FreeBSD port for 1.23.3
IPC and jail are a rather peculiar combination.
be sure to set
security.jail.sysvipc_allowed to 1
(however, "officially" the above is not recommended, security wise).
In FreeBSD IPC and jails are a long unsolved problem (which has affected
the use of PostgreSQL under jails), and is inherent due to the fact that jails
were rather a security concept than a full blown virtual machine.
Having said that, it is amazing how much things jails can do compared
to chroot. Their only limitation, from my point of view is IPC.
be sure to set
achix wrote:IPC and jail are a rather peculiar combination.
be sure to set
Yeah jails have a few silly limitations.
This explains why my tinkering with kern.ip* sysctl's was not able to solve the "unknown shared memory id" issue, I'll post more tomorrow along with the results from your new make file. Thanks.
When using the new Makefile, I get this
"Makefile", line 69: Need an operator
"Makefile", line 70: Need an operator
"Makefile", line 71: Need an operator
"Makefile", line 75: Missing dependency operator
"Makefile", line 76: Missing dependency operator
"Makefile", line 77: Missing dependency operator
"Makefile", line 78: Missing dependency operator
"Makefile", line 79: Missing dependency operator
"Makefile", line 80: Missing dependency operator
"Makefile", line 81: Missing dependency operator
"Makefile", line 82: Missing dependency operator
"Makefile", line 83: Missing dependency operator
"Makefile", line 84: Missing dependency operator
"Makefile", line 86: Need an operator
make: fatal errors encountered -- cannot continue
now I can't seem to make it compile with the old make file on a new system.
uname
Installed ports
Compile error:
uname
6.3-RELEASE FreeBSD 6.3-RELEASE #0: Wed Jan 16 04:18:52 UTC 2008 root@dessler.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC i386
zoneminder# pkg_info
apache-1.3.41 The extremely popular Apache http server. Very fast, very c
autoconf-2.61_2 Automatically configure source code on many Un*x platforms
autoconf-wrapper-20071109 Wrapper script for GNU autoconf
automake-1.5_4,1 GNU Standards-compliant Makefile generator (1.5)
automake-wrapper-20071109 Wrapper script for GNU automake
djbfft-0.76_2 An extremely fast library for floating-point convolution
expat-2.0.1 XML 1.0 parser written in C
faad2-2.6.1,1 MPEG-2 and MPEG-4 AAC audio decoder
ffmpeg-2008.07.27_1 Hyper fast realtime audio/video encoder/converter, streamin
gettext-0.17_1 GNU gettext package
gmake-3.81_3 GNU version of 'make' utility
gnutls-2.4.1 GNU Transport Layer Security library
gpac-libgpac-0.4.4,1 Gpac MPEG-4 Systems library and headers
help2man-1.36.4_2 Automatically generating simple manual pages from program o
jbigkit-1.6 Lossless compression for bi-level images such as scanned pa
jpeg-6b_4 IJG's jpeg compression utilities
liba52-0.7.4_2 A free library for decoding ATSC A/52 streams, aka AC-3
libexecinfo-1.1_1 A library for inspecting program's backtrace
libgcrypt-1.4.1_1 General purpose crypto library based on code used in GnuPG
libgpg-error-1.6_1 Common error values for all GnuPG components
libiconv-1.11_1 A character set conversion library
libogg-1.1.3,4 Ogg bitstream library
libtheora-1.0.b2 Theora video codec for the Ogg multimedia streaming system
libtool-1.5.26 Generic shared library support script
libvorbis-1.2.0_2,3 Audio compression codec library
libxml2-2.6.32 XML parser library for GNOME
m4-1.4.11,1 GNU m4
mysql-client-5.0.51a Multithreaded SQL database (client)
mysql-server-5.0.51a Multithreaded SQL database (server)
