Timeline not working
agw
Post by agw »
Hi all, have a working zoneminder with 5 cams since some years back. Installed zmNinja app on my iPhone some months ago and I can't get the timeline to work. Live view (montage) is fine but when I press Timeline nothing happens. Tried to run zmNinja on my win10 with the same behaviour.
The log shows **exception** but I can't really understand what to look for.
Nov 4, 2016 10:16 AM INFO multi server list loaded{"servers":[]}
Nov 4, 2016 10:16 AM DEBUG **EXCEPTION**TypeError: Cannot read property 'pageCount' of undefined caused by undefined
Nov 4, 2016 10:16 AM INFO Monitor load was successful, loaded 5 monitors
Nov 4, 2016 10:16 AM DEBUG Now trying to get multi-server data, if present
Nov 4, 2016 10:16 AM DEBUG TimelineCtrl/drawgraph: graphLoaded:false
API works, and I upgraded ZM from 1.29 to 1.30 yesterday with the same result.
Please advise.
BR
/AGW
asker
Re: Timeline not working
Post by asker »
That error almost always means your APIs are broken.
How exactly did you upgrade, which instructions did you follow and which Distro?
Try this:
a) Open a browser, login in
b) Open a tab in the SAME browser, and do a
http://<server>/zm/api/events.json
(replace server and path as needed)
Please post the output (preferably as a gist)
Please read before posting:
ES docs
zmNinja docs
agw
Post by agw »
Ok, http://<server>/zm/api/events.json doesn't work at all, nothing happens.
http://<server>zm/api/host/getVersion.json
Gives me:
"version": "1.30.0",
"apiversion": "1.0"
Same behaviour before and after the upgrade. I stated that API works in my first post but that was based on the output from zm/api/host/getVersion.json
I'm running Ubuntu 14.04.5 LTS (GNU/Linux 3.19.0-25-generic x86_64)
/A
agw
Post by agw »
asker
Post by asker »
I need to see the output of the events API, not just /api
thx
ES docs
zmNinja docs
asker
Post by asker »
I think I know what may be going on.
Edit /usr/share/zoneminder/www/api/app/Config/database.php
and uncomment the 'encoding' => 'utf8' line in the DATABASE_CONFIG for $default
It should look like this:
class DATABASE_CONFIG {
    public $default = array(
        'datasource' => 'Database/Mysql',
        'persistent' => false,
        'login' => ZM_DB_USER,
        'password' => ZM_DB_PASS,
        'database' => ZM_DB_NAME,
        'prefix' => '',
        'encoding' => 'utf8',
Then try the events API again
ES docs
zmNinja docs
agw
Post by agw »
Thanks! Problem solved!
BR
/AGW
