Eminent 6250HD
jajest
Eminent 6250HD
Post by jajest »
hello,
I hope I post this in the right thread...
I have an Eminent EM6250HD IP camera who function well under VLC / iSpy / ...
the MPEG4 stream can be accessed with this: RTSP://192.168.1.14/004218161.password (in VLC for example)
But it seems I do something wrong in zoneminder coz I can't image on the cam.
this is my config:
any ideas ?
PS: I tried already to configure "remote host port " = 554
thanks.
marc
Re: Eminent 6250HD
Use ffmpeg in Zoneminder and get the resolution spot on!
jajest
Re: Eminent 6250HD
Post by jajest »
thanks bbunge! I enabled: OPT_FFMPEG: (Checked) under the IMAGES tab and now I can see the stream.
But what do you mean by "get the resolution spot on!" ?
Re: Eminent 6250HD
Spot on or exactly right. Whatever terms used the resolution you enter in Zoneminder has to match what the camera can deliver!
