I've noticed that for some of my monitors, that playback via the web interface is having a problem.
It'll play one or two frames, pause, then skip to the end, giving me the "Next event in XX seconds".
I've checked all of the settings to see whether I messed something up between cameras and I can't find anything.
This didn't used to be a problem. A camera that worked just fine is now having the problem.
I know the video is being captured correctly as if I create the video file and export it, it will playback in VLC just fine.
Running 1.30.0 on CentOS 7.
Errors With Event Playback
Re: Errors With Event Playback
As a follow up, I just noticed that for the cameras where this just started, if I go to events a few days old, they will playback just fine. It's only newly recorded events that are having the issue.
As far as I know nothing has changed on the server or install. I did a reboot yesterday, but I didn't install or update any packages. There's nothing in the logs to indicate any issues.