netpbm-10.26.55 A toolkit for conversion of images between different format
p5-Archive-Tar-1.38_1 Perl module for creation and manipulation of tar files
p5-Archive-Zip-1.23 Perl module to create, manipulate, read, and write Zip arch
p5-Authen-SASL-2.12 Perl5 module for SASL authentication
p5-Compress-Raw-Zlib-2.012 Low-Level Interface to zlib compression library
p5-Compress-Zlib-2.012 Perl5 interface to zlib compression library
p5-Convert-BinHex-1.119 Perl module to extract data from Macintosh BinHex files
p5-DBD-mysql50-4.006 MySQL 5.0 driver for the Perl5 Database Interface (DBI)
p5-DBI-1.60.4 The perl5 Database Interface. Required for DBD::* modules
p5-Date-Manip-5.44 Perl5 module containing date manipulation routines
p5-Digest-1.15 Modules that calculate message digests
p5-Digest-HMAC-1.01 Perl5 interface to HMAC Message-Digest Algorithms
p5-Digest-MD5-2.36 Perl5 interface to the MD5 algorithm
p5-Digest-SHA1-2.11 Perl interface to the SHA-1 Algorithm
p5-Email-Date-Format-1.002 Produce RFC 2822 date strings
p5-File-Temp-0.20 Perl5 module to generate temporary files or directories saf
p5-File-Which-0.05 Portable implementation of `which' in Perl
p5-HTML-Parser-3.56_1 Perl5 module for parsing HTML documents
p5-HTML-Tagset-3.20 Some useful data table in parsing HTML
p5-IO-Compress-Base-2.012 Base Class for IO::Uncompress modules
p5-IO-Compress-Zlib-2.012 Perl5 interface for reading and writing of (g)zip files
p5-IO-String-1.08 Simplified Perl5 module to handle I/O on in-core strings
p5-IO-Zlib-1.09 IO:: style interface to Compress::Zlib
p5-IO-stringy-2.110 Perl5 module for using IO handles with non-file objects
p5-MIME-Base64-3.07 Perl5 module for Base64 and Quoted-Printable encodings
p5-MIME-Lite-3.02.1 A simple interface for creating (not parsing!) MIME message
p5-MIME-Tools-5.427,2 A set of perl5 modules for MIME
p5-MIME-Types-1.24 Perl extension for determining MIME types
p5-Mail-Tools-2.02 Perl5 modules for dealing with Internet e-mail messages
p5-Net-1.22,1 Perl5 modules to access and use network protocols
p5-PHP-Serialization-0.27 Converting the output of PHP serialize() into the Perl
p5-PathTools-3.2701 A Perl module for portably manipulating file specifications
p5-Storable-2.18 Persistency for perl data structures
p5-URI-1.37 Perl5 interface to Uniform Resource Identifier (URI) refere
p5-gettext-1.05_2 Message handling functions
p5-libwww-5.805 Perl5 library for WWW access
pcre-7.7 Perl Compatible Regular Expressions library
perl-5.8.8_1 Practical Extraction and Report Language
php5-5.2.6 PHP Scripting Language
pkg-config-0.23_1 A utility to retrieve information about installed libraries
png-1.2.28 Library for manipulating PNG images
screen-4.0.3_5 A multi-screen window manager
texi2html-1.76_1,1 Texinfo to HTML converter
tiff-3.8.2_1 Tools and library routines for working with TIFF images
x264-0.0.20080409_2 Multimedia library and tool for encoding H.264/AVC video st
yasm-0.7.1_1 A complete rewrite of the NASM assembler
zoneminder#
zoneminder# make
===> Building for zoneminder-1.23.3,1
/bin/cp /usr/ports/multimedia/zoneminder/files/videodev.h /usr/ports/multimedia/zoneminder/work/ZoneMinder-1.23.3/src
/bin/cp /usr/ports/multimedia/zoneminder/files/zm_fbsd_camera.cpp /usr/ports/multimedia/zoneminder/work/ZoneMinder-1.23.3/src
/bin/cp /usr/ports/multimedia/zoneminder/files/zm_fbsd_camera.h /usr/ports/multimedia/zoneminder/work/ZoneMinder-1.23.3/src
make all-recursive
Making all in src
cd .. && /bin/sh ./config.status src/zm_config.h
config.status: creating src/zm_config.h
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from jinclude.h:20,
