08-23 18:04:48.254585 zmc_m20[7580].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 5000 - Capturing at 4.98 fps]
2016-08-23 18:04:48.691285 zma_m20[7596].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 5000 - Analysing at 4.98 fps]
2016-08-23 18:04:49.058063 zmc_m26[7611].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 5000 - Capturing at 4.98 fps]
2016-08-23 18:04:49.479794 zma_m26[7625].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 5000 - Analysing at 4.98 fps]
2016-08-23 18:05:03.231471 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 8000 - Capturing at 7.75 fps]
2016-08-23 18:06:54.515550 web_js[5394].ERR-?view=log [Export request failed: 500 / Internal Server Error - exportFail()]
2016-08-23 18:06:57.664824 web_js[8933].ERR-?view=log [Export request failed: 500 / Internal Server Error - exportFail()]
2016-08-23 18:07:12.946640 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 9000 - Capturing at 7.75 fps]
2016-08-23 18:08:08.473665 zmc_m16[7475].INF-zm_monitor.cpp/3116 [Back_Door1_QC2_LR: 6000 - Capturing at 4.95 fps]
2016-08-23 18:08:08.514982 zmc_m17[7504].INF-zm_monitor.cpp/3116 [Garage_QC3_LR: 6000 - Capturing at 4.98 fps]
2016-08-23 18:08:08.903483 zma_m16[7489].INF-zm_monitor.cpp/1287 [Back_Door1_QC2_LR: 6000 - Analysing at 4.98 fps]
2016-08-23 18:08:08.929670 zmc_m18[7518].INF-zm_monitor.cpp/3116 [Front_Window_QC4_LR: 6000 - Capturing at 4.98 fps]
2016-08-23 18:08:09.121176 zmc_m19[7549].INF-zm_monitor.cpp/3116 [BackDoor_Pool_QC5_LR: 6000 - Capturing at 4.95 fps]
2016-08-23 18:08:09.347340 zma_m18[7535].INF-zm_monitor.cpp/1287 [Front_Window_QC4_LR: 6000 - Analysing at 4.95 fps]
2016-08-23 18:08:09.543612 zma_m19[7564].INF-zm_monitor.cpp/1287 [BackDoor_Pool_QC5_LR: 6000 - Analysing at 4.98 fps]
2016-08-23 18:08:09.728528 zmc_m20[7580].INF-zm_monitor.cpp/3116 [Front_Door_QC6_LR: 6000 - Capturing at 4.98 fps]
2016-08-23 18:08:10.130871 zma_m20[7596].INF-zm_monitor.cpp/1287 [Front_Door_QC6_LR: 6000 - Analysing at 4.95 fps]
2016-08-23 18:08:10.532408 zmc_m26[7611].INF-zm_monitor.cpp/3116 [Side_Gate_QC1_LR: 6000 - Capturing at 4.98 fps]
2016-08-23 18:08:10.938798 zma_m26[7625].INF-zm_monitor.cpp/1287 [Side_Gate_QC1_LR: 6000 - Analysing at 4.98 fps]
2016-08-23 18:09:21.773294 zmc_m7[7458].INF-zm_monitor.cpp/3116 [Family_Room_PT_foscam: 10000 - Capturing at 7.75 fps]
Re: Can not change saved states via web after update to 1.30.0 (command line works)
Working fine here.
You should contact the OpenSuse package maintainer. I've seen him pop into this forums from time to time, but he may not see this one since you've not identified you are running OpenSuses in the title.
The package maintainer has chosen to customize ZoneMinder. In particular, I seem to recall he chose to use sudo (and a custom sudoers file), rather than polkit, to authenticate requests for changing state from the web console. This is just a guess, but that would explain why the default state changes all work, but the new states you just created do not... because those state names are not in the sudoers file.
emailej
Post by emailej »
Thanks Knnniggett,
Looks like its related to a recent fix:
https://build.opensuse.org/package/show ... ZoneMinder
"Latest Revision
Dirk Hartmann Dirk Hartmann (Monex) committed 3 days ago (revision 115)
- Fix web control start/stop/restart"
Bug report submitted ( https://bugzilla.opensuse.org/show_bug.cgi?id=995384 ) and I will update here if a fix becomes available.
monex
Post by monex »
it seems that my last fix doesn't work as expected. I rolled back the changes for now, so that it should work as expected again. New Packages are on the way.
By the way the package uses polkit since 1.30.0 and is a lot more closer to the vanilla version.
Please report back, if the error still exists after the next package update.
Have a lot of fun,
Dirk
Thanks for the follow-up, Dirk!
emailej
Post by emailej »
Thanks much for the help Dirk, and knnniggett!
Latest update (11.30.0-12.1) installed and that fixed it :D :D :D
