Zoneminder stopped after upgrade to 1.30
gnocera
Re: Zoneminder stopped after upgrade to 1.30
Post by gnocera »
Hello
Please refer to the initial post by AndresCT46 » Tue Aug 09, 2016 12:01 pm
Probably you will find the right log.
The URL that you point it corresponds to a camera that was down at that moment, nothing more. Actually there are almost 140 cameras working on 2 servers with the url you mentioned.
"I also recommend using monit to ensure that it starts back up if it does stop."
Please can you be more specific about this? What do you mean with "monit". Don't know if I understood, but did you mean we have a way to starts zoneminder again when it goes stop?
Regards,
GNC
gnocera
Post by gnocera »
Please refer to Post by AndresCT46 » Tue Aug 09, 2016 12:01 pm
You will probably find there the log you are looking for.
Don't worry about url, it was a camera down at that moment. In fact we have almost 140 working with this stream with ffmpeg.
I am not sure I am understanding what are you trying to say with "monit".
Did you have a way to zoneminder automatically restarts when it goes to stop ? Because right now we have to manually restart again in the monitor (web console)
Thanks,
GNC
SteveGilvarry
Post by SteveGilvarry »
The original log posted is just zms errors, and maybe 20 mins. You should be looking for zmc errors, or just post full logs across the time it fails.
Monit is a third party app that you could use to monitor the service and restart it. https://www.digitalocean.com/community/ ... gure-monit, or google "monit restart service"
SteveGilvarry
iconnor,
Didn't we fix unable to decode frame to be an error and move on? Saw this in one of the later log posts.
2016-08-26 02:43:09.821490 zmc_m42 19303 FAT Unable to decode frame at frame 302711 zm_ffmpeg_camera.cpp 178
gnocera
Post by gnocera »
SteveGilvarry wrote:The original log posted is just zms errors, and maybe 20 mins. You should be looking for zmc errors, or just post full logs across the time it fails.
________________________________________________________
Thank you for the -monit- suggestion. To be honest we didn't knew this application. Many thanks, this will help.
We have adjusted yesterday some parameters on the server, and also increased the RAM memory on each. It was below the limit showed in mysqltunner.
Now if the error happens again we will send the complete log (btw it is huge log).
Regards,
GNC
SteveGilvarry
On the contact page on zoneminder.com there is an option to discuss paid support, that isn't me, but some of the team who consult commercially. But since you are a larger install you may have some budget to get direct assistance, not assuming anything, but just giving you the option.
gnocera
Post by gnocera »
Thank you Steve,
Yes. As soon as we can fix the production environment, it may be possible to get a budget to support.
Regards,
GNC