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_monitor.h:26,
from zmc.cpp:27:
/usr/local/include/jconfig.h:12:1: warning: "HAVE_STDLIB_H" redefined
In file included from zm_config.h:20,
from zm.h:28,
from zmc.cpp:24:
../config.h:74:1: warning: this is the location of the previous definition
In file included from /usr/local/include/ffmpeg/avformat.h:40,
from zm_mpeg.h:29,
from zm_stream.h:27,
from zm_event.h:36,
from zm_zone.h:27,
from zm_monitor.h:27,
from zmc.cpp:27:
/usr/local/include/libavcodec/avcodec.h:2353: warning: `ImgReSampleContext' is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:2347)
/usr/local/include/libavcodec/avcodec.h:2363: warning: `ImgReSampleContext' is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:2347)
mv -f .deps/zmc.Tpo .deps/zmc.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm.o -MD -MP -MF .deps/zm.Tpo -c -o zm.o zm.cpp
mv -f .deps/zm.Tpo .deps/zm.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_db.o -MD -MP -MF .deps/zm_db.Tpo -c -o zm_db.o zm_db.cpp
mv -f .deps/zm_db.Tpo .deps/zm_db.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_config.o -MD -MP -MF .deps/zm_config.Tpo -c -o zm_config.o zm_config.cpp
mv -f .deps/zm_config.Tpo .deps/zm_config.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_coord.o -MD -MP -MF .deps/zm_coord.Tpo -c -o zm_coord.o zm_coord.cpp
mv -f .deps/zm_coord.Tpo .deps/zm_coord.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_box.o -MD -MP -MF .deps/zm_box.Tpo -c -o zm_box.o zm_box.cpp
mv -f .deps/zm_box.Tpo .deps/zm_box.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_poly.o -MD -MP -MF .deps/zm_poly.Tpo -c -o zm_poly.o zm_poly.cpp
mv -f .deps/zm_poly.Tpo .deps/zm_poly.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_image.o -MD -MP -MF .deps/zm_image.Tpo -c -o zm_image.o zm_image.cpp
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_image.cpp:21:
from zm.h:28,
from zm_image.cpp:19:
zm_image.cpp: In member function `bool Image::ReadRaw(const char*)':
zm_image.cpp:273: warning: long int format, different type arg (arg 3)
mv -f .deps/zm_image.Tpo .deps/zm_image.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_stream.o -MD -MP -MF .deps/zm_stream.Tpo -c -o zm_stream.o zm_stream.cpp
from zm_mpeg.h:29,
from zm_stream.cpp:23:
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_stream.cpp:24:
from zm.h:28,
from zm_stream.cpp:22:
mv -f .deps/zm_stream.Tpo .deps/zm_stream.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_event.o -MD -MP -MF .deps/zm_event.Tpo -c -o zm_event.o zm_event.cpp
from zm_mpeg.h:29,
from zm_event.cpp:32:
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_event.h:35,
from zm_event.cpp:34:
from zm.h:28,
from zm_event.cpp:30:
zm_event.cpp: In constructor `Event::Event(Monitor*, timeval, const char*, const char*)':
zm_event.cpp:58: error: invalid conversion from `long int*' to `const time_t*'
zm_event.cpp:58: error: initializing argument 1 of `tm* localtime(const time_t*)'
zm_event.cpp: In destructor `Event::~Event()':
zm_event.cpp:168: error: invalid conversion from `long int*' to `const time_t*'
zm_event.cpp:168: error: initializing argument 1 of `tm* localtime(const time_t*)'
zm_event.cpp: In member function `bool EventStream::loadInitialEventData_t(int, time_t)':
zm_event.cpp:474: warning: long int format, time_t arg (arg 5)
zm_event.cpp: In member function `virtual void EventStream::processCommand(const StreamBase::CmdMsg*)':
zm_event.cpp:897: warning: long int format, time_t arg (arg 4)
*** Error code 1
Stop in /usr/ports/multimedia/zoneminder/work/ZoneMinder-1.23.3/src.
