Has anyone seen this:
http://www.securityfocus.com/bid/96120/info
Any thing end users can do to mitigate?
ZM Vulnerability
Re: ZM Vulnerability
This is bad. More info: http://seclists.org/bugtraq/2017/Feb/6
My router reported this site as malicious.alabamatoy wrote:This is bad. More info: http://seclists.org/bugtraq/2017/Feb/6
More harmful than Zoneminder, at least.
bb
Looks like this has been fixed in 1.30.2. At least my test machine will not let me browse http://ipaddr/zm/events
Here is a "fix" to block the directory browsing. I must admit it is partly my fault..
For Ubuntu
Undo my "Fix to allow API to work" (back to the original configuration)
nano /etc/apache2/apache2.conf
Change All to None in two places as shown below
<Directory /usr/share>
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/>
AllowOverride None
Require all granted
</Directory>
Ctrl+o Enter to save
CTRL+x to exit
Edit zoneminder.conf
Add a - before Indexes and a + before FollowSymLinks
Make sure the following is at the bottom of the file
AllowOverride All
</Directory>
CTRL+x to exit
Restart Apache
service apache2 reload
http://ip-addr/zm/events should now give you a Forbidden 403 error
For Ubuntu
AllowOverride None
Require all granted
</Directory>
AllowOverride None
Require all granted
</Directory>
CTRL+x to exit
AllowOverride All
</Directory>
CTRL+x to exit
Restart Apache
Same is valid for 1.29 as I posted here -> viewtopic.php?f=34&t=25784
Yes, I know. The fix will be the same. Just did not have the time to do all that yesterday.alexo wrote:Same is valid for 1.29 as I posted here -> viewtopic.php?f=34&t=25784
Seclists is only bad because it lists things like router vulnerabilities, that your router manufacturer probably doesn't want you to see.bbunge wrote:
bb
