8CH DVR PCI CX23880
nokia001
8CH DVR PCI CX23880
Post by nokia001 »
i updated my Server last week. Now i have a problem.
My 8CH DVR Card with Philips Semiconductors SAA7130 works greate.
But the 8ch DVR Card " Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder" won't work.
DMESG:
[ 4117.988376] cx88[0]: subsystem: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected], frontend(s): 0
[ 4118.171537] cx88[0]/0: found at 0000:05:00.0, rev: 5, irq: 18, latency: 32, mmio: 0xfa000000
[ 4118.171645] cx88[0]/0: registered device video8 [v4l2]
[ 4118.171873] cx88[0]/0: registered device vbi8
[ 4118.171993] cx88[1]: subsystem: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected], frontend(s): 0
[ 4118.354935] cx88[1]/0: found at 0000:05:01.0, rev: 5, irq: 19, latency: 32, mmio: 0xf8000000
[ 4118.355047] cx88[1]/0: registered device video9 [v4l2]
[ 4118.355064] cx88[1]/0: registered device vbi9
[ 4118.355193] cx88[2]: subsystem: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected], frontend(s): 0
[ 4118.538966] cx88[2]/0: found at 0000:05:02.0, rev: 5, irq: 16, latency: 32, mmio: 0xf6000000
[ 4118.539063] cx88[2]/0: registered device video10 [v4l2]
[ 4118.539084] cx88[2]/0: registered device vbi10
[ 4118.539204] cx88[3]: subsystem: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected], frontend(s): 0
[ 4118.722981] cx88[3]/0: found at 0000:05:03.0, rev: 5, irq: 17, latency: 32, mmio: 0xf4000000
[ 4118.723082] cx88[3]/0: registered device video11 [v4l2]
[ 4118.723099] cx88[3]/0: registered device vbi11
[ 4118.723221] cx88[4]: subsystem: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected], frontend(s): 0
[ 4118.907253] cx88[4]/0: found at 0000:05:04.0, rev: 5, irq: 18, latency: 32, mmio: 0xf2000000
[ 4118.907361] cx88[4]/0: registered device video12 [v4l2]
[ 4118.907378] cx88[4]/0: registered device vbi12
[ 4118.907569] cx88[5]: subsystem: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected], frontend(s): 0
[ 4119.103394] cx88[5]/0: found at 0000:05:05.0, rev: 5, irq: 19, latency: 32, mmio: 0xf0000000
[ 4119.103501] cx88[5]/0: registered device video13 [v4l2]
[ 4119.103728] cx88[5]/0: registered device vbi13
[ 4119.104205] cx88[6]: subsystem: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected], frontend(s): 0
[ 4119.291077] cx88[6]/0: found at 0000:05:06.0, rev: 5, irq: 16, latency: 32, mmio: 0xee000000
[ 4119.291182] cx88[6]/0: registered device video14 [v4l2]
[ 4119.291199] cx88[6]/0: registered device vbi14
[ 4119.291321] cx88[7]: subsystem: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected], frontend(s): 0
[ 4119.475053] cx88[7]/0: found at 0000:05:07.0, rev: 5, irq: 17, latency: 32, mmio: 0xec000000
[ 4119.475154] cx88[7]/0: registered device video15 [v4l2]
[ 4119.475171] cx88[7]/0: registered device vbi15
Zoneminder syslog:
 zmdc[6223]: INF [Starting pending process, zmc -d /dev/video14]
Feb 12 18:01:24 Videoserver zmdc[6223]: INF ['zmc -d /dev/video14' starting at 17/02/12 18:01:24, pid = 6383]
Feb 12 18:01:24 Videoserver zmdc[6383]: INF ['zmc -d /dev/video14' started at 17/02/12 18:01:24]
Feb 12 18:01:24 Videoserver zmc_dvideo14[6383]: INF [Starting Capture version 1.30.0]
Feb 12 18:01:24 Videoserver zmc_dvideo14[6383]: FAT [Failed to set video standard 256: Device or resource busy]
Feb 12 18:01:24 Videoserver zmdc[6223]: ERR ['zmc -d /dev/video14' exited abnormally, exit status 255]
Zoneminder settings:
DevicePath: /dev/video14
DeviceChannel: 0,1,2 (all tested)
Device Format: PAL
Capture Palette: YUYV
Width: 640
Height: 480
With ZM 1.25 and Kernel Gentoo 3.0.6 all worked.
Now 1.30 and Kernel Gentoo 4.9.6 only the SAA7130 worked.
Please help.
Thx
Re: 8CH DVR PCI CX23880
It is likely the newer Linux kernel does not support the old cards. Not Zoneminder's fault.
yeah nothing has really changed with zm in terms of local capture cards. It is more likely the kernel's fault. Should be fixable though.
PaoloV
Post by PaoloV »
I got the same board: c180:c980, board: Shenzhen Tungsten Ages Tech TE-DTV-250 / Swann OEM [card=55,autodetected]
Did you solved?
