Hacked Yi Home Camera Support
I own four Xaiomi Yi Home Cameras: https://www.amazon.com/YI-Home-Camera-O ... B016F3M7OM
I have installed a modified firmware that provides an unencrypted RTSP stream: https://github.com/fritz-smh/yi-hack
I can remotely view the streams via the HTTP urls described at GitHub using VLC or a browser. However, I cannot get the cameras working with ZoneMinder. Does anyone have any experience with a similar setup or could anyone provide some help? I would sincerely appreciate it.
So far, I have only been able to get zoneMinder to display Red and/or Blue screens or alternately a complete gray screen where only the timestamp from the camera (Not ZM) is displayed for a few seconds and then freezes.
URL that works with VLC for example: rtsp://10.0.10.50:554/ch0_0.h264
- knight-of-ni
Re: Hacked Yi Home Camera Support
Well, you should start by providing us some real data. Telling us something doesn't work is not particularly helpful, and none of us have special powers.
Show us screenshots of the general and source tabs of the monitor in question.
We need to see your zoneminder log, from the moment zoneminder is started up until just after you either see errors in the logs. Do not try to open a live view while collecting this data.
Sorry I should have known better. I suppose I was just hoping someone had previously solved this problem.
EDIT: Those photos aren't working. Here is the direct link to the imgur album: http://imgur.com/a/gP3KV
Date/Time
Component Server PID Level Message File Line
2016-09-09 14:33:54.308020 zmc_m3 9242 INF Monitor-3: 76000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:53.210763 zmc_m3 9242 INF Monitor-3: 75000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:51.203398 zmc_m3 9242 INF Monitor-3: 74000 - Capturing at 333.33 fps zm_monitor.cpp 3116
2016-09-09 14:33:48.712906 zmc_m3 9242 INF Monitor-3: 73000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:46.484929 web_js 2917 ERR Export request failed: 500 / Internal Server Error - exportFail() ?view=log
2016-09-09 14:33:46.196956 zmc_m3 9242 INF Monitor-3: 72000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:46.011295 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:33:46.010671 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:33:46.009618 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:33:42.309726 zmc_m3 9242 INF Monitor-3: 71000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:40.123580 zmc_m3 9242 INF Monitor-3: 70000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:38.721347 zmc_m3 9242 INF Monitor-3: 69000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:36.789617 zmc_m3 9242 INF Monitor-3: 68000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:35.029227 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:33:35.028654 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:33:35.027684 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:33:34.834049 zmc_m3 9242 INF Monitor-3: 67000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:32.706629 zmc_m3 9242 INF Monitor-3: 66000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:31.103271 web_js 5226 ERR Export request failed: 500 / Internal Server Error - exportFail() ?view=log
2016-09-09 14:33:30.102986 zmc_m1 9233 INF Attached_Garage: 2000 - Capturing at 18.18 fps zm_monitor.cpp 3116
2016-09-09 14:33:29.785748 web_js 2917 ERR Export request failed: 500 / Internal Server Error - exportFail() ?view=log
2016-09-09 14:33:28.808446 zmc_m3 9242 INF Monitor-3: 65000 - Capturing at 333.33 fps zm_monitor.cpp 3116
2016-09-09 14:33:25.127438 zmc_m3 9242 INF Monitor-3: 64000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:24.810823 web_js 5139 ERR Export request failed: 500 / Internal Server Error - exportFail() ?view=log
2016-09-09 14:33:24.089476 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:33:24.088743 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:33:24.087679 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:33:21.196395 zmc_m3 9242 INF Monitor-3: 63000 - Capturing at 333.33 fps zm_monitor.cpp 3116
2016-09-09 14:33:18.721696 zmc_m3 9242 INF Monitor-3: 62000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:16.353520 zmc_m3 9242 INF Monitor-3: 61000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:14.310465 zmc_m3 9242 INF Monitor-3: 60000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:13.010910 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:33:13.010063 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:33:13.008698 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:33:12.082902 zmc_m3 9242 INF Monitor-3: 59000 - Capturing at 333.33 fps zm_monitor.cpp 3116
2016-09-09 14:33:09.712414 zmc_m3 9242 INF Monitor-3: 58000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:08.086100 zmc_m3 9242 INF Monitor-3: 57000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:06.591131 zmc_m3 9242 INF Monitor-3: 56000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:04.356521 zmc_m3 9242 INF Monitor-3: 55000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:33:02.039140 zmc_m3 9242 INF Monitor-3: 54000 - Capturing at 333.33 fps zm_monitor.cpp 3116
