New installation problems
esprit1st
Post by esprit1st »
Hi guys,
I am new to ZM and am having trouble with the cameras. Here some info:
- I am running Ubuntu Desktop 16.04.1 (clean install right before ZM installation)
- ZM V. 1.30.0
- installed using the installation guide from the ZM homepage
- seems fine working
- set up two cameras:
- Panasonic BL-C10A
- GW Secure Model GW-5037IP
I cannot see the camera pictures if I click on the camera names.
Here is an excerpt from the ZM Log:
2016-10-15 12:27:05.657129 zmc_m1 2524 INF Bobs Toys: 20000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:23:45.653192 zmc_m1 2524 INF Bobs Toys: 19000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:22:53.738819 zmc_m2 2525 INF Testing Center: 9000 - Capturing at 1.94 fps zm_monitor.cpp 3116
2016-10-15 12:20:25.663044 zmc_m1 2524 INF Bobs Toys: 18000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:17:46.809507 web_php 2368 ERR socket_sendto( /var/run/zm/zms-289869s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-10-15 12:17:05.647750 zmc_m1 2524 INF Bobs Toys: 17000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:14:17.830319 zmc_m2 2525 INF Testing Center: 8000 - Capturing at 1.94 fps zm_monitor.cpp 3116
2016-10-15 12:13:45.656631 zmc_m1 2524 INF Bobs Toys: 16000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:10:25.623843 zmc_m1 2524 INF Bobs Toys: 15000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:07:05.642553 zmc_m1 2524 INF Bobs Toys: 14000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:05:41.750524 zmc_m2 2525 INF Testing Center: 7000 - Capturing at 2.31 fps zm_monitor.cpp 3116
2016-10-15 12:03:45.630732 zmc_m1 2524 INF Bobs Toys: 13000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:00:25.615083 zmc_m1 2524 INF Bobs Toys: 12000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:58:28.994052 zmc_m2 2525 INF Testing Center: 6000 - Capturing at 2.63 fps zm_monitor.cpp 3116
2016-10-15 11:57:05.611083 zmc_m1 2524 INF Bobs Toys: 11000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:53:45.595914 zmc_m1 2524 INF Bobs Toys: 10000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:52:08.189638 zmc_m2 2525 INF Testing Center: 5000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:50:25.601693 zmc_m1 2524 INF Bobs Toys: 9000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:47:05.580424 zmc_m1 2524 INF Bobs Toys: 8000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:45:47.211130 zmc_m2 2525 INF Testing Center: 4000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:43:45.576438 zmc_m1 2524 INF Bobs Toys: 7000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:40:25.575688 zmc_m1 2524 INF Bobs Toys: 6000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:39:26.337545 zmc_m2 2525 INF Testing Center: 3000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:37:05.559626 zmc_m1 2524 INF Bobs Toys: 5000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:36:35.079049 web_php 2371 ERR socket_sendto( /var/run/zm/zms-277302s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-10-15 11:33:45.546901 zmc_m1 2524 INF Bobs Toys: 4000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:33:05.534613 zmc_m2 2525 INF Testing Center: 2000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:30:25.537060 zmc_m1 2524 INF Bobs Toys: 3000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:27:05.541094 zmc_m1 2524 INF Bobs Toys: 2000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:26:44.866922 zmc_m2 2525 INF Testing Center: 1000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:23:45.535202 zmc_m1 2524 INF Bobs Toys: 1000 - Capturing at 4.95 fps zm_monitor.cpp 3116
