NEWBE here
Hi I am pretty new to zoneminder, linux, and all.
I do have some camera, a raspberry pi 3 (with raspberry jessie) and wanted to try Zoneminder.
I followed these instructions
https://wiki.zoneminder.com/Debian_8_64 ... e_Easy_Way
To me it seems that everything went fine (can't be sure about it).
Anyway now when I put this in a chrome browser in the same network as my Pi3
http://192.168.1.239/zm
I receive this error
Not Found
The requested URL /zm was not found on this server.
Apache/2.4.10 (Raspbian) Server at 192.168.1.239 Port 80
Troubleshoot installation
Re: Troubleshoot installation
I have this error, can anyone help?
pi@raspberrypi:~ $ sudo systemctl status zoneminder.service
● zoneminder.service - LSB: Control ZoneMinder as a Service
Loaded: loaded (/etc/init.d/zoneminder)
Active: failed (Result: exit-code) since Sat 2016-12-17 20:21:11 CET; 17s ago
Process: 18180 ExecStart=/etc/init.d/zoneminder start (code=exited, status=2)
Dec 17 20:21:11 raspberrypi zoneminder[18180]: Starting ZoneMinder: Bareword....
Dec 17 20:21:11 raspberrypi zoneminder[18180]: BEGIN not safe after errors--....
Dec 17 20:21:11 raspberrypi zoneminder[18180]: Compilation failed in require....
Dec 17 20:21:11 raspberrypi zoneminder[18180]: BEGIN failed--compilation abo....
Dec 17 20:21:11 raspberrypi zoneminder[18180]: failure
Dec 17 20:21:11 raspberrypi systemd[1]: zoneminder.service: control process ...2
Dec 17 20:21:11 raspberrypi systemd[1]: Failed to start LSB: Control ZoneMin....
Dec 17 20:21:11 raspberrypi systemd[1]: Unit zoneminder.service entered fail....
Hint: Some lines were ellipsized, use -l to show in full.
pi@raspberrypi:~ $
pi@raspberrypi:~ $