2016-09-09 14:33:02.025616 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:33:02.025066 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:33:02.023959 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:32:59.927432 zmc_m3 9242 INF Monitor-3: 53000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:57.744981 zmc_m3 9242 INF Monitor-3: 52000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:55.314594 zmc_m3 9242 INF Monitor-3: 51000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:53.504917 zmc_m3 9242 INF Monitor-3: 50000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:51.014293 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:32:51.013239 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:32:51.011856 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:32:49.783067 zmc_m3 9242 INF Monitor-3: 49000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:48.697272 zmc_m3 9242 INF Monitor-3: 48000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:46.723945 zmc_m3 9242 INF Monitor-3: 47000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:45.688729 zmc_m3 9242 INF Monitor-3: 46000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:44.625674 zmc_m3 9242 INF Monitor-3: 45000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:43.555828 zmc_m3 9242 INF Monitor-3: 44000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:42.494082 zmc_m3 9242 INF Monitor-3: 43000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:41.427432 zmc_m3 9242 INF Monitor-3: 42000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:40.367187 zmc_m3 9242 INF Monitor-3: 41000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:40.060592 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:32:40.059859 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:32:40.058802 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:32:39.307952 zmc_m3 9242 INF Monitor-3: 40000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:38.243093 zmc_m3 9242 INF Monitor-3: 39000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:37.126372 zmc_m3 9242 INF Monitor-3: 38000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:36.040585 zmc_m3 9242 INF Monitor-3: 37000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:35.608630 zmc_m1 9233 INF Attached_Garage: 1000 - Capturing at 19.61 fps zm_monitor.cpp 3116
2016-09-09 14:32:34.982371 zmc_m3 9242 INF Monitor-3: 36000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:33.918646 zmc_m3 9242 INF Monitor-3: 35000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:32.848561 zmc_m3 9242 INF Monitor-3: 34000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:31.783934 zmc_m3 9242 INF Monitor-3: 33000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:30.712840 zmc_m3 9242 INF Monitor-3: 32000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:29.545622 zmc_m3 9242 INF Monitor-3: 31000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:29.002178 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:32:29.001731 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:32:29.000835 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:32:28.483401 zmc_m3 9242 INF Monitor-3: 30000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:27.327943 zmc_m3 9242 INF Monitor-3: 29000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:26.111725 zmc_m3 9242 INF Monitor-3: 28000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:25.038584 zmc_m3 9242 INF Monitor-3: 27000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:23.968229 zmc_m3 9242 INF Monitor-3: 26000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:22.891924 zmc_m3 9242 INF Monitor-3: 25000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:21.818129 zmc_m3 9242 INF Monitor-3: 24000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:20.749844 zmc_m3 9242 INF Monitor-3: 23000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:19.695569 zmc_m3 9242 INF Monitor-3: 22000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:18.619215 zmc_m3 9242 INF Monitor-3: 21000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:18.050495 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:32:18.049433 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:32:18.048332 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:32:17.543262 zmc_m3 9242 INF Monitor-3: 20000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:16.489028 zmc_m3 9242 INF Monitor-3: 19000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:15.403618 zmc_m3 9242 INF Monitor-3: 18000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:14.342516 zmc_m3 9242 INF Monitor-3: 17000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:13.284387 zmc_m3 9242 INF Monitor-3: 16000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:12.208943 zmc_m3 9242 INF Monitor-3: 15000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:11.065615 zmc_m3 9242 INF Monitor-3: 14000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:10.027967 zmc_m3 9242 