No Live Video - fps works - stills work - socket_sendto Errors
zminderhalp
Post by zminderhalp »
Followed these directions, twice.
http://zoneminder.readthedocs.io/en/sta ... untu-16-04
Ubuntu 16 desktop, Zoneminder v1.30.0
This is the IP camera I'm using:
http://www.aviosys.com/downloads/manual ... sic_en.pdf
In VLC, this link works perfectly, no auth required:
rtsp://192.168.8.169/mpeg4
Monitor settings in ZM:
General
- Source Type: Remote
- Function: Record
- Enabled: Checked
- Linked Monitors: None
- Analysis FPS: blank
- Max FPS: blank
- Ref Image Blend: 6.25%
- AlmRefImageBlendPct: 6.25%
Source
- Rem Protocol: RTSP
- Remote Method: RTP/RTSP
- Remote Host Name: 192.168.8.169
- Remote Host Port: 554
- Remote Host Path: /mpeg4
- Target colorspace: 24bit
- Capture Width: 1280
- Capture Height: 720
- Pres. Aspect Ration: unchecked
- Oritentation: Normal
- Deinter: Disabled
- Use RTSP Resp. Media URL: Checked
Buffers
- 50, 25, 25, 25, 1000, 1
Still images work and the FPS shows up in the "Feed" screen, just no actual video shows up.
I already set Options->Paths->PATH_ZMS to /zm/cgi-bin/nph-zms
Zoneminder error log:
2016-09-17 12:37:50.574912 web_php[32398].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:37:50.590161 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:37:50.601816 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:37:56.573776 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:37:56.584895 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:37:56.594121 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:37:58.090340 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 14 seconds (1474130278-1474130264)]
2016-09-17 12:37:58.187200 zmdc[32261].INF-zmdc.pl ['zmc -m 1' sending stop to pid 393 at 16/09/17 12:37:58]
2016-09-17 12:37:58.191740 zmc_m1[393].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-09-17 12:38:02.573328 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:02.584469 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:02.593353 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:04.192200 zmdc[32261].WAR-zmdc.pl ['zmc -m 1' has not stopped at 16/09/17 12:38:04. Sending KILL to pid 393]
2016-09-17 12:38:04.204460 zmdc[32261].INF-zmdc.pl ['zmc -m 1' crashed, signal 8]
2016-09-17 12:38:08.580913 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:08.601443 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:08.619623 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:14.218710 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 30 seconds (1474130294-1474130264)]
2016-09-17 12:38:14.434230 zmdc[32261].INF-zmdc.pl ['zmc -m 1' starting at 16/09/17 12:38:14, pid = 412]
2016-09-17 12:38:14.434250 zmdc[412].INF-zmdc.pl ['zmc -m 1' started at 16/09/17 12:38:14]
2016-09-17 12:38:14.565246 zmc_m1[412].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-09-17 12:38:14.580622 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:14.598261 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:14.613390 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:15.497596 zmc_m1[413].INF-zm_rtsp.cpp/398 [Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://192.168.8.169/mpeg4/']
2016-09-17 12:38:20.578881 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:20.599278 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:20.614189 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:26.581500 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:26.603789 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:26.616392 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:32.576688 web_php[32380].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:32.599174 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:32.614819 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:33.827412 zma_m1[32637].INF-zm_monitor.cpp/1287 [SODACAM: 7000 - Analysing at 7.81 fps]
2016-09-17 12:38:38.578116 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:38.599955 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:38.613408 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:44.580088 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:44.597194 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:44.611356 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:50.576470 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:50.597069 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:50.616929 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:38:56.577594 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:38:56.594365 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:38:56.608797 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:02.573418 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:02.586234 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:02.597189 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:08.571115 web_php[32378].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:08.581266 web_js[32378].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:08.589891 web_js[32378].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:14.454830 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 14 seconds (1474130354-1474130340)]
2016-09-17 12:39:14.555770 zmdc[32261].INF-zmdc.pl ['zmc -m 1' sending stop to pid 412 at 16/09/17 12:39:14]
2016-09-17 12:39:14.560453 zmc_m1[412].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-09-17 12:39:14.571210 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:14.581400 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:14.590296 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:20.560930 zmdc[32261].WAR-zmdc.pl ['zmc -m 1' has not stopped at 16/09/17 12:39:20. Sending KILL to pid 412]
2016-09-17 12:39:20.571066 web_php[32379].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:20.581200 zmdc[32261].INF-zmdc.pl ['zmc -m 1' crashed, signal 8]
2016-09-17 12:39:20.586785 web_js[32379].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:20.601471 web_js[32379].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:26.711812 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:26.733037 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:26.750750 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:30.592480 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 30 seconds (1474130370-1474130340)]
