Blue Screen
ov10fac
Blue Screen
Post by ov10fac »
I know this has been pretty much talked to death, but I can't find any definitive answer for my problem. I use a Wansview IP camera model W2. It works fine with any browser and the Wansview app. But all I get from zoneminder is a blue screen. I have tried most of the options but most result in the same blue screen. Sometimes a white screen.
So, here is the configuration.
Souce Type: Ffmpeg I have tried most of the others with no satisfactory result
Source Path: rstp://user:pw@ip:554/mjpeg/snap.cgi?chn=0
Remote Method: RTP/Unicast, I have tried RTP/RTSP and most of the others
I have also tried http://user:pw@ip:80/mjpeg/snap.....
The log just started to give me some errors. Unable to open input rtsp://jwright:passwowrd@192.168.10.68:554/mjpeg/snap.cgi?chn=1 due to: Operation now in progress
I have found some references to this error and have made sure no other computers are accessing the camera. So I'm at a loss.
Any suggestions would be appreciated.
marco123
Re: Blue Screen
Post by marco123 »
ov10fac
Re: Blue Screen
Post by ov10fac »
Thank you. I did that and I was able to get the camera in the browser using that connect string. But it took about 10 seconds to bring the image up. Makes me wonder if maybe it isn't a timing issue?
I changed my source to that string and still get the blue screen.
Here is what I get from the log:
socket_sendto( /var/run/zm/zms-951063s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-12-05 12:07:46.004709 web_js 22623 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-951063s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-12-05 12:07:45.951385 web_php 22623 ERR socket_sendto( /var/run/zm/zms-951063s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-12-05 12:07:43.138482 zms 23364 ERR Terminating, last frame sent time 1480961262.638349 secs more than maximum of 10.000000
Note the last entry, appears to be a timing issue. So where can I change that 10sec to something longer?