INF Monitor-3: 13000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:08.966432 zmc_m3 9242 INF Monitor-3: 12000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:07.914692 zmc_m3 9242 INF Monitor-3: 11000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:07.094374 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:32:07.093755 zmc_m3 9277 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:32:07.092616 zmc_m3 9277 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:32:06.868235 zmc_m3 9242 INF Monitor-3: 10000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:05.807041 zmc_m3 9242 INF Monitor-3: 9000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:04.744416 zmc_m3 9242 INF Monitor-3: 8000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:03.588126 zmc_m3 9242 INF Monitor-3: 7000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:02.555009 zmc_m3 9242 INF Monitor-3: 6000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:01.497702 zmc_m3 9242 INF Monitor-3: 5000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:32:00.423752 zmc_m3 9242 INF Monitor-3: 4000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:31:59.361812 zmc_m3 9242 INF Monitor-3: 3000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:31:58.294162 zmc_m3 9242 INF Monitor-3: 2000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:31:57.227126 zmc_m3 9242 INF Monitor-3: 1000 - Capturing at 83.33 fps zm_monitor.cpp 3116
2016-09-09 14:31:56.034034 zmc_m3 9277 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:31:56.032975 zmc_m3 9242 ERR Unable to open input http://10.0.10.51:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:31:56.031477 zmc_m3 9242 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:31:46.716360 zmwatch 9263 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-09-09 14:31:46.714940 zmwatch 9263 INF Watchdog starting zmwatch.pl
2016-09-09 14:31:46.704590 zmdc 9272 INF 'zmtelemetry.pl' started at 16/09/09 18:31:46 zmdc.pl
2016-09-09 14:31:46.704580 zmdc 9201 INF 'zmtelemetry.pl' starting at 16/09/09 18:31:46, pid = 9272 zmdc.pl
2016-09-09 14:31:46.198410 zmdc 9263 INF 'zmwatch.pl' started at 16/09/09 18:31:46 zmdc.pl
2016-09-09 14:31:46.197740 zmdc 9201 INF 'zmwatch.pl' starting at 16/09/09 18:31:46, pid = 9263 zmdc.pl
2016-09-09 14:31:46.097600 zmfilter 9246 INF Scanning for events zmfilter.pl
2016-09-09 14:31:45.869370 zmc_m1 9256 WAR Discarding incomplete frame 0, 0 bytes zm_rtp_source.cpp 336
2016-09-09 14:31:45.860738 zmc_m1 9256 WAR Discarding frame 0 zm_rtp_source.cpp 349
2016-09-09 14:31:45.859303 zmc_m1 9256 WAR Sequence in probation 2, out of sequence zm_rtp_source.cpp 112
2016-09-09 14:31:45.652392 zmc_m1 9235 INF Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://10.0.10.50/ch0_0.h264/' zm_rtsp.cpp 398
2016-09-09 14:31:45.589620 zmdc 9253 INF 'zmaudit.pl -c' started at 16/09/09 18:31:45 zmdc.pl
2016-09-09 14:31:45.589080 zmdc 9201 INF 'zmaudit.pl -c' starting at 16/09/09 18:31:45, pid = 9253 zmdc.pl
2016-09-09 14:31:45.203390 zmdc 9201 INF 'zmfilter.pl' starting at 16/09/09 18:31:45, pid = 9246 zmdc.pl
2016-09-09 14:31:45.203390 zmdc 9246 INF 'zmfilter.pl' started at 16/09/09 18:31:45 zmdc.pl
2016-09-09 14:31:45.190385 zmc_m3 9242 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:31:45.189692 zmc_m3 9242 INF Priming capture from http://10.0.10.51:554/ch0_0.h264 zm_ffmpeg_camera.cpp 104
2016-09-09 14:31:45.188661 zmc_m3 9242 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-09 14:31:44.981200 zmdc 9242 INF 'zmc -m 3' started at 16/09/09 18:31:44 zmdc.pl
2016-09-09 14:31:44.981190 zmdc 9201 INF 'zmc -m 3' starting at 16/09/09 18:31:44, pid = 9242 zmdc.pl
2016-09-09 14:31:44.940340 zmdc 9201 INF Starting pending process, zmc -m 3 zmdc.pl
2016-09-09 14:31:44.939050 zmdc 9201 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl
2016-09-09 14:31:44.911850 zmdc 9238 INF 'zmc -m 3' started at 16/09/09 18:31:44 zmdc.pl
2016-09-09 14:31:44.911840 zmdc 9201 INF 'zmc -m 3' starting at 16/09/09 18:31:44, pid = 9238 zmdc.pl
2016-09-09 14:31:44.814928 zmc_m1 9233 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-09 14:31:44.515100 zmdc 9233 INF 'zmc -m 1' started at 16/09/09 18:31:44 zmdc.pl
2016-09-09 14:31:44.514870 zmdc 9201 INF 'zmc -m 1' starting at 16/09/09 18:31:44, pid = 9233 zmdc.pl
2016-09-09 14:31:44.511810 zmdc 9201 INF Starting pending process, zmc -m 1 zmdc.pl
2016-09-09 14:31:44.510600 zmdc 9201 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-09-09 14:31:44.485520 zmdc 9228 INF 'zmc -m 1' started at 16/09/09 18:31:44 zmdc.pl
2016-09-09 14:31:44.485180 zmdc 9201 INF 'zmc -m 1' starting at 16/09/09 18:31:44, pid = 9228 zmdc.pl
2016-09-09 14:31:44.259750 zmpkg 9186 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-09-09 14:31:41.255220 zmdc 9201 INF Server starting at 16/09/09 18:31:41 zmdc.pl
2016-09-09 14:31:40.871560 zmpkg 9186 INF Command: start zmpkg.pl
2016-09-09 14:31:40.868610 zmpkg 9186 INF Sanity checking States table... zmpkg.pl
2016-09-09 14:31:25.604790 zmdc 3206 INF Server shutdown at 16/09/09 18:31:25 zmdc.pl
