FFMPEG IP Camera Buggy Snapshots
I'm getting a weird problem on many of my IP cameras at random times. Can anyone give me an idea of what could cause the problem with the attached image?
- zm-problem-1.jpg (59.93 KiB) Viewed 10780 times
Re: FFMPEG IP Camera Buggy Snapshots
I'm sure it will, I wasn't aware it was called smearing. Thank you.
So I've been playing with this and it seems changing the colorspace from 32bit to 24 bit has made them much more stable. Now I'm seeing glitches on the screen that are not as severe, is this also called smearing?
- 2017-03-08 14_27_30.jpg (204.33 KiB) Viewed 10766 times
That is more like an artefact maybe caused by some missing data in the stream. Try the setting below if not already.
Smearing becomes a bigger issue with high res cameras running in UDP mode, it fills the buffers and image just finishes on the last row of pixels it got and it's like someone smeared the image down the page. For me swapping to Remote Method in the ffmpeg monitor to RTP/RTSP seemed to have the best results, you will see references to putting ?tcp in the url, this setting does that in the FFmpeg API.
Yeah I'm still having a lot of problems with the system. I have the cameras set to run on TCP, but you can see my settings below. I have also attached a few screenshots.
- Settings
- 2017-03-17 10_13_55.jpg (34.92 KiB) Viewed 10682 times
- Unknown cause?
- 2017-03-17 10_13_20.jpg (76.73 KiB) Viewed 10682 times
- MOCORD - All events are smears/artifacts.
- 2017-03-17 10_13_10.jpg (11.66 KiB) Viewed 10682 times
I'm running 2.6.4, I'll try updating now.
3.2.4 is now installed, I'm cleaning the events and I'll update within the next few days. I appreciate your input.
Well I let it run over the weekend, it doesn't have seemed to have helped. 423 events and 419 events on the 2 active cameras.
- 2017-03-20 10_03_47.jpg (32.2 KiB) Viewed 10650 times
Tuxxin,
From your screenshot Remote Method = RTP/Unicast is still UDP. Change that to RTP/RTSP.
Thank you, I have updated them to RTP/RTSP and cleared the events again.
I have similar issue: only happens on some cheap cams; some cams never have the trouble; some cams aways do.
Cams that have the bug usually have 60% or 70% top image fine; and bottom is garbage. For these cams, the image is always perfect when I view the cam via it's internal website: the defect is not in the CCD; and my browser can correctly decode the stream, when accessed directly.
Debian stretch
ffmpeg 3.2.4-1 is giving much better than 3.2.2 ...
Debian stretch
DoubleHP - same problem here, noted in another thread related to Reolink cameras. The stream is also fine via VLC while the smearing occurs in ZoneMinder.
The fix for me has been to change all my source types to Remote. I have yet to see smearing with it (vs ffmpeg).
jt
jt
For me, using RTP-RTSP is much better than Unicast.
Johny, not sure what you call remote.
DoubleHP wrote:
Debian stretch
Confirmed. I looked through the changes but could not really find anything that accounts for the better performance but they are working hard!
https://git.videolan.org/?p=ffmpeg.git; ... ags/n3.2.4
