Hi there,
I recently performed a clean install of my home server, I installed Ubuntu Server 16.10 and followed the ZM Ubuntu install guide. Since doing this three of the Tenvis IP cameras that were previously working int 1.28/Debian (for the last two years) now just show a bright blue screen. The two USB cameras and one other IP camera are working fine. I've tried just having one camera running to eliminate a resource issue but still get the same. The shared memory is nice and high so at a loss as to what else to try. The cameras work fine when connecting directly to their web interface.
Any suggestions?
Clean install of 1.3 on Ubuntu resulted in Blue Screen in ZM console
- knight-of-ni
Re: Clean install of 1.3 on Ubuntu resulted in Blue Screen in ZM console
If you want a good answer, we need real, quantitative data.
For starters, tell us:
- model of Tenvis cameras in question
- show us the general and source tabs of your camera config. Screenshots are preferred.
- what does your zoneminder log say? It certainly says something. More is better. A full page of events would be nice.
Check your Options::Path::PATH_ZMS setting. Should be /zm/cgi-bin/nph-zms. Also, blue screen could be an indication of bad resolution of a mistake in the path to the camera.
The Options::Path::PATH_ZMS setting does not need to be changed for Ubuntu 16.10.
You did not say what instructions you followed but you may want to check these:
The blue screen may be caused by incorrect video resolution settings.
