I forgot the HAppy New Year 2008!
I installed this .deb via apt and have it running successfully.
I did the extras from the wiki as needed.
http://www.zoneminder.com/wiki/index.ph ... rom_a_.deb
chmod 4755 /usr/bin/zmfix
In the settings/system I enabled
ZM_OPT_USE_AUTH
and changed
ZM_AUTH_RELAY
to "none"
This fixes the problem outlined here
http://www.zoneminder.com/forums/viewto ... mauthrelay
I found it necessary to manually enable all the cameras for the admin user. Is that the normal behavior, or do I have something else misconfigured?
hardware:
Intel DG965WHMR motherboard
Core2duo E6600
2 GB ram (4 slot board for upgrade possibility)
PV-183 16 port capture card
2x500GB seagate SATA in software RAID1
(11) Sony SSC-M183 B&W cameras
320x240 greyscale
alarm at 10fps
Load is at 0.40
8400 events so far in 21 hours, at a busy nursing facility!
Thank you all for your efforts. Paypal is on the way