2016-10-15 11:20:24.498220 zmdc 2550 INF 'zmtelemetry.pl' started at 16/10/15 11:20:24 zmdc.pl
2016-10-15 11:20:24.498190 zmdc 2490 INF 'zmtelemetry.pl' starting at 16/10/15 11:20:24, pid = 2550 zmdc.pl
2016-10-15 11:20:24.332630 zmdc 2490 INF 'zmupdate.pl -c' starting at 16/10/15 11:20:24, pid = 2546 zmdc.pl
2016-10-15 11:20:24.332630 zmdc 2546 INF 'zmupdate.pl -c' started at 16/10/15 11:20:24 zmdc.pl
2016-10-15 11:20:24.326370 zmwatch 2538 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-10-15 11:20:24.282310 zmwatch 2538 INF Watchdog starting zmwatch.pl
2016-10-15 11:20:24.178050 zmdc 2490 INF 'zmwatch.pl' starting at 16/10/15 11:20:24, pid = 2538 zmdc.pl
2016-10-15 11:20:24.178050 zmdc 2538 INF 'zmwatch.pl' started at 16/10/15 11:20:24 zmdc.pl
2016-10-15 11:20:24.134098 zmc_m1 2524 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-10-15 11:20:24.085220 zmfilter 2526 INF Scanning for events zmfilter.pl
2016-10-15 11:20:24.050612 zmc_m1 2524 INF Priming capture from rtsp://192.168.1.211:554/mpeg4?username=admin&password=A3E17F3B36EED680B815F02976AEE758 zm_ffmpeg_camera.cpp 104
2016-10-15 11:20:24.042910 zmdc 2531 INF 'zmaudit.pl -c' started at 16/10/15 11:20:24 zmdc.pl
2016-10-15 11:20:24.042780 zmdc 2490 INF 'zmaudit.pl -c' starting at 16/10/15 11:20:24, pid = 2531 zmdc.pl
2016-10-15 11:20:23.962538 zmc_m1 2524 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:20:23.943086 zmc_m2 2525 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:20:23.860070 zmdc 2526 INF 'zmfilter.pl' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.860070 zmdc 2490 INF 'zmfilter.pl' starting at 16/10/15 11:20:23, pid = 2526 zmdc.pl
2016-10-15 11:20:23.809700 zmdc 2525 INF 'zmc -m 2' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.809690 zmdc 2490 INF 'zmc -m 2' starting at 16/10/15 11:20:23, pid = 2525 zmdc.pl
2016-10-15 11:20:23.708350 zmdc 2490 INF Starting pending process, zmc -m 2 zmdc.pl
2016-10-15 11:20:23.659250 zmdc 2524 INF 'zmc -m 1' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.659240 zmdc 2490 INF 'zmc -m 1' starting at 16/10/15 11:20:23, pid = 2524 zmdc.pl
2016-10-15 11:20:23.608170 zmdc 2490 INF Starting pending process, zmc -m 1 zmdc.pl
2016-10-15 11:20:23.559560 zmdc 2490 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:20:23.445070 zmdc 2520 INF 'zmc -m 2' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.445070 zmdc 2490 INF 'zmc -m 2' starting at 16/10/15 11:20:23, pid = 2520 zmdc.pl
2016-10-15 11:20:23.332830 zmdc 2490 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:20:23.249210 zmdc 2490 INF 'zmc -m 1' starting at 16/10/15 11:20:23, pid = 2516 zmdc.pl
2016-10-15 11:20:23.249210 zmdc 2516 INF 'zmc -m 1' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.114340 zmpkg 2474 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-10-15 11:20:20.106750 zmdc 2490 INF Server starting at 16/10/15 11:20:20 zmdc.pl
2016-10-15 11:20:19.915080 zmpkg 2474 INF Command: start zmpkg.pl
2016-10-15 11:20:19.872440 zmpkg 2474 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:20:19.717690 zmdc 2190 INF Server shutdown at 16/10/15 11:20:19 zmdc.pl
2016-10-15 11:20:09.586520 zmdc 2190 INF 'zmc -m 1' exited normally zmdc.pl
2016-10-15 11:20:09.546180 zmdc 2190 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-10-15 11:20:09.503090 zmdc 2190 INF 'zmc -m 2' exited normally zmdc.pl
2016-10-15 11:20:09.419530 zmdc 2190 INF 'zmupdate.pl -c' sending stop to pid 2245 at 16/10/15 11:20:09 zmdc.pl
