Another Socket error
epicfatigue
Post by epicfatigue »
Hey Guys,
So i am having a little issue.
I am not getting any streaming from the web GUI.
I had a look at
https://zoneminder.readthedocs.io/en/st ... -streaming
I am running on FREENAS 9.10
And i am using NGINX not Apache like the GitHub suggested .
Since i am running NGINX the guide doesnt really apply.
Should i switch to Apache?
Any Pointers or Direction would be awesome thanks guys
user www;
worker_processes 1;
#error_log logs/error.log;
#error_log logs/error.log notice;
#error_log logs/error.log info;
pid /var/run/nginx.pid;
events {
worker_connections 1024; ## Default: 1024
http {
include mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local]
"$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
server_tokens off;
gzip on;
gzip_comp_level 4;
gzip_min_length 1100;
Stopping mysql.
Waiting for PIDS: 1427.
Starting mysql.
Performing sanity check on nginx configuration:
nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Starting nginx.
gzip_buffers 64 8k;
gzip_http_version 1.1;
gzip_proxied any;
gzip_types text/plain application/xml application/x-javascript
text/css;
server {
root /usr/local/www/zoneminder;
try_files $uri $uri/ /index.php$is_args$args;
index index.php;
location = /cgi-bin/nph-zms {
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME
$document_root$fastcgi_script_name;
fastcgi_pass unix:/var/run/fcgiwrap/fcgiwrap.sock;
location ~ \.php$ {
fastcgi_pass unix:/var/run/php-fpm.sock;
location /api {
rewrite ^/api/(.+)$ /api/index.php?p=$1 last;
epicfatigue
Re: Another Socket error
Any Ideas Guys ?
I see the socket being created in the directory it is looking for? however it can not seem to bind to it....
Do not know of any folks running Zoneminder on a NAS package. You might have better luck getting an answer if you ran a regular Linux distro. Sorry...
the /cgi-bin needs to be configured in NGINX similar to setting up ZM on a Hiawatha server. alias the cgi-bin to match your path PATH_ZMS and that the cgi-bin is reachable. In Hiawatha there is a config to specify what to do with files with no extension so they run as CGI which is the case with ZMS and NPH-ZMS. Simply put you need to tell NGINX where the streaming components are in the cgi-bin and have the correct permissions.
I think..........
epicfatigue
Thanks for the Help Guys,
Sadily none of those worked.
However i did manage to solve it.
It was a NGINX config error as suggested.
My Server block needed to be configured this way.
server {
index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
