Hi Support,
How To setup on zomeminder recording only when motion is detected. we need to use the motion detection built in the camera to save CPU
Please help
Thanks & Puneet sharma
How to use your external camera's motion detection with ZM
Re: How to use your external camera's motion detection with ZM
i have zoneminder 1.29 on Centos 6.5
Can someone tell me the perticular steps its will really helpful for me
There's a fantastic option in the forum called "Search", I recommend you to use it before asking for help.
Hope it helps,
PacoLM
Hope it helps,
PacoLM
@ PacoLM i searched but didnt found any solution can you please help me.
Thanks a lot
Thanks a lot
using nc and allowing the
ZM_OPT_TRIGGERS
ZoneMinder can interact with external systems which prompt or cancel alarms. This is done via the zmtrigger.pl script. This option indicates whether you want to use these external triggers. Most people will say no here.
ZM_OPT_TRIGGERS
edit: Apparently I cannot read, I thought this was about triggering over a network. Post removed, my bad.
