KKMoon SD27W Setup
wjcunning
KKMoon SD27W Setup
Post by wjcunning »
Here are the basics to get video stream on ZM.
Hint: DO NOT remove the wiring harness from the camera for any reason ( I wanted to make a smaller hole in my wall). BAD IDEA. The connectors are made of tissue paper and the wires are 30 AWG, and fracture when pulled. I ended up rebuilding the whole wiring harness from scratch.
Enjoy!
Source Type: Remote
Analysis FPS: 30
Maximum FPS: 30
Alarm Max FPS: 30
Remote Protocol: RTSP
Remote Method: RTP/Unicast
Remote host name: xxx.xxx.xxx.xxx(cameraIP)
Remote Host Port: 554
Remote Host Path: xxx.xxx.xxx.xxx (cameraIP)/user=yourusername&password=yourpassword/trackID=0
Target Colorspace: 24 bit color
Capture Width: 1920
Capture Height: 1080
Wild Bill
Re: KKMoon SD27W Setup
Same answer as the Foscam question
wjcunning
Post by wjcunning »
Works great with the numbers I posted. Leaving as is. Wish the wiring harness connectors were higher quality. Nice camera. Plays well with ZM.
wesconne2
Post by wesconne2 »
How do I get another wiring harness for the SD27W? Or do I need to make my own?