2016-10-15 11:20:09.419489 zmc_m1 2220 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:20:09.377707 zmc_m2 2388 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-10-15 11:20:09.327660 zmdc 2190 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-10-15 11:20:09.285778 zmc_m2 2388 ERR Unable to read content zm_remote_camera_http.cpp 1026
2016-10-15 11:20:09.244130 zmdc 2190 INF 'zmc -m 1' sending stop to pid 2220 at 16/10/15 11:20:09 zmdc.pl
2016-10-15 11:20:09.202337 zmc_m2 2388 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-10-15 11:20:09.160660 zmdc 2190 INF 'zmtelemetry.pl' sending stop to pid 2251 at 16/10/15 11:20:09 zmdc.pl
2016-10-15 11:20:09.160615 zmc_m2 2388 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:20:09.118910 zmdc 2190 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-10-15 11:20:09.077120 zmdc 2190 INF 'zmc -m 2' sending stop to pid 2388 at 16/10/15 11:20:09 zmdc.pl
2016-10-15 11:20:09.035350 zmdc 2190 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-10-15 11:20:08.984750 zmdc 2190 INF 'zmaudit.pl -c' sending stop to pid 2231 at 16/10/15 11:20:08 zmdc.pl
2016-10-15 11:20:08.943000 zmdc 2190 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-10-15 11:20:08.901190 zmdc 2190 INF 'zmfilter.pl' sending stop to pid 2226 at 16/10/15 11:20:08 zmdc.pl
2016-10-15 11:20:08.864300 zmdc 2190 INF 'zmwatch.pl' sending stop to pid 2238 at 16/10/15 11:20:08 zmdc.pl
2016-10-15 11:20:08.659630 zmpkg 2433 INF Command: stop zmpkg.pl
2016-10-15 11:20:08.619320 zmpkg 2433 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:20:08.482580 zmsystemctl 2421 INF Redirecting command through systemctl zmsystemctl.pl
2016-10-15 11:20:08.317690 zmpkg 2415 INF Command: restart zmpkg.pl
2016-10-15 11:20:08.255120 zmpkg 2415 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:19:51.994510 zmdc 2190 WAR Can't find process with command of 'zma -m 2' zmdc.pl
2016-10-15 11:19:51.940652 zmc_m2 2388 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:19:51.814710 zmdc 2388 INF 'zmc -m 2' started at 16/10/15 11:19:51 zmdc.pl
2016-10-15 11:19:51.814710 zmdc 2190 INF 'zmc -m 2' starting at 16/10/15 11:19:51, pid = 2388 zmdc.pl
2016-10-15 11:19:51.697590 zmdc 2190 INF 'zmc -m 2' exited normally zmdc.pl
2016-10-15 11:19:51.643616 zmc_m2 2225 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-10-15 11:19:51.601807 zmc_m2 2225 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-10-15 11:19:51.560070 zmc_m2 2225 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-10-15 11:19:51.518247 zmc_m2 2225 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:19:51.477290 zmdc 2190 INF 'zmc -m 2' sending stop to pid 2225 at 16/10/15 11:19:51 zmdc.pl
2016-10-15 11:19:51.252200 zmdc 2190 WAR Can't find process with command of 'zma -m 2' zmdc.pl
2016-10-15 11:19:26.159371 web_js 1709 ERR TypeError: e[c] is undefined zm/tools/mootools/mootools-more.js 1
2016-10-15 11:18:56.718846 zmc_m1 2220 INF Bobs Toys: 1000 - Capturing at 4.98 fps zm_monitor.cpp 3116
2016-10-15 11:15:35.700230 zmdc 2251 INF 'zmtelemetry.pl' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.700190 zmdc 2190 INF 'zmtelemetry.pl' starting at 16/10/15 11:15:35, pid = 2251 zmdc.pl
2016-10-15 11:15:35.560750 zmwatch 2238 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-10-15 11:15:35.528640 zmdc 2245 INF 'zmupdate.pl -c' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.528630 zmdc 2190 INF 'zmupdate.pl -c' starting at 16/10/15 11:15:35, pid = 2245 zmdc.pl
2016-10-15 11:15:35.519930 zmwatch 2238 INF Watchdog starting zmwatch.pl
