software for android
pystik
Post by pystik »
would prejudice an advice, you know a good software like eyezm I can use my terminal on Android??
marty505
Re: software for android
Post by marty505 »
I'm using IP Camera Viewer Basic v.4.4.3 on an android based smart TV and it works just fine.
Flasheart
Post by Flasheart »
I use the same on an HTC Desire, but take feeds directly from the ip cameras, not via zm.
pystik
Post by pystik »
thank you very much now I just feel
rassi
Post by rassi »
Any one tested to turn Android phone to camera for ZM?
There is at least this app:
http://www.appbrain.com/app/ip-webcam/com.pas.webcam
Will it work with ZM? :)
I do have some spare Android phones and like to use them as network cameras.
rassi
Post by rassi »
Tested at it does work nicely :)
pystik
Post by pystik »
sorry guys i scarivcato the apk but I can not set it, the brand and what should I put in the description? ZoneMinder by chance?
zSeries
Post by zSeries »
I am curios, I have an Android phone and I access the ZM via the standard browser while wi-fi connected to my home network. What will you gain by bypassing ZM? If you want to bypass ZM what are you doing here? :-)
Fabrizio
Post by Fabrizio »
rassi wrote:Tested at it does work nicely :)
Yes, I tried it also successfully. IP Webcam even supports to switch on and off the camera LED of the phone via the web interface. Maybe I try to make a small control script for ZoneMinder so you can switch on the light from there directly.
Would work nicely to e.g. read out meters for water and power without having to go downstairs with pen and paper. :-)
CrisTooR
Post by CrisTooR »
Has this script been written?
