Can't insert event - 1.30.10
Matt84
Re: Can't insert event - 1.30.10
Post by Matt84 »
quian wrote:Hi
Matt84 did you manage to get your video stream to show yet on 1.30.11?
Quian
No, i haven't, I built a new virtual machine for the time being (1.29.0)
Next weekend i will investigate more. going to do a clean install and see if i get the same issue.
Regards
Matt84
quian
Post by quian »
I have a big install I am keen to use storage areas on as it makes life easier when wanting to add extra hard drives. I'm currently using 1.30 from iconner ppa.
Will let you know if I find anything
Regards Quian
Eradicator
Post by Eradicator »
Hi all!
I had same problem. To eliminate this problem i stopped zoneminder, flush all events, etc.. and install last (1.13.12) update. Now events are successfully saved.
quian
Re: Can't insert event - 1.30.10r
Post by quian »
Nice work Mr IC :D
Thanks for this...
1) I created a virtual machine to test (Ubuntu 16.04.1 lts) installed master ppa 1.30.1 and then upgraded to latest storage areas ppa 1.30.12
No problems at all.
2) I then set up path_zms to the usual /zm/cgi-bin/nph-zms
3) logged into <myipadress>/zm
4) Added 2x IP cams and setup up recording... all ok
5) Created 2 new dirs /1 for camera1 and /2 for camera2 (chown and chmod)
6) Edited cams and change storage... all ok
2 small things i did pickup so far. Screens shots of the logs below
1) My console did not show properly at first... I noticed i could see the bandwidth setting in dark so i clicked on it and changed it to high and then back
to low. Then the whole console showed.
2) Also when I add storage paths and click save I get an error or maybe its not.
Otherwise so far all looks good... Will keep you posted
Q :D
Matt84
Post by Matt84 »
quian wrote:Hi
Quian
I have upgrade my system this morning to (1.30.12-xenial-2017012301) ..
and live view is now working correctly. i also rebooted my system, first time in months!