2016-10-15 11:15:35.349830 zmdc 2238 INF 'zmwatch.pl' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.349830 zmdc 2190 INF 'zmwatch.pl' starting at 16/10/15 11:15:35, pid = 2238 zmdc.pl
2016-10-15 11:15:35.274490 zmfilter 2226 INF Scanning for events zmfilter.pl
2016-10-15 11:15:35.228690 zmdc 2190 INF 'zmaudit.pl -c' starting at 16/10/15 11:15:35, pid = 2231 zmdc.pl
2016-10-15 11:15:35.228690 zmdc 2231 INF 'zmaudit.pl -c' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.185123 zmc_m1 2220 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-10-15 11:15:35.144802 zmc_m2 2225 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:15:35.101649 zmc_m1 2220 INF Priming capture from rtsp://192.168.1.211:554/mpeg4?username=admin&password=A3E17F3B36EED680B815F02976AEE758 zm_ffmpeg_camera.cpp 104
2016-10-15 11:15:35.060900 zmdc 2190 INF 'zmfilter.pl' starting at 16/10/15 11:15:35, pid = 2226 zmdc.pl
2016-10-15 11:15:35.060900 zmdc 2226 INF 'zmfilter.pl' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.049438 zmc_m1 2220 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:15:35.010860 zmdc 2225 INF 'zmc -m 2' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.010850 zmdc 2190 INF 'zmc -m 2' starting at 16/10/15 11:15:35, pid = 2225 zmdc.pl
2016-10-15 11:15:34.967990 zmdc 2190 INF Starting pending process, zmc -m 2 zmdc.pl
2016-10-15 11:15:34.925810 zmdc 2190 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:15:34.810420 zmdc 2221 INF 'zmc -m 2' started at 16/10/15 11:15:34 zmdc.pl
2016-10-15 11:15:34.810420 zmdc 2190 INF 'zmc -m 2' starting at 16/10/15 11:15:34, pid = 2221 zmdc.pl
2016-10-15 11:15:34.768740 zmdc 2220 INF 'zmc -m 1' started at 16/10/15 11:15:34 zmdc.pl
2016-10-15 11:15:34.768730 zmdc 2190 INF 'zmc -m 1' starting at 16/10/15 11:15:34, pid = 2220 zmdc.pl
2016-10-15 11:15:34.725870 zmdc 2190 INF Starting pending process, zmc -m 1 zmdc.pl
2016-10-15 11:15:34.686000 zmdc 2190 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:15:34.577050 zmdc 2216 INF 'zmc -m 1' started at 16/10/15 11:15:34 zmdc.pl
2016-10-15 11:15:34.576620 zmdc 2190 INF 'zmc -m 1' starting at 16/10/15 11:15:34, pid = 2216 zmdc.pl
2016-10-15 11:15:34.469710 zmpkg 2174 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-10-15 11:15:31.467460 zmdc 2190 INF Server starting at 16/10/15 11:15:31 zmdc.pl
2016-10-15 11:15:31.274140 zmpkg 2174 INF Command: start zmpkg.pl
2016-10-15 11:15:31.232570 zmpkg 2174 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:15:31.044750 zmdc 1219 INF Server shutdown at 16/10/15 11:15:31 zmdc.pl
2016-10-15 11:15:20.849750 zmdc 1219 INF 'zmc -m 2' exited normally zmdc.pl
2016-10-15 11:15:20.762279 zmc_m2 1765 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-10-15 11:15:20.745060 zmdc 1219 INF 'zmc -m 1' exited normally zmdc.pl
2016-10-15 11:15:20.712386 zmc_m2 1765 ERR Unable to read content zm_remote_camera_http.cpp 1026
2016-10-15 11:15:20.670431 zmc_m2 1765 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-10-15 11:15:20.628710 zmc_m2 1765 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:15:20.545250 zmdc 1219 INF 'zmc -m 2' sending stop to pid 1765 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.545225 zmc_m1 1774 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:15:20.486770 zmdc 1219 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.428440 zmdc 1219 INF 'zmc -m 1' sending stop to pid 1774 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.386590 zmdc 1219 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.344890 zmdc 1219 INF 'zmupdate.pl -c' sending stop to pid 1628 