2016-09-17 12:39:30.799530 zmdc[32261].INF-zmdc.pl ['zmc -m 1' starting at 16/09/17 12:39:30, pid = 483]
2016-09-17 12:39:30.799560 zmdc[483].INF-zmdc.pl ['zmc -m 1' started at 16/09/17 12:39:30]
2016-09-17 12:39:30.946676 zmc_m1[483].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-09-17 12:39:31.869369 zmc_m1[484].INF-zm_rtsp.cpp/398 [Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://192.168.8.169/mpeg4/']
2016-09-17 12:39:32.577876 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:32.593150 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:32.607209 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:38.575089 web_php[32400].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:38.592971 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:38.607580 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:44.580385 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:44.603163 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:44.618414 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:50.579249 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:50.601316 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:50.617888 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:39:56.573304 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:39:56.590811 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:39:56.605017 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:00.076760 zma_m1[32637].INF-zm_monitor.cpp/1512 [SODACAM: 7833 - Closing event 36, section end]
2016-09-17 12:40:00.099860 zma_m1[32637].INF-zm_monitor.cpp/1532 [SODACAM: 7833 - Opening new event 37, section start]
2016-09-17 12:40:02.571082 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:02.587210 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:02.599318 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:08.576040 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:08.593576 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:08.605811 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:11.300131 zma_m1[32637].INF-zm_monitor.cpp/1287 [SODACAM: 8000 - Analysing at 10.20 fps]
2016-09-17 12:40:14.575004 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:14.594366 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:14.608453 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:20.567658 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:20.579419 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:20.587939 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:26.568816 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:26.578799 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:26.586918 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:30.819710 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 14 seconds (1474130430-1474130416)]
2016-09-17 12:40:30.917650 zmdc[32261].INF-zmdc.pl ['zmc -m 1' sending stop to pid 483 at 16/09/17 12:40:30]
2016-09-17 12:40:30.924206 zmc_m1[483].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-09-17 12:40:32.569918 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:32.579847 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:32.590331 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:36.924650 zmdc[32261].WAR-zmdc.pl ['zmc -m 1' has not stopped at 16/09/17 12:40:36. Sending KILL to pid 483]
2016-09-17 12:40:36.943360 zmdc[32261].INF-zmdc.pl ['zmc -m 1' crashed, signal 8]
2016-09-17 12:40:38.581896 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:38.601747 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:38.615413 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:44.583304 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:44.604443 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:44.620532 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:46.952810 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 30 seconds (1474130446-1474130416)]
2016-09-17 12:40:47.166600 zmdc[503].INF-zmdc.pl ['zmc -m 1' started at 16/09/17 12:40:47]
2016-09-17 12:40:47.166600 zmdc[32261].INF-zmdc.pl ['zmc -m 1' starting at 16/09/17 12:40:47, pid = 503]
2016-09-17 12:40:47.320272 zmc_m1[503].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-09-17 12:40:48.219960 zmc_m1[504].INF-zm_rtsp.cpp/398 [Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://192.168.8.169/mpeg4/']
2016-09-17 12:40:48.329180 zmc_m1[503].ERR-zm_remote_camera_rtsp.cpp/322 [Error while decoding frame 0]
2016-09-17 12:40:48.334558 zmc_m1[503].ERR-zm_remote_camera_rtsp.cpp/323 [119: 20 c7 35 34 9b 4a 46 6e 52 19 1b 32 0a 41 fb 40 59 4d 80 4c 18 24 36 0a 61 2f d7 95 8f 83 0c 1b 7c eb b6 b9 97 0b d3 09 49 d9 02 9f 04 67 85 c2 e0 50 6a ca 7c 69 00 44 fb f9 05 6a 79 32 8a 87 9f 67 9c 8f 0b 83 a0 38 1c 83 89 82 f2 61 19 a6 a4 2a 06 17 38 5f 98 a0 6d 24 19 47 9a 57 f1 52 a4 05 c4 c3 cf 35 11 72 c2 62 67 a2 1c 90 c4 95 3e 05 13 81 c4 58 8d]
2016-09-17 12:40:50.574527 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:50.587931 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:50.603037 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:40:56.572998 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:40:56.590027 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:40:56.602765 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:02.576089 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:02.594092 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:02.609753 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:08.576342 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:08.592836 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:08.606337 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:14.575877 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:14.593858 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:14.607891 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:20.574684 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:20.593607 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:20.610060 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:26.574973 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:26.592215 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:26.605213 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:32.575242 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:32.596907 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:32.613432 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:38.567785 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:38.578104 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:38.587201 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:44.568400 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:44.579000 web_js[32377].