Make error
So in summary what have we got?
I am running Zoneminder on a CentOS5 Sytem
With the CentOS (2.6.18-53.1.14.el5) kernel
And ZoneMinder-1.23.3
I have no idea what version of ffmpeg I am running but it's the latest ffmpeg svn checkout. As of this date. (See date of post).
And I can't seem to compile Zoneminder.
I have a lot of conflicting information.
Has anyone got a similar setup?
Coz I really need some help!
Do you know what thew names of the files are. The seem to be a lot of files in /usr/lib (This is where they are on my system) /usr/lib/ and /usr/bin/
I am not sure what files to remove. And don't want to remove any files that are relevant to other applications or the system, other than files related to ffmpeg. Can you help me?
I really appreciate your help. But I am a little confused in what your suggesting. Are you saying that when I run ./configure for ffmpeg I should append the ./configure with --prefix=/usr, like so:
./configure --prefix=/usr
And when I run ./configure for Zoneminder I should run it appended with --with-ffmpeg=/usr, like so:
./configure --with-ffmpeg=/usr
It would be wise to do a "make uninstall" first so that you don't have any extra files laying around, then a "make clean" to make sure that you get a good clean build.
You can then reinstall:
./configure --with-webdir=/var/www/zm --with-cgidir=/var/www/cgl-bin -with-webuser=apache --with-webgroup=apache --with-ffmpeg=/usr ZM_DB_PASS=WhatEverPasswordYouWantHere
make
setup your database
make install
make
setup your database
make install
I ran a make uninstall and it seemed to hang at the below point. I had to do a <Ctrl> C, to get my cursor back.
rm -f '/var/www/html/zm/zm_lang_nl_nl.php'
rm -f '/var/www/html/zm/zm_lang_it_it.php'
rm -f '/var/www/html/zm/zm_lang_es_ar.php'
rm -f '/var/www/html/zm/zm_lang_pt_br.php'
rm -f '/var/www/html/zm/zm_lang_dk_dk.php'
rm -f '/var/www/html/zm/zm_lang_cs_cz.php'
make uninstall-hook
make[3]: Entering directory `/root/ZoneMinder-1.22.3/web'
make uninstall-hook
Here's what I ran:
./configure --with-ffmpeg=/usr ZM_DB_PASS=zmpass --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-mysql=/usr --with-libarch=lib --with-pcre=/usr/include ZM_SSL_LIB=openssl
This seemed to go fine.
Then make
This did not go so fine.
make
make all-recursive
make[1]: Entering directory `/root/ZoneMinder-1.23.3'
Making all in src
make[2]: Entering directory `/root/ZoneMinder-1.23.3/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_stream.h:27,
from zm_event.h:36,
from zm_zone.h:27,
from zm_monitor.h:27,
from zmc.cpp:27:
zm_mpeg.h:29:29: error: ffmpeg/avformat.h: No such file or directory
zm_mpeg.h:31:28: error: ffmpeg/swscale.h: No such file or directory
zm_mpeg.h:63: error: use of enum âPixelFormatâ without previous declaration
zm_mpeg.h:64: error: ISO C++ forbids declaration of âAVOutputFormatâ with no type
zm_mpeg.h:64: error: expected â;â before â*â token
zm_mpeg.h:65: error: ISO C++ forbids declaration of âAVFormatContextâ with no type
zm_mpeg.h:65: error: expected â;â before â*â token
zm_mpeg.h:66: error: ISO C++ forbids declaration of âAVStreamâ with no type
zm_mpeg.h:66: error: expected â;â before â*â token
zm_mpeg.h:67: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_mpeg.h:67: error: expected â;â before â*â token
zm_mpeg.h:68: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_mpeg.h:68: error: expected â;â before â*â token
zm_mpeg.h:69: error: ISO C++ forbids declaration of âuint8_tâ with no type
zm_mpeg.h:69: error: expected â;â before â*â token
zm_mpeg.h:85: error: âuint8_tâ has not been declared
make[2]: *** [zmc.o] Error 1
make[2]: Leaving directory `/root/ZoneMinder-1.23.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/ZoneMinder-1.23.3'
make: *** [all] Error 2
Then make
make
make all-recursive
Making all in src
from zm_event.h:36,
from zm_zone.h:27,
from zmc.cpp:27:
Is this the lastest ffmpeg from svn?
What SVN version is it?
It would seem that they have changed the location of the header files
If this is the latest ffmpeg, you will need to cange the code in ZM to reflect the new location and let us know what version of ffmpeg you have so we can track it down and make it work in ZM.
The file you would need to change is zm_mpeg.h
http://www.zoneminder.com/wiki/index.ph ... tes#ffmpeg
I tried to post the canges here but the sanitation of the forum botchs the post so the above link will have the changes needed listed.
FFmpeg version SVN-r13065, Copyright (c) 2000-2008 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-swscale --prefix=/usr
libavutil version: 49.6.0
libavcodec version: 51.56.0
libavformat version: 52.13.0
libavdevice version: 52.0.0
built on May 10 2008 10:46:39, gcc: 4.1.2 20070626 (Red Hat 4.1.2-14)