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.303060 zmdc 1219 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.261340 zmdc 1219 INF 'zmtelemetry.pl' sending stop to pid 1639 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.219580 zmdc 1219 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.177850 zmdc 1219 INF 'zmwatch.pl' sending stop to pid 1610 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.127730 zmdc 1219 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.077650 zmdc 1219 INF 'zmfilter.pl' sending stop to pid 1584 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.032230 zmdc 1219 INF 'zmaudit.pl -c' sending stop to pid 1597 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:19.811120 zmpkg 2130 INF Command: stop zmpkg.pl
2016-10-15 11:15:19.783400 zmpkg 2130 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:15:19.646610 zmsystemctl 2124 INF Redirecting command through systemctl zmsystemctl.pl
2016-10-15 11:15:19.452430 zmpkg 2116 INF Command: restart zmpkg.pl
2016-10-15 11:15:19.402690 zmpkg 2116 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:12:36.698567 zmc_m1 1774 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-10-15 11:12:36.426404 zmc_m1 1774 INF Priming capture from rtsp://192.168.1.211:554/mpeg4?username=admin&password=A3E17F3B36EED680B815F02976AEE758 zm_ffmpeg_camera.cpp 104
2016-10-15 11:12:36.197167 zmc_m1 1774 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:12:35.821811 zmc_m2 1765 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:12:35.582010 zmdc 1774 INF 'zmc -m 1' started at 16/10/15 11:12:35 zmdc.pl
2016-10-15 11:12:35.581550 zmdc 1219 INF 'zmc -m 1' starting at 16/10/15 11:12:35, pid = 1774 zmdc.pl
2016-10-15 11:12:35.321930 zmdc 1219 INF Starting pending process, zmc -m 1 zmdc.pl
2016-10-15 11:12:35.248310 zmdc 1765 INF 'zmc -m 2' started at 16/10/15 11:12:35 zmdc.pl
2016-10-15 11:12:35.247900 zmdc 1219 INF 'zmc -m 2' starting at 16/10/15 11:12:35, pid = 1765 zmdc.pl
2016-10-15 11:12:35.138350 zmdc 1219 INF Starting pending process, zmc -m 2 zmdc.pl
2016-10-15 11:12:35.022560 zmdc 1219 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:12:34.855700 zmdc 1219 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:12:30.709120 zmdc 1639 INF 'zmtelemetry.pl' started at 16/10/15 11:12:30 zmdc.pl
2016-10-15 11:12:30.705160 zmdc 1219 INF 'zmtelemetry.pl' starting at 16/10/15 11:12:30, pid = 1639 zmdc.pl
2016-10-15 11:12:30.455390 zmwatch 1610 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-10-15 11:12:30.306910 zmfilter 1584 INF Scanning for events zmfilter.pl
2016-10-15 11:12:30.161750 zmdc 1219 INF 'zmupdate.pl -c' starting at 16/10/15 11:12:30, pid = 1628 zmdc.pl
2016-10-15 11:12:30.161750 zmdc 1628 INF 'zmupdate.pl -c' started at 16/10/15 11:12:30 zmdc.pl
2016-10-15 11:12:29.777470 zmwatch 1610 INF Watchdog starting zmwatch.pl
2016-10-15 11:12:29.408380 zmdc 1610 INF 'zmwatch.pl' started at 16/10/15 11:12:29 zmdc.pl
2016-10-15 11:12:29.408370 zmdc 1219 INF 'zmwatch.pl' starting at 16/10/15 11:12:29, pid = 1610 zmdc.pl
2016-10-15 11:12:28.930240 zmdc 1597 INF 'zmaudit.pl -c' started at 16/10/15 11:12:28 zmdc.pl
2016-10-15 11:12:28.930230 zmdc 1219 INF 'zmaudit.pl -c' starting at 16/10/15 11:12:28, pid = 1597 zmdc.pl
2016-10-15 11:12:28.468360 zmdc 1584 INF 'zmfilter.pl' started at 16/10/15 11:12:28 zmdc.pl
2016-10-15 11:12:28.468160 zmdc 1219 INF 'zmfilter.pl' starting at 16/10/15 11:12:28, pid = 1584 zmdc.pl
2016-10-15 11:12:27.966190 zmdc 1572 INF 'zmc -m 2' started at 16/10/15 11:12:27 zmdc.pl