2016-09-09 14:31:15.391060 zmdc 3206 INF 'zmc -m 1' crashed, signal 8 zmdc.pl
2016-09-09 14:31:15.381230 zmdc 3206 WAR 'zmc -m 1' has not stopped at 16/09/09 18:31:15. Sending KILL to pid 7626 zmdc.pl
2016-09-09 14:31:13.322910 zmdc 3206 INF 'zmc -m 3' exited normally zmdc.pl
2016-09-09 14:31:13.316030 zmdc 3206 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-09-09 14:31:13.295070 zmdc 3206 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-09-09 14:31:13.293250 zmdc 3206 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-09-09 14:31:13.292050 zmdc 3206 INF 'zmtelemetry.pl' sending stop to pid 3273 at 16/09/09 18:31:13 zmdc.pl
2016-09-09 14:31:13.291190 zmdc 3206 INF 'zmc -m 3' sending stop to pid 3245 at 16/09/09 18:31:13 zmdc.pl
2016-09-09 14:31:13.289390 zmdc 3206 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-09-09 14:31:13.289190 zmdc 3206 INF 'zmaudit.pl -c' sending stop to pid 3257 at 16/09/09 18:31:13 zmdc.pl
2016-09-09 14:31:13.287680 zmdc 3206 INF 'zmwatch.pl' sending stop to pid 3264 at 16/09/09 18:31:13 zmdc.pl
2016-09-09 14:31:13.287645 zmc_m1 7626 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-09 14:31:13.286410 zmdc 3206 INF 'zmc -m 1' sending stop to pid 7626 at 16/09/09 18:31:13 zmdc.pl
2016-09-09 14:31:13.284540 zmdc 3206 INF 'zmfilter.pl' sending stop to pid 3249 at 16/09/09 18:31:13 zmdc.pl
2016-09-09 14:31:12.415430 zmpkg 9135 INF Command: stop zmpkg.pl
2016-09-09 14:31:12.413580 zmpkg 9135 INF Sanity checking States table... zmpkg.pl
2016-09-09 14:31:11.620770 zmpkg 9126 INF Command: status zmpkg.pl
2016-09-09 14:31:11.618640 zmpkg 9126 INF Sanity checking States table... zmpkg.pl
2016-09-09 14:29:30.411473 zms 9082 ERR Terminating, last frame sent time 1473445769.911364 secs more than maximum of 10.000000 zm_monitor.cpp 4192
2016-09-09 14:29:29.647033 web_php 8965 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:29:29.645446 web_php 8965 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 13:50:59.017756 zms 8968 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-09 13:50:51.901557 web_php 6043 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 13:50:51.899942 web_php 6043 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 13:50:46.215089 zms 8966 ERR Terminating, last frame sent time 1473443445.714992 secs more than maximum of 10.000000 zm_monitor.cpp 4192
2016-09-09 13:50:45.545525 web_php 5598 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 13:50:45.543043 web_php 5598 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-08 00:32:40.922030 zmc_m1 7628 WAR Destroying mutex when locked zm_thread.cpp 64
2016-09-08 00:32:33.914630 zmc_m1 7629 ERR RTP timed out zm_rtp_data.cpp 93
2016-09-08 00:32:30.894992 zmc_m1 7628 INF Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://10.0.10.50/ch0_0.h264/' zm_rtsp.cpp 398
2016-09-08 00:32:30.018701 zmc_m1 7626 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-08 00:32:29.813440 zmdc 7626 INF 'zmc -m 1' started at 16/09/08 04:32:29 zmdc.pl
2016-09-08 00:32:29.813440 zmdc 3206 INF 'zmc -m 1' starting at 16/09/08 04:32:29, pid = 7626 zmdc.pl
2016-09-08 00:32:29.399230 zmwatch 3264 INF Restarting capture daemon for Attached_Garage, time since last capture 26 seconds (1473309149-1473309123) zmwatch.pl
2016-09-08 00:32:19.391230 zmdc 3206 INF 'zmc -m 1' crashed, signal 8 zmdc.pl
2016-09-08 00:32:19.381850 zmdc 3206 WAR 'zmc -m 1' has not stopped at 16/09/08 04:32:19. Sending KILL to pid 7615 zmdc.pl
2016-09-08 00:32:13.381197 zmc_m1 7615 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-08 00:32:13.328960 zmdc 3206 INF 'zmc -m 1' sending stop to pid 7615 at 16/09/08 04:32:13 zmdc.pl
2016-09-08 00:32:13.085790 zmwatch 3264 INF Restarting capture daemon for Attached_Garage, time since last capture 10 seconds (1473309133-1473309123) zmwatch.pl
2016-09-08 00:31:56.694397 zmc_m1 7618 WAR Discarding incomplete frame 0, 0 bytes zm_rtp_source.cpp 336
2016-09-08 00:31:56.692689 zmc_m1 7618 WAR Discarding frame 0 zm_rtp_source.cpp 349
2016-09-08 00:31:56.691698 zmc_m1 7618 WAR Sequence in probation 2, out of sequence zm_rtp_source.cpp 112
2016-09-08 00:31:54.096988 zmc_m1 7617 INF Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://10.0.10.50/ch0_0.h264/' zm_rtsp.cpp 398
2016-09-08 00:31:53.283989 zmc_m1 7615 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-08 00:31:53.020290 zmdc 7615 INF 'zmc -m 1' started at 16/09/08 04:31:53 zmdc.pl
2016-09-08 00:31:53.020280 zmdc 3206 INF 'zmc -m 1' starting at 16/09/08 04:31:53, pid = 7615 zmdc.pl
2016-09-08 00:31:52.627370 zmwatch 3264 INF Restarting capture daemon for Attached_Garage, shared data not valid zmwatch.pl
2016-09-08 00:31:45.815800 zmdc 3206 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-09-08 00:31:45.786730 zmc_m1 7607 ERR Failed to pre-capture monitor 1 1666202996 (1/1) zmc.cpp 315
- knight-of-ni
Change your source type from Remote to ffmpeg.
Note that this will change some of the fields on the source tab, so will need to re-enter the rtsp url.
Will need to see your log files again if that does not completely solve the issue.
