Help! My Debian Unstable and Axis 206 dont seem to work.
you grabing via jpeg or mjpeg, ie whats the path your using~?
James Wilson
strange i had issues with jpeg grab on a 206m.
I use 206's on many sites with great success. Try using jpeg grabs and see if that helps
James Wilson
ah
good luck lol
good luck lol
James Wilson
just had a thought you arnt trying to throttle the fps in zm on a mjpeg feed are you, ie your throttling the cam?
James Wilson
thats your problem then
set it to 12 on the cam, or use jpg stream
James Wilson
ok matey
James Wilson
you mean on the cam?
if so add
user:pass@123.123.123.123
to the host once you have set a pass etc on the cam
if so add
James Wilson