2016-10-15 11:12:27.966180 zmdc 1219 INF 'zmc -m 2' starting at 16/10/15 11:12:27, pid = 1572 zmdc.pl
2016-10-15 11:12:27.507510 zmdc 1524 INF 'zmc -m 1' started at 16/10/15 11:12:27 zmdc.pl
2016-10-15 11:12:27.506660 zmdc 1219 INF 'zmc -m 1' starting at 16/10/15 11:12:27, pid = 1524 zmdc.pl
2016-10-15 11:12:26.988350 zmpkg 1158 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-10-15 11:12:23.986440 zmdc 1219 INF Server starting at 16/10/15 11:12:23 zmdc.pl
2016-10-15 11:12:23.610100 zmpkg 1158 INF Command: start zmpkg.pl
2016-10-15 11:12:23.323660 zmpkg 1158 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:06:46.687330 zmdc 1368 INF Server shutdown at 16/10/15 11:06:46 zmdc.pl
2016-10-15 11:06:36.542900 zmdc 1368 INF 'zmc -m 2' exited normally zmdc.pl
2016-10-15 11:06:36.496911 zmc_m2 1844 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-10-15 11:06:36.455177 zmc_m2 1844 ERR Unable to read content zm_remote_camera_http.cpp 1026
2016-10-15 11:06:36.371673 zmc_m2 1844 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-10-15 11:06:36.341270 zmdc 1368 INF 'zmc -m 1' exited normally zmdc.pl
2016-10-15 11:06:36.321596 zmc_m2 1844 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
Any help would be welcome.
Thank you guys!
esprit
Re: New installation problems
Check the WIKI instructions...
Set your resolution lower. Use vlc to check your stream settings.
esprit1st
Post by esprit1st »
The Panasonic camera has a pretty low resolution. According to the logs, ZM seems to capture the stream, I installed VLC and using the same settings as in ZM I can see the video just fine.
esprit1st
Post by esprit1st »
Any idea what the error
means?
esprit1st
Post by esprit1st »
Ok guys, I found the problem. And I am embarrassed to say that it was the path_zms not set right.
So options/paths/path_zms config entry. :oops:
Gold star to the OP for posting such a wealth of data. It makes zeroing in on the problem much faster.
We get the infamous PATH_ZMS issue reported every week. It is clear that many aren't reading that step in the instructions or didn't follow the instructions at all. It would be helpful to us, if you could tell us how to make that PATH_ZMS instruction stand out more, since so many people run into this problem.
esprit1st
Post by esprit1st »
Well, one thing is to at least change the order of the last step on the readthedocs.io. Make it a "mandatory last step" to check. It says congrats and then after that to check the path_zms ... would be smart to do it the other way round. I need to admit I just stopped reading at the congrats ... ;)
charsi
Post by charsi »
I ran into the same issue.. spent an hour googling and trying different things. And then finally saw this thread.
I reccomend moving the ZMS_PATH check before instead of after the "Congratulations Your installation is complete" bit in the installation instructions. Might help other impatient souls like me. :)
esprit1st
Post by esprit1st »
Yeah, why would you read past congratulation, right? :)
I didn't either.
If you use the instructions in the WIKI you will see:
Open Zoneminder in a web browser (http://server-ip/zm). Click on Options - Paths and change PATH_ZMS to /zm/cgi-bin/nph-zms Click the Save button
in bold!
zmxen
Post by zmxen »
Thank you so much for this head-check. The CGI_PATH is an important detail missing from the setup guide I followed.
The readthedocs version of the Ubuntu Easy Install is missing this last step at this time. http://zoneminder.readthedocs.io/en/sta ... untu-16-04 I hope I can find the right place over on Github to influence getting that changed.