Continued fiddling after posting those pictures and logs. I noticed I get a different result if I use an analysis FPS of 30. I've also tried your suggestion of ffmpeg. Below are the logs and pictures for everything. The pictures are in order:
http://imgur.com/a/FQIX0
Date/Time
2016-09-09 14:46:23.625556 zmc_m1 9719 INF Attached_Garage: 97000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:21.241777 zmc_m1 9719 INF Attached_Garage: 96000 - Capturing at 333.33 fps zm_monitor.cpp 3116
2016-09-09 14:46:18.812351 zmc_m1 9719 INF Attached_Garage: 95000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:16.525714 zmc_m1 9719 INF Attached_Garage: 94000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:15.481326 zmc_m1 9719 INF Attached_Garage: 93000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:15.098791 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:46:15.098290 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:46:15.097352 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:46:14.426111 zmc_m1 9719 INF Attached_Garage: 92000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:13.365377 zmc_m1 9719 INF Attached_Garage: 91000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:12.323603 zmc_m1 9719 INF Attached_Garage: 90000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:11.269263 zmc_m1 9719 INF Attached_Garage: 89000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:10.214731 zmc_m1 9719 INF Attached_Garage: 88000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:09.149125 zmc_m1 9719 INF Attached_Garage: 87000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:08.093346 zmc_m1 9719 INF Attached_Garage: 86000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:08.039386 zmc_m3 9596 INF Monitor-3: 6000 - Capturing at 19.23 fps zm_monitor.cpp 3116
2016-09-09 14:46:07.036609 zmc_m1 9719 INF Attached_Garage: 85000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:05.990353 zmc_m1 9719 INF Attached_Garage: 84000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:04.943222 zmc_m1 9719 INF Attached_Garage: 83000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:04.049279 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:46:04.048282 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:46:04.046974 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:46:03.893640 zmc_m1 9719 INF Attached_Garage: 82000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:02.846288 zmc_m1 9719 INF Attached_Garage: 81000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:01.802497 zmc_m1 9719 INF Attached_Garage: 80000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:46:00.754602 zmc_m1 9719 INF Attached_Garage: 79000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:59.711748 zmc_m1 9719 INF Attached_Garage: 78000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:58.661926 zmc_m1 9719 INF Attached_Garage: 77000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:57.614563 zmc_m1 9719 INF Attached_Garage: 76000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:56.561710 zmc_m1 9719 INF Attached_Garage: 75000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:55.508077 zmc_m1 9719 INF Attached_Garage: 74000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:54.470540 zmc_m1 9719 INF Attached_Garage: 73000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:53.428186 zmc_m1 9719 INF Attached_Garage: 72000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:53.107301 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:45:53.106522 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:45:53.105463 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:45:52.367740 zmc_m1 9719 INF Attached_Garage: 71000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:51.323366 zmc_m1 9719 INF Attached_Garage: 70000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:50.271956 zmc_m1 9719 INF Attached_Garage: 69000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:49.224771 zmc_m1 9719 INF Attached_Garage: 68000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:48.163594 zmc_m1 9719 INF Attached_Garage: 67000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:47.007973 zmc_m1 9719 INF Attached_Garage: 66000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:45.834307 zmc_m1 9719 INF Attached_Garage: 65000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:44.680529 zmc_m1 9719 INF Attached_Garage: 64000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:43.446747 zmc_m1 9719 INF Attached_Garage: 63000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:42.301597 zmc_m1 9719 INF Attached_Garage: 62000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:42.036901 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:45:42.036080 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:45:42.034860 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:45:41.093677 zmc_m1 9719 INF Attached_Garage: 61000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:39.926102 zmc_m1 9719 INF Attached_Garage: 60000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:38.758795 zmc_m1 9719 INF Attached_Garage: 59000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:37.544373 zmc_m1 9719 INF Attached_Garage: 58000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:36.304355 zmc_m1 9719 INF Attached_Garage: 57000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:35.248729 zmc_m1 9719 INF Attached_Garage: 56000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:34.194864 zmc_m1 9719 INF Attached_Garage: 55000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:33.126890 zmc_m1 9719 INF Attached_Garage: 54000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:32.070234 zmc_m1 9719 INF Attached_Garage: 53000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:31.069325 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:45:31.068606 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:45:31.067503 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:45:31.016781 zmc_m1 9719 INF Attached_Garage: 52000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:29.965100 zmc_m1 9719 INF Attached_Garage: 51000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:28.917704 zmc_m1 9719 INF Attached_Garage: 50000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:27.849188 zmc_m1 9719 INF Attached_Garage: 49000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:26.788427 zmc_m1 9719 INF Attached_Garage: 48000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:25.727164 zmc_m1 9719 INF Attached_Garage: 47000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:24.689640 zmc_m1 9719 INF Attached_Garage: 46000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:23.636508 zmc_m1 9719 INF Attached_Garage: 45000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:22.593774 zmc_m1 9719 INF Attached_Garage: 44000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:21.529634 zmc_m1 9719 INF Attached_Garage: 43000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:20.488228 zmc_m1 9719 INF Attached_Garage: 42000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:20.021535 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:45:20.020891 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:45:20.019846 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:45:19.418852 zmc_m1 9719 INF Attached_Garage: 41000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:18.368430 zmc_m1 9719 INF Attached_Garage: 40000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:17.317898 zmc_m1 9719 INF Attached_Garage: 39000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:16.454243 zmc_m3 9596 INF Monitor-3: 5000 - Capturing at 19.23 fps zm_monitor.cpp 3116
