help Configure zm with AIC250W
cordel
Post by cordel »
Then your settings in zm should be:
Host: 197.0.0.4
Port: 9393
Path: video.cgi
Width: 320
Height: 240
You might have to set HTTP 1.1 in ZM in Options Under the Network tab.
rickygm
Post by rickygm »
ufff, doesn't still connect, it excuses to send you these images to your email without requesting your authorization, but I believe that it is better than you look at it to that explains to it
send the email to your hotmail account
cordel
Post by cordel »
Pictures of the console do me no good, most it tells me is that it is not working and nothing more.
Check your logs and see what they discribe.
Also you have port 9293 configured, I thought you were using 9393, sorry.
rickygm
Post by rickygm »
my log
xserver zmc_m1[15439]: ERR [Select timed out]
Jan 23 16:57:18 xserver zmc_m1[15439]: ERR [Unable to get response]
Jan 23 16:57:18 xserver zmc_m1[15439]: ERR [Failed to post-capture monitor 0]
Jan 23 16:57:18 xserver zmdc[15225]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jan 23 16:57:18 xserver zmdc[15225]: INF [Starting pending process, zmc -m 1]
Jan 23 16:57:18 xserver zmdc[15225]: INF ['zmc -m 1' starting at 08/01/23 16:57:18, pid = 15448]
Jan 23 16:57:18 xserver zmdc[15448]: INF ['zmc -m 1' started at 08/01/23 16:57:18]
Jan 23 16:57:18 xserver zmc_m1[15448]: INF [Debug Level = 0, Debug Log = <none>]
Jan 23 16:57:19 xserver zmc_m1[15448]: INF [Starting Capture]
I am using the port 9293, and it works well, but zm doesn't present anything...