*** Error code 1
Stop in /usr/ports/multimedia/zoneminder/work/ZoneMinder-1.23.3.
*** Error code 1
*** Error code 1
Stop in /usr/ports/multimedia/zoneminder.
zoneminder#
6.3 amd64 seems to fail now also.
uname
Installed ports
Compile error:
uname
6.3-RELEASE FreeBSD 6.3-RELEASE #0: Wed Jan 16 01:31:10 UTC 2008 root@palmer.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC amd64
zoneminder64# pkg_info
m4-1.4.11,1 GNU m4
zoneminder64#
zoneminder64# make
make all-recursive
Making all in src
from zm_jpeg.h:22,
from zm_image.h:33,
from zmc.cpp:27:
from zm.h:28,
from zmc.cpp:24:
from zm_mpeg.h:29,
from zm_event.h:36,
from zm_zone.h:27,
from zmc.cpp:27:
from zm_jpeg.h:22,
from zm_image.h:33,
from zm.h:28,
from zm_mpeg.h:29,
from zm_jpeg.h:22,
from zm_image.h:33,
from zm.h:28,
from zm_mpeg.h:29,
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_event.h:35,
from zm.h:28,
zm_event.cpp: In member function `bool Event::SendFrameImage(const Image*, bool)':
zm_event.cpp:298: warning: int format, different type arg (arg 2)
zm_event.cpp:298: warning: int format, different type arg (arg 3)
mv -f .deps/zm_event.Tpo .deps/zm_event.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_zone.o -MD -MP -MF .deps/zm_zone.Tpo -c -o zm_zone.o zm_zone.cpp
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_zone.h:26,
from zm_zone.cpp:22:
from zm.h:28,
from zm_zone.cpp:20:
from zm_mpeg.h:29,
from zm_event.h:36,
from zm_zone.h:27,
mv -f .deps/zm_zone.Tpo .deps/zm_zone.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_camera.o -MD -MP -MF .deps/zm_camera.Tpo -c -o zm_camera.o zm_camera.cpp
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_camera.h:27,
from zm_camera.cpp:21:
from zm.h:28,
from zm_camera.cpp:20:
mv -f .deps/zm_camera.Tpo .deps/zm_camera.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_fbsd_camera.o -MD -MP -MF .deps/zm_fbsd_camera.Tpo -c -o zm_fbsd_camera.o zm_fbsd_camera.cpp
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_local_camera.h:26,
from zm_fbsd_camera.cpp:33:
from zm.h:28,
from zm_fbsd_camera.cpp:32:
mv -f .deps/zm_fbsd_camera.Tpo .deps/zm_fbsd_camera.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_remote_camera.o -MD -MP -MF .deps/zm_remote_camera.Tpo -c -o zm_remote_camera.o zm_remote_camera.cpp
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_remote_camera.h:25,
from zm_remote_camera.cpp:39:
from zm.h:28,
from zm_remote_camera.cpp:38:
mv -f .deps/zm_remote_camera.Tpo .deps/zm_remote_camera.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_file_camera.o -MD -MP -MF .deps/zm_file_camera.Tpo -c -o zm_file_camera.o zm_file_camera.cpp
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_file_camera.h:23,
from zm_file_camera.cpp:35:
from zm.h:28,
from zm_file_camera.cpp:34:
mv -f .deps/zm_file_camera.Tpo .deps/zm_file_camera.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_monitor.o -MD -MP -MF .deps/zm_monitor.Tpo -c -o zm_monitor.o zm_monitor.cpp
from zm_mpeg.h:29,
from zm_monitor.cpp:26:
from zm_jpeg.h:22,
from zm_image.h:33,
from zm_monitor.cpp:28:
from zm.h:28,
from zm_monitor.cpp:24:
mv -f .deps/zm_monitor.Tpo .deps/zm_monitor.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_user.o -MD -MP -MF .deps/zm_user.Tpo -c -o zm_user.o zm_user.cpp