2016-09-09 14:45:16.261381 zmc_m1 9719 INF Attached_Garage: 38000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:15.206832 zmc_m1 9719 INF Attached_Garage: 37000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:14.160647 zmc_m1 9719 INF Attached_Garage: 36000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:13.112021 zmc_m1 9719 INF Attached_Garage: 35000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:12.066020 zmc_m1 9719 INF Attached_Garage: 34000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:10.994737 zmc_m1 9719 INF Attached_Garage: 33000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:10.247542 zms 9727 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-09 14:45:09.802395 zmc_m1 9719 INF Attached_Garage: 32000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:09.051317 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:45:09.050709 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:45:09.049659 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:45:08.488683 zmc_m1 9719 INF Attached_Garage: 31000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:06.995847 zmc_m1 9719 INF Attached_Garage: 30000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:05.607066 zmc_m1 9719 INF Attached_Garage: 29000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:03.208273 zmc_m1 9719 INF Attached_Garage: 28000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:02.550792 web_php 9678 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:45:02.548262 web_php 9678 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:45:01.859628 zmc_m1 9719 INF Attached_Garage: 27000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:45:00.812612 zmc_m1 9719 INF Attached_Garage: 26000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:59.759871 zmc_m1 9719 INF Attached_Garage: 25000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:58.718237 zmc_m1 9719 INF Attached_Garage: 24000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:58.107149 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:44:58.106322 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:44:58.105321 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:44:57.653430 zmc_m1 9719 INF Attached_Garage: 23000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:56.611364 zmc_m1 9719 INF Attached_Garage: 22000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:55.549611 zmc_m1 9719 INF Attached_Garage: 21000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:54.511603 zmc_m1 9719 INF Attached_Garage: 20000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:53.439121 zmc_m1 9719 INF Attached_Garage: 19000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:52.384701 zmc_m1 9719 INF Attached_Garage: 18000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:51.328651 zmc_m1 9719 INF Attached_Garage: 17000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:50.274129 zmc_m1 9719 INF Attached_Garage: 16000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:49.228662 zmc_m1 9719 INF Attached_Garage: 15000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:48.227564 zms 9725 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-09 14:44:47.021374 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:44:47.020506 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:44:47.019625 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:44:47.013714 zmc_m1 9719 INF Attached_Garage: 14000 - Capturing at 200.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:42.227477 zmc_m1 9719 INF Attached_Garage: 13000 - Capturing at 200.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:37.901049 zmc_m1 9719 INF Attached_Garage: 12000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:37.591979 web_php 2917 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:44:37.590481 web_php 2917 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:44:36.795940 zmc_m1 9719 INF Attached_Garage: 11000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:36.084597 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:44:36.084089 zmc_m1 9724 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:44:36.082958 zmc_m1 9724 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:44:35.642098 zmc_m1 9719 INF Attached_Garage: 10000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:34.591090 zmc_m1 9719 INF Attached_Garage: 9000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:33.517624 zmc_m1 9719 INF Attached_Garage: 8000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:32.462030 zmc_m1 9719 INF Attached_Garage: 7000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:31.414853 zmc_m1 9719 INF Attached_Garage: 6000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:30.358212 zmc_m1 9719 INF Attached_Garage: 5000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:29.313630 zmc_m1 9719 INF Attached_Garage: 4000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:28.254003 zmc_m1 9719 INF Attached_Garage: 3000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:27.219706 zmc_m1 9719 INF Attached_Garage: 2000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:26.158127 zmc_m1 9719 INF Attached_Garage: 1000 - Capturing at 83.33 fps zm_monitor.cpp 3116
2016-09-09 14:44:25.036229 zmc_m1 9724 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:44:25.035092 zmc_m1 9719 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:44:25.033809 zmc_m1 9719 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:44:24.794375 zmc_m3 9596 INF Monitor-3: 4000 - Capturing at 19.61 fps zm_monitor.cpp 3116
2016-09-09 14:44:21.286988 zms 9722 ERR Terminating, last frame sent time 1473446660.786858 secs more than maximum of 10.000000 zm_monitor.cpp 4192
2016-09-09 14:44:20.536009 web_php 9529 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:44:20.532892 web_php 9529 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:44:14.614068 zmc_m1 9719 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:44:14.613281 zmc_m1 9719 INF Priming capture from http://10.0.10.50:554/ch0_0.h264 zm_ffmpeg_camera.cpp 104
2016-09-09 14:44:14.611955 zmc_m1 9719 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-09 14:44:14.519470 zmdc 9719 INF 'zmc -m 1' started at 16/09/09 18:44:14 zmdc.pl
2016-09-09 14:44:14.519440 zmdc 9201 INF 'zmc -m 1' starting at 16/09/09 18:44:14, pid = 9719 zmdc.pl
2016-09-09 14:44:14.515360 zmdc 9201 INF Starting pending process, zmc -m 1 zmdc.pl
2016-09-09 14:44:14.413020 zmdc 9201 INF 'zmc -m 1' crashed, signal 8 zmdc.pl
2016-09-09 14:44:14.401840 zmdc 9201 WAR 'zmc -m 1' has not stopped at 16/09/09 18:44:14. Sending KILL to pid 9698 zmdc.pl
