Hi everyone,
I moved the events folder from a 1TB to a 4TB.
After moving, ZM still shows disk 9% on the top left corner as it was when on the 1TB.
And I can see that it is actually at 5% when I do "df -h" on the server.
After deleting the whole events folder it dropped at 5% but it shoudl show 1%.
Everything looks OK but I am concerned about if ZM really sees that there is much more space available to record events.
Is there a field somewhere that would have the wrong info about the size of that partition?
Here is how I moved it:
1- I stopped zm
2- I mv /var/cache/zoneminder/events/ /var/cache/zoneminder/events_old/
Which renamed the events folder
3- I added in the /etc/fstab file /dev/sda1 /var/cache/zoneminder/events ext4 defaults 0 0
(The original events folder was on sdb1 (1TB) and now the /var/cache/zoneminder/events folder is mounted on sda1 (4tb) when I boot up the server.
4- I rebooted and stopped ZM again
So when I "df -h" I can see that the folder events is indeed on sda1
5- I cp -a /var/cache/zoneminder/events_old/* /var/cache/zoneminder/events/
Which copied the content of the original events folder to the new one. Everything works fine
6- And finally I rm -rf /var/cache/zoneminder/events_old
Which deleted the original events folder from the 1TB drive.
ZM seems to not see new partion size after moving events
Re: ZM seems to not see new partion size after moving events
I think I know what is happening.
I think that what I am seeing as Disk % is not free space available on my second drive (4td) but the total % of available space on both drives. Which, I think, makes more sense.
What do you guys think?
"the total % of available space on both drives" - that's how I have been interpreting that value on the console, and the math works based on my df output.
