API configuration issues
bforcier
Post by bforcier »
I recently upgraded to 1.29 and am trying to setup the API for use with zmnija. I followed the guide posted on the wiki for apache and zm configuration but I can't get the app to talk to the API. When I do http://serverip/zm/api: I get "The requested URL /zm/api was not found on this server."
http://serverip/zm/api/host/getVersion.json I don't see anything. I actually don't even have a host folder in my api directory.
Everything in /usr/share has the same user/owner (www-data). My apache2.conf has entries described on the wiki. Not sure what else I could be missing.
asker
Re: API configuration issues
Post by asker »
How exactly did you upgrade? Which guide did you follow?
Please read before posting:
ES docs
zmNinja docs
bforcier
Post by bforcier »
I removed with purge, autoremove, and cleared the zm database then followed this:
asker
Post by asker »
If you followed that guide verbatim and are sure you did not miss steps, then the Api parh should be server/zm/api not server/api as you wrote below?
bforcier wrote:I removed with purge, autoremove, and cleared the zm database then followed this:
ES docs
zmNinja docs
bforcier
Post by bforcier »
Yes. Sorry about that http://serverip/zm/api is what was configured (edited in original) this returns 404.
asker
Post by asker »
Try these, and please post the exact output from all of these. Thanks.
sudo a2enmod rewrite
cat /usr/share/zoneminder/www/api/.htaccess
cat /usr/share/zoneminder/www/api/app/.htaccess
cat /usr/share/zoneminder/www/api/app/webroot/.htaccess
cat /etc/apache2/conf-enabled/zoneminder.conf #replace zoneminder.conf with any other config you may  be using
ES docs
zmNinja docs
Zenw1e
Post by Zenw1e »
hi, asker!
We have same problem weet API. ZM works good, but our chief wants to explore cameras from he's smartphone (iPhone 6). We have bought zmninja from AppMarket, then install it, But ZMNinja request an API.
My API doesn't work, i' got error (see attachment)
What would i do?
Linux Debian 8.0
ZM 1.29.0
I'm trying by your steps:
root@stk-video-01:/etc/apache2# a2enmod rewrite
Module rewrite already enabled
root@stk-video-01:/etc/apache2# cat /usr/share/zoneminder/www/api/.htaccess
cat: /usr/share/zoneminder/www/api/.htaccess: No file or directory is found
root@stk-video-01:/etc/apache2# cat /usr/share/zoneminder/www/api/app/.htaccess
<IfModule mod_rewrite.c>
    RewriteEngine on
    RewriteRule    ^$    webroot/    [L]
    RewriteRule    (.*) webroot/$1    [L]
    RewriteBase /zm/api
</IfModule>
root@stk-video-01:/etc/apache2# cat /usr/share/zoneminder/www/api/app/webroot/.htaccess
    RewriteEngine On
    RewriteRule ^ index.php [L]
    RewriteBase /zm/api
</IfModule>
root@stk-video-01:/etc/apache2# cat /etc/apache2/conf-enabled/zoneminder.conf
    AllowOverride All
    Require all granted
</Directory>
  php_flag register_globals off
  <IfModule mod_dir.c>
    DirectoryIndex index.php
  </IfModule>
</Directory>
    AllowOverride All
</Directory>
cakephp error.jpg (205.75 KiB) Viewed 8342 times
asker
Post by asker »
Are you sure you did
edit: looks like you already did it
ES docs
zmNinja docs
asker
Post by asker »
Hmm, looks like your .htaccess file is missing in api/ - not sure how you upgraded
Try this:
cp /usr/share/zoneminder/www/api/app/.htaccess /usr/share/zoneminder/www/api/.htaccess
ES docs
zmNinja docs
Zenw1e
Post by Zenw1e »
Thanx, i tried to
root@stk-video-01:/etc/apache2# cp /usr/share/zoneminder/www/api/app/.htaccess /usr/share/zoneminder/www/api/.htaccess
then try to open.
I have no upgrade to 1.29.0
Clear install was be with 1.29.0 version.
internal error.jpg (68.25 KiB) Viewed 8301 times
Zenw1e
Post by Zenw1e »
Thanx a lot, asker!
I have solved my problem.
Problem was in file:
root@stk-video-01:/usr/share/zoneminder/www/api# cat /usr/share/zoneminder/www/api/.htaccess
    RewriteEngine on
    RewriteRule    ^$   /webroot/    [L]
    RewriteRule    (.*) /webroot/$1    [L]
    RewriteBase /zm/api
</IfModule>
In this case API doesn't work. But i turn on my other ZM server and make:
    RewriteEngine on
    RewriteRule    ^$   app/webroot/    [L]
    RewriteRule    (.*) app/webroot/$1    [L]
    RewriteBase /zm/api
</IfModule>
Then, i corrected my /usr/share/zoneminder/www/api/.htaccess file and paste "app", reload apache2 and GOOD!
THANX!