2016-09-09 14:44:08.400828 zmc_m1 9698 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-09 14:44:08.399170 zmdc 9201 INF 'zmc -m 1' sending stop to pid 9698 at 16/09/09 18:44:08 zmdc.pl
2016-09-09 14:44:08.390860 zmdc 9201 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-09-09 14:44:08.198108 zmc_m1 9698 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:44:08.197025 zmc_m1 9698 INF Priming capture from http://10.0.10.50:554/ch0_0.h264 zm_ffmpeg_camera.cpp 104
2016-09-09 14:44:08.196028 zmc_m1 9698 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-09 14:44:07.922530 zmwatch 9263 INF Restarting capture daemon for Attached_Garage, shared data not valid zmwatch.pl
2016-09-09 14:44:07.908700 zmdc 9698 INF 'zmc -m 1' started at 16/09/09 18:44:07 zmdc.pl
2016-09-09 14:44:07.908690 zmdc 9201 INF 'zmc -m 1' starting at 16/09/09 18:44:07, pid = 9698 zmdc.pl
2016-09-09 14:44:07.632070 zmdc 9201 INF 'zmc -m 1' exited normally zmdc.pl
2016-09-09 14:44:07.595183 zmc_m1 9660 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-09 14:44:07.593390 zmdc 9201 INF 'zmc -m 1' sending stop to pid 9660 at 16/09/09 18:44:07 zmdc.pl
2016-09-09 14:44:07.110360 zmdc 9201 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-09-09 14:44:06.008200 zmc_m1 9660 INF Attached_Garage: 30000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:04.960662 zmc_m1 9660 INF Attached_Garage: 29000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:03.915679 zmc_m1 9660 INF Attached_Garage: 28000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:03.126641 zms 9680 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-09 14:44:01.924198 zmc_m1 9660 INF Attached_Garage: 27000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:44:01.081488 zmc_m1 9679 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:44:01.030498 zmc_m1 9679 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:44:01.029119 zmc_m1 9679 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:43:57.927293 zmc_m1 9660 INF Attached_Garage: 26000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:53.407064 zmc_m1 9660 INF Attached_Garage: 25000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:50.088915 zmc_m1 9679 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:43:50.088043 zmc_m1 9679 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:43:50.086793 zmc_m1 9679 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:43:49.182651 zmc_m1 9660 INF Attached_Garage: 24000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:45.329089 zmc_m1 9660 INF Attached_Garage: 23000 - Capturing at 250.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:41.503762 zmc_m1 9660 INF Attached_Garage: 22000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:41.484815 web_php 9615 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:43:41.482465 web_php 9615 WAR ZM_OPT_CAMBOZOLA is enabled, but the system cannot find /usr/share/zoneminder/www/cambozola.jar /usr/share/zoneminder/www/includes/functions.php 791
2016-09-09 14:43:40.437166 zmc_m1 9660 INF Attached_Garage: 21000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:39.389896 zmc_m1 9660 INF Attached_Garage: 20000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:39.103260 zmc_m1 9679 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:43:39.102672 zmc_m1 9679 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:43:39.101513 zmc_m1 9679 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-09-09 14:43:38.330855 zmc_m1 9660 INF Attached_Garage: 19000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:37.283169 zmc_m1 9660 INF Attached_Garage: 18000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:36.225606 zmc_m1 9660 INF Attached_Garage: 17000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:35.166248 zmc_m1 9660 INF Attached_Garage: 16000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:34.109214 zmc_m1 9660 INF Attached_Garage: 15000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:33.200070 zmc_m3 9596 INF Monitor-3: 3000 - Capturing at 19.23 fps zm_monitor.cpp 3116
2016-09-09 14:43:33.056064 zmc_m1 9660 INF Attached_Garage: 14000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:32.014555 zmc_m1 9660 INF Attached_Garage: 13000 - Capturing at 500.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:30.963188 zmc_m1 9660 INF Attached_Garage: 12000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:29.925345 zmc_m1 9660 INF Attached_Garage: 11000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:28.883109 zmc_m1 9660 INF Attached_Garage: 10000 - Capturing at 1000.00 fps zm_monitor.cpp 3116
2016-09-09 14:43:28.063962 zmc_m1 9679 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-09 14:43:28.063222 zmc_m1 9679 ERR Unable to open input http://10.0.10.50:554/ch0_0.h264 due to: Success zm_ffmpeg_camera.cpp 280
2016-09-09 14:43:28.062162 zmc_m1 9679 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
- knight-of-ni
Why are you trying to do this over http?
You should be using the exact same url you used when you successfully tested with vlc. e.g. rtsp://10.0.10.50:554/ch0_0.h264
On a slightly related note, I have a camera very similar to yours which I bought off ebay:
http://www.ebay.com/itm/IP-Camera-720p- ... SwwpdW5pRZ
Mine was onvif compliant so I was able to capture an rtsp stream with third party software w/o hacking the camera's firmware.
Awesome. Working perfect now thank you. Since you're using a similar camera, any settings I should investigate tweaking?
Not sure my camera is ONVIF compliant but I know the RTSP stream was disabled prior to hacking it. Here is one of the resources I used to research hacking mine: http://en.miui.com/thread-137413-1-1.html
Beyond the RTSP stream, the hack prevents the camera from communicating with any server I haven't authorized. When the factory OS was installed, it was sending information to Chinese servers regularly. Not sure if it was malicious, but now I don't have to worry about it. I can also set static IP, name servers, time zones, access via FTP, HTTP and serial. I put the cameras on a VLAN since the streams are unauthenticated. Now I can use ZM to monitor them remotely. I sincerely appreciate the help!
- knight-of-ni
Yeah, I did notice the stupid thing always tried to contact some Chinese cloud server. Even when the camera and viewing device are on the local lan, you still need to be in contact with their cloud server for the supplied app to work with the camera.
I've got mine mounted in an rc model boat, connected to an isolated wifi network so it can't phone home. I'm using a generic onvif app on my android tablet to view the stream.
The cameras should work fine as configured, but note that you only need ~5 fps or so for general surveillance. If your cameras have the ability to lower the frame rate in the camera (mine does not), then that would be a good idea to save storage space and avoid issues where your recording hardware can't keep up.
That's neat that someone has figured out how to hack the firmware. I'll read the link you provided when I get home. The firewall I am behind at work is blocking access to it, but that is no surprise.
