Sep 23 20:27:03 garagehost zma_m8[4666]: INF [workshop small 50: 502001 - Opening new event 33689, section start]
Sep 23 20:27:03 garagehost zma_m8[4666]: INF [In overload mode, 3 frames of 3 remaining]
Sep 23 20:27:03 garagehost zma_m8[4666]: INF [In overload mode, 2 frames of 3 remaining]
Sep 23 20:27:03 garagehost zma_m8[4666]: INF [In overload mode, 1 frames of 3 remaining]
Sep 23 20:27:04 garagehost zma_m8[4666]: INF [In overload mode, 3 frames of 3 remaining]
Sep 23 20:27:05 garagehost zma_m8[4666]: INF [In overload mode, 2 frames of 3 remaining]
Sep 23 20:27:05 garagehost zma_m8[4666]: INF [In overload mode, 1 frames of 3 remaining]
Sep 23 20:27:05 garagehost zma_m8[4666]: INF [In overload mode, 3 frames of 3 remaining]
Sep 23 20:27:06 garagehost zma_m8[4666]: INF [In overload mode, 2 frames of 3 remaining]
Sep 23 20:27:06 garagehost zma_m8[4666]: INF [In overload mode, 1 frames of 3 remaining]
Sep 23 20:27:06 garagehost zma_m8[4666]: INF [In overload mode, 3 frames of 3 remaining]
Sep 23 20:27:07 garagehost zma_m8[4666]: INF [In overload mode, 1 frames of 3 remaining]
Sep 23 20:27:07 garagehost zma_m8[4666]: INF [workshop small 50: 502017 - Gone into prealarm state]
Sep 23 20:27:21 garagehost zmwatch[3357]: INF [Restarting capture daemon for Ally, time since last capture 12 seconds (1474658841-1474658829)]
Sep 23 20:27:22 garagehost zmdc[2820]: INF ['zmc -m 10' sending stop to pid 16126 at 16/09/23 20:27:22]
Sep 23 20:27:22 garagehost zmc_m10[16126]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:28 garagehost zmdc[2820]: WAR ['zmc -m 10' has not stopped at 16/09/23 20:27:28. Sending KILL to pid 16126]
Sep 23 20:27:28 garagehost zmdc[2820]: INF ['zmc -m 10' exited normally]
Sep 23 20:27:29 garagehost systemd[1]: zoneminder.service: Main process exited, code=exited, status=4/NOPERMISSION
Sep 23 20:27:29 garagehost zmpkg[16130]: INF [Sanity checking States table...]
Sep 23 20:27:29 garagehost zmpkg[16130]: INF [Command: stop]
Sep 23 20:27:29 garagehost sudo[16136]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/bin/true
Sep 23 20:27:29 garagehost sudo[16136]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Sep 23 20:27:29 garagehost sudo[16136]: pam_unix(sudo:session): session closed for user www-data
Sep 23 20:27:29 garagehost sudo[16138]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl check
Sep 23 20:27:29 garagehost sudo[16138]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Sep 23 20:27:29 garagehost sudo[16138]: pam_unix(sudo:session): session closed for user www-data
Sep 23 20:27:30 garagehost systemd[1]: zoneminder.service: Control process exited, code=exited status=1
Sep 23 20:27:30 garagehost zmc_m8[16105]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zmc_m5[4616]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zmc_m7[4471]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zmc_m6[16102]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zma_m5[4620]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zma_m6[15771]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zma_m8[4666]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zma_m10[11836]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zmc_m9[16127]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zma_m9[14444]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zma_m7[4475]: INF [Got signal 15 (Terminated), exiting]
Sep 23 20:27:30 garagehost zma_m8[4666]: INF [workshop small 50: 502184 - Closing event 33689, section end]
Sep 23 20:27:30 garagehost zma_m9[14444]: INF [Ally small 52: 64300 - Closing event 33688, shutting down]
Sep 23 20:27:30 garagehost zma_m7[4475]: INF [office small 51: 514932 - Closing event 33686, shutting down]
Sep 23 20:27:31 garagehost zma_m8[4666]: WAR [Event 33690 has zero time, setting to current]
Sep 23 20:27:31 garagehost zma_m8[4666]: INF [workshop small 50: 502184 - Opening new event 33690, section start]
Sep 23 20:27:31 garagehost zma_m8[4666]: INF [workshop small 50: 502184 - Gone into prealarm state]
Sep 23 20:27:32 garagehost zma_m8[4666]: INF [workshop small 50: 502185 - Closing event 33690, shutting down]
Sep 23 20:27:32 garagehost systemd[1]: zoneminder.service: Unit entered failed state.
Sep 23 20:27:32 garagehost systemd[1]: zoneminder.service: Failed with result 'exit-code'.
DF output
Filesystem 1M-blocks Used Available Use% Mounted on
udev 7870M 0M 7870M 0% /dev
tmpfs 1576M 58M 1519M 4% /run
/dev/sda1 51915M 10003M 39253M 21% /
tmpfs 7880M 1550M 6331M 20% /dev/shm
tmpfs 5M 1M 5M 1% /run/lock
tmpfs 7880M 0M 7880M 0% /sys/fs/cgroup
/dev/sdc1 2816556M 638327M 2035134M 24% /media/denis/storage1
tmpfs 1576M 1M 1576M 1% /run/user/112
tmpfs 1576M 0M 1576M 0% /run/user/1000
total used free shared buff/cache available
Mem: 16136 802 161 1687 15171 13307
Swap: 8376 0 8376
Any help or pointers to troubleshoot this would be appreciated, only started 2 days ago after manually purging the logfile (coincidence?) system has been faultless for about a month now on 1.30.
EDIT: Debian testing on 4.6.0-1-amd64 kernel
