I have searched around the forums for everything I can think of t describe this, but haven't found any relevant threads. I'm sure someone has asked this before or perhaps there is even a guide for this somewhere that I am unaware of.
I switched a few of my cameras to Amcrest IP3M-954E POE IP cameras and I like a lot of the features so far, but my Zoneminder is filling up with video glitches like this:
https://dl.dropboxusercontent.com/u/123 ... -r1-s1.mpg
It seems to happen every few minutes. How can I stop the glitching?
If I can't stop the glitching, how can I make a filter or adjust the settings so these don't generate unwanted Modect Event?
Filtering Unwanted Events & Video Glitches
Re: Filtering Unwanted Events & Video Glitches
Set the max fps in the camera and set the max fps settings in Zoneminder to blank, slowing down the fps might help too.
Thanks!
I limited the cameras' FPS to 20 (40 was default). I already had the values for max FPS blank in Zoneminder.
I'm still getting the glitching. Is there some way to create a filter on a set of zones that will catch this kind of video noise, but leave other events alone? I already set a "preclusive" zone on a small area that shouldn't change frequently, but that doesn't seem to be working the way I thought it would.
Are you using ffmepg or vlc to capture the ip cam images? I recommend you to use ffmpeg, if does not improve, decrease the fps to 10, just to see if a lower value makes the noise dissapear.
I am using Ffmpeg as the Source Type in Zoneminder. I just set the Maximum FPS down to 10 and it looks like the cameras are still glitching.
I noticed that if I open the same stream from my phone in LiveCams Pro, I can watch the same stream that I have pulled up in Zoneminder and the picture never glitches. This makes me think the issue is definitely on the Zoneminder/Ffmpeg side. How can I see if Ffmpeg is being overtaxed and running out of memory?