I'm not sure I have the ability to reduce the FPS but the streams stay at a steady 20FPS and it's not taxing the container too bad. The container was configured with 2 vCPUs and 2048GB of RAM. I'm surprised how well it runs with so little resources.
I have a question related to your camera - I noticed your's also supports local storage with the MicroSD card slot. Is it possible to make use of this local storage with ZoneMinder?
Hi, jcconnell,
I have the same problem like you: i have a hacked Yi Home camera and i can view streaming in VLC but not in ZM.
Could you upload the exactly screenshots with the good configuration that works fine in ZM with this camera?
Best Regards,
Pakitorn
Best Regards,
Pakitorn
This should be everything you need here:
General Tab: https://i.imgur.com/woIb74r.png
Source Tab: https://i.imgur.com/CxKWy5T.png
I have tried configuring the same camera, but it looks a bit different (the "Remote Method" has different options)
It looks like the motion events are detected and the camera is successfully connected, but I cant see any image.
On VLC everything works great.
I have attached my configuration, I've tried using all 4 options for remote method but nothing works.
- Screenshot 2017-04-15 12.49.27.png (109.02 KiB) Viewed 28948 times
- Screenshot 2017-04-15 12.49.07.png (108.73 KiB) Viewed 28948 times
The resolution looks OK. (1280x720)thatguy wrote:Make sure to set your resolution correctly. You will generally see a blue image if settings like that are incorrect. You can confirm your cameras details by using ffprobe.sagil wrote:I have tried configuring the same camera, but it looks a bit different (the "Remote Method" has different options)
Here is the ffprobe info, couldn't find anything wrong.
ffprobe version 3.3 Copyright (c) 2007-2017 the FFmpeg developers
built with Apple LLVM version 8.0.0 (clang-800.0.42.1)
configuration: --prefix=/usr/local/Cellar/ffmpeg/3.3 --enable-shared --enable-pthreads --enable-gpl --enable-version3 --enable-hardcoded-tables --enable-avresample --cc=clang --host-cflags= --host-ldflags= --enable-libmp3lame --enable-libx264 --enable-libxvid --enable-opencl --disable-lzma --enable-vda
libavutil 55. 58.100 / 55. 58.100
libavcodec 57. 89.100 / 57. 89.100
libavformat 57. 71.100 / 57. 71.100
libavdevice 57. 6.100 / 57. 6.100
libavfilter 6. 82.100 / 6. 82.100
libavresample 3. 5. 0 / 3. 5. 0
libswscale 4. 6.100 / 4. 6.100
libswresample 2. 7.100 / 2. 7.100
libpostproc 54. 5.100 / 54. 5.100
Input #0, rtsp, from 'rtsp://192.168.0.150/ch0_0.h264':
Metadata:
title : H.264 Program Stream, streamed by the LIVE555 Media Server
comment : ch0_0.h264
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0: Video: h264 (High), yuv420p(progressive), 1280x720, 19.50 tbr, 90k tbn, 180k tbc
Stream #0:1: Audio: aac (LC), 8000 Hz, stereo, fltp
[STREAM]
index=0
codec_name=h264
codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
profile=High
codec_type=video
codec_time_base=0/2
codec_tag_string=[0][0][0][0]
codec_tag=0x0000
width=1280
height=720
coded_width=1280
coded_height=720
has_b_frames=0
sample_aspect_ratio=0:1
pix_fmt=yuv420p
level=31
color_range=N/A
color_space=unknown
color_transfer=unknown
color_primaries=unknown
chroma_location=left
field_order=progressive
timecode=N/A
refs=1
is_avc=false
nal_length_size=0
id=N/A
r_frame_rate=39/2
avg_frame_rate=0/0
time_base=1/90000
start_pts=4590
start_time=0.051000
duration_ts=N/A
duration=N/A
bit_rate=N/A
max_bit_rate=N/A
bits_per_raw_sample=8
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:default=0
DISPOSITION:dub=0
DISPOSITION:original=0
DISPOSITION:comment=0
DISPOSITION:lyrics=0
DISPOSITION:karaoke=0
DISPOSITION:forced=0
DISPOSITION:hearing_impaired=0
DISPOSITION:visual_impaired=0
DISPOSITION:clean_effects=0
DISPOSITION:attached_pic=0
DISPOSITION:timed_thumbnails=0
[/STREAM]
[STREAM]
index=1
codec_name=aac
codec_long_name=AAC (Advanced Audio Coding)
profile=LC
codec_type=audio
codec_time_base=1/8000
codec_tag=0x0000
sample_fmt=fltp
sample_rate=8000
channels=2
channel_layout=stereo
bits_per_sample=0
id=N/A
r_frame_rate=0/0
avg_frame_rate=0/0
time_base=1/8000
start_pts=0
start_time=0.000000
duration_ts=N/A
duration=N/A
bit_rate=N/A
max_bit_rate=N/A
bits_per_raw_sample=N/A
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:dub=0
[/STREAM]
OK I got the issue,
I followed the installation instructions for version 1.29 and not 1.30 so I didn't do the PATH_ZMS part.
As I did this the CGI path was corrected and everything is working !
Thank you for your assistance !
@sagil
I recently updated to 1.30.4 and now realize what you mentioned about the different settings screen. How has your experience been with 1.30 and could you share your configuration, including the PATH_ZMS?