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:44.589426 web_js[32377].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:47.186490 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 14 seconds (1474130507-1474130493)]
2016-09-17 12:41:47.283450 zmdc[32261].INF-zmdc.pl ['zmc -m 1' sending stop to pid 503 at 16/09/17 12:41:47]
2016-09-17 12:41:47.288041 zmc_m1[503].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-09-17 12:41:50.566177 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:50.578206 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:50.595181 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:41:53.288480 zmdc[32261].WAR-zmdc.pl ['zmc -m 1' has not stopped at 16/09/17 12:41:53. Sending KILL to pid 503]
2016-09-17 12:41:53.310240 zmdc[32261].INF-zmdc.pl ['zmc -m 1' crashed, signal 8]
2016-09-17 12:41:56.575289 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:41:56.595393 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:41:56.613004 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:02.576194 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:02.596245 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:02.614804 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:03.321000 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 30 seconds (1474130523-1474130493)]
2016-09-17 12:42:03.530380 zmdc[32261].INF-zmdc.pl ['zmc -m 1' starting at 16/09/17 12:42:03, pid = 521]
2016-09-17 12:42:03.530380 zmdc[521].INF-zmdc.pl ['zmc -m 1' started at 16/09/17 12:42:03]
2016-09-17 12:42:03.706393 zmc_m1[521].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-09-17 12:42:04.614694 zmc_m1[522].INF-zm_rtsp.cpp/398 [Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://192.168.8.169/mpeg4/']
2016-09-17 12:42:04.715514 zmc_m1[521].ERR-zm_remote_camera_rtsp.cpp/322 [Error while decoding frame 0]
2016-09-17 12:42:04.721295 zmc_m1[521].ERR-zm_remote_camera_rtsp.cpp/323 [256: b0 6a c1 99 2b 40 05 00 2b dc 16 07 bd 38 1d 05 1c 16 05 cd 07 3a 7d c0 e8 28 a8 53 1a b9 c1 61 a1 03 07 19 3d ce e1 82 d7 03 69 cf 61 33 4e 07 ae 05 43 b8 70 e2 c0 78 13 78 bb 1a b8 20 04 03 c6 37 85 2f 44 5f a7 bb 88 8f 48 d1 3c d4 69 c8 98 d7 1c 0a 26 56 ce 06 3d 1d 0b 93 fd be fb 83 2c d0 b7 0d 08 cc 08 01 9e 88 c2 90 b9 09 3d 63 98 d9 9a db 67 02 99 1a c7 1a 5e 4a b6 9d 19 12 9a a2 81 1f 1a 6d f0 25 ed e6 62 39 1f 88 39 74 82 83 9b 3c 15 48 17 4e 4b 0c b8 4e 88 2c 0f c5 d3 8c 18 e6 1a 07 43 a2 20 60 5b 9a 12 92 99 8b 1f 11 81 e0 0f 89 f7 41 25 16 39 cc 2d a8 5c c9 91 18 16 0e 31 36 b9 39 3a eb 9b 13 87 02 e4 cd 05 67 44 60 84 00 fd 10 89 e7 72 91 a6 a7 a2 32 3b c1 5a 50 22 03 71 11 f2 0a 2b 4c 12 03 07 4a c8 86 a4 02 30 d4 a2 9d 52 b3 41 79 0a 50 ac 64]
2016-09-17 12:42:08.573312 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:08.596651 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:08.609999 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:14.573269 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:14.589348 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:14.606137 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:20.572026 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:20.591566 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:20.603417 zma_m1[32637].INF-zm_monitor.cpp/1287 [SODACAM: 9000 - Analysing at 7.75 fps]
2016-09-17 12:42:20.605967 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:26.575544 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:26.594000 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:26.607882 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:32.572505 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:32.589645 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:32.601759 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:38.572779 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:38.606103 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:38.619682 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:44.575998 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:44.593818 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:44.607516 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:50.570953 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:50.587469 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:50.600168 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:42:56.566956 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:42:56.581029 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:42:56.592203 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:02.567078 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:02.582132 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:02.591074 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:03.550870 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 14 seconds (1474130583-1474130569)]
2016-09-17 12:43:03.648610 zmdc[32261].INF-zmdc.pl ['zmc -m 1' sending stop to pid 521 at 16/09/17 12:43:03]
2016-09-17 12:43:03.653360 zmc_m1[521].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-09-17 12:43:08.630800 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:08.643882 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:08.652788 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:09.653840 zmdc[32261].WAR-zmdc.pl ['zmc -m 1' has not stopped at 16/09/17 12:43:09. Sending KILL to pid 521]
