I`v bough chinesee CAMERA IP info form ONIVF Device Manager:
Locatin: country/china
Manufacturer: H264
Model: 53H20L_S39
Firmware: V4.02.R11.00002532.10010.240100..ONVIF 2.4
and through ONIVF Device Manager and VLC - there is no problem with striming
adress:rtsp://192.168.XX.XX:554/user=XXX_password=XXXX_channel=1_stream=0.sdp?real_stream
but I cant figure out how to set this "piece of art" in ZoneMinder
Remote RSTP - dont work
Libvls - dont work
FfMpeg - dont work
Do you have any idea ? how to set this ?
LOG:
ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
FAT Unable to create libvlc instance due to: (null)
Regards
Jack
chinesee CAMERA IP
Re: chinesee CAMERA IP
Bought something similar, so I'll follow this post.
One tip: On the ebay-page I bought mine, it was a review stating:
"It works in ZoneMinder
To make this camera working in zoneminder you need to use model preset.
Choose "Foscam FI8908W" and enter correct source path."
But no luck for me
But no luck for me
Got the camera videofeed to show in VLC.
rtsp://192.168.0.xxx/user=admin&password=mypassword&channel=1&stream=1.sdp
But not any feed on zm. I also used the height/with that VLC reports.
Anyone got theese xmeye cameras to work in ZM?