2016-09-17 12:43:09.666800 zmdc[32261].INF-zmdc.pl ['zmc -m 1' crashed, signal 8]
2016-09-17 12:43:14.575877 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:14.594315 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:14.609809 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:19.678160 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 30 seconds (1474130599-1474130569)]
2016-09-17 12:43:19.933720 zmdc[32261].INF-zmdc.pl ['zmc -m 1' starting at 16/09/17 12:43:19, pid = 540]
2016-09-17 12:43:19.933730 zmdc[540].INF-zmdc.pl ['zmc -m 1' started at 16/09/17 12:43:19]
2016-09-17 12:43:20.114963 zmc_m1[540].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-09-17 12:43:20.575344 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:20.599835 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:20.614797 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:20.996348 zmc_m1[541].INF-zm_rtsp.cpp/398 [Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://192.168.8.169/mpeg4/']
2016-09-17 12:43:26.574124 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:26.592494 web_js[32383].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:26.605190 web_js[32383].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:32.574160 web_php[32383].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:32.634798 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:32.650545 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:38.584224 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:38.602312 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:38.617616 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:44.570649 web_php[32683].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:44.591414 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:44.608064 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:50.572047 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:50.590624 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:50.604586 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:56.570611 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:43:56.587680 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:43:56.601174 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:43:58.456698 zma_m1[32637].INF-zm_monitor.cpp/1287 [SODACAM: 10000 - Analysing at 10.20 fps]
2016-09-17 12:44:02.587093 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:44:02.602278 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:44:02.618237 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:44:08.568392 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:44:08.582386 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:44:08.591038 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:44:14.568251 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:44:14.580173 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:44:14.590197 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:44:19.952440 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 14 seconds (1474130659-1474130645)]
2016-09-17 12:44:20.050210 zmdc[32261].INF-zmdc.pl ['zmc -m 1' sending stop to pid 540 at 16/09/17 12:44:20]
2016-09-17 12:44:20.054900 zmc_m1[540].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2016-09-17 12:44:20.568120 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:44:20.578580 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:44:20.589157 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:44:26.055340 zmdc[32261].WAR-zmdc.pl ['zmc -m 1' has not stopped at 16/09/17 12:44:26. Sending KILL to pid 540]
2016-09-17 12:44:26.075800 zmdc[32261].INF-zmdc.pl ['zmc -m 1' crashed, signal 8]
2016-09-17 12:44:26.568139 web_php[32377].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:44:26.587062 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:44:26.603253 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:44:32.576999 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:44:32.597420 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:44:32.613898 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:44:36.087400 zmwatch[32312].INF-zmwatch.pl [Restarting capture daemon for SODACAM, time since last capture 31 seconds (1474130676-1474130645)]
2016-09-17 12:44:36.266390 zmdc[32261].INF-zmdc.pl ['zmc -m 1' starting at 16/09/17 12:44:36, pid = 570]
2016-09-17 12:44:36.266410 zmdc[570].INF-zmdc.pl ['zmc -m 1' started at 16/09/17 12:44:36]
2016-09-17 12:44:36.348243 zmc_m1[570].INF-zmc.cpp/250 [Starting Capture version 1.30.0]
2016-09-17 12:44:37.309190 zmc_m1[571].INF-zm_rtsp.cpp/398 [Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://192.168.8.169/mpeg4/']
2016-09-17 12:44:38.569928 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:44:38.586071 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:44:38.596424 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
2016-09-17 12:44:44.575113 web_php[32401].ERR-/usr/share/zoneminder/www/includes/functions.php/1993 [socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory]
2016-09-17 12:44:44.597238 web_js[32401].ERR-?view=watch [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-902070s.sock ) failed: No such file or directory - checkStreamForErrors()]
2016-09-17 12:44:44.614867 web_js[32401].ERR-http://192.168.8.211/zm/skins/classic/v ... tch.js/218 [TypeError: streamImg.src is undefined]
Re: No Live Video - fps works - stills work - socket_sendto Errors
Change your source type from Remote/RTSP to ffmpeg.
If that does not resolve it, then we need to see a fresh set of logs using ffmpeg source type (do NOT try to open a live view while collecting this info).
We also need to see your camera configuration, screenshots are preferred.
krig
Post by krig »
Such kind of problem. Ubuntu server 14 - 64bit, zm 1.30, camera Foscam C1-Lite, can't get image, only blue screen. http://89.251.26.174/zm/index.php?view=watch&mid=7.
And also. I have a password for admin and some users, but it didn't affect on online service. How to solve. I knew it's a dum questions but I can't resolve it.