mv -f .deps/zm_user.Tpo .deps/zm_user.Po
c++ -DHAVE_CONFIG_H -I. -I.. -I/usr/local/include -I/usr/local/include -Wall -Wno-sign-compare -I/usr/local/include -I/usr/local/include/ -MT zm_mpeg.o -MD -MP -MF .deps/zm_mpeg.Tpo -c -o zm_mpeg.o zm_mpeg.cpp
from zm_mpeg.h:29,
from zm_mpeg.cpp:24:
zm_mpeg.cpp: In destructor `VideoStream::~VideoStream()':
zm_mpeg.cpp:281: error: cannot convert `ByteIOContext**' to `ByteIOContext*' for argument `1' to `int url_fclose(ByteIOContext*)'
zm_mpeg.cpp: In member function `double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)':
zm_mpeg.cpp:325: warning: `img_convert' is deprecated (declared at /usr/local/include/libavcodec/avcodec.h:2515)
*** Error code 1
*** Error code 1
*** Error code 1
*** Error code 1
zoneminder64#
ffmpeg-2008.07.27_1 and zoneminder
I installed zoneminder 1.23.3 today, after last update of ffmpeg.
FreeBSD cs 7.0-STABLE FreeBSD 7.0-STABLE #7: Fri Jul 11 17:21:05 EEST 2008
FFmpeg version SVN-r14424, Copyright (c) 2000-2008 Fabrice Bellard, et al.
configuration: --cc=cc --prefix=/usr/local --enable-swscale --disable-debug --enable-memalign-hack --enable-shared --enable-postproc --extra-cflags=-I/usr/local/include/vorbis -I/usr/local/include --extra-ldflags=-L/usr/local/lib -la52 --extra-libs=-pthread --enable-gpl --enable-pthreads --mandir=/usr/local/man --enable-liba52 --enable-liba52bin --enable-libfaac --enable-libfaad --enable-libfaadbin --disable-libamr-nb --disable-libamr-wb --disable-mmx --enable-libgsm --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid
libavutil version: 49.7.0
libavcodec version: 51.61.0
libavformat version: 52.18.0
libavdevice version: 52.0.0
built on Jul 30 2008 19:43:33, gcc: 4.2.1 20070719 [FreeBSD]
FFmpeg SVN-r14424
libavutil 3213056
libavcodec 3357952
libavformat 3412480
libavdevice 3407872
Successful compilation require to build ffmpeg with --enable-swscale. Remove files/patch_zm_mpeg.cpp and apply this path:
I hope it's useful for you.
FFmpeg SVN-r14424
libavutil 3213056
libavcodec 3357952
libavformat 3412480
libavdevice 3407872
-- /usr/ports/multimedia/ffmpeg/Makefile.orig 2008-07-30 19:52:43.000000000 +0300
+++ /usr/ports/multimedia/ffmpeg/Makefile 2008-07-30 19:39:10.000000000 +0300
@@ -59,11 +59,13 @@
libavutil/random.h \
libavutil/rational.h \
libavutil/sha1.h \
+ libswscale/swscale.h \
libpostproc/postprocess.h
.include <bsd>
CONFIGURE_ARGS+=--cc="${CC}" --prefix="${PREFIX}" \
+ --enable-swscale \
--disable-debug \
--enable-memalign-hack \
--enable-shared \
In the case of 6.3 the following changes must be made:
Whenever the compiler complaints about smth like:
then the following change must be made:zm_monitor.cpp:2218: error: invalid conversion from `const long int*' to `const time_t*'
zm_monitor.cpp:2218: error: initializing argument 1 of `tm* localtime(const time_t*)'
strftime( label_time_text, sizeof(label_time_text), label_format, localtime( (time_t *)&ts_time->tv_sec ) );
The differences in the two systems is that
in 6.3 (most probably not so correctly) struct timeval resolves to
i believe if someone defines -D__arm__ in the compilation of the programs which have
the above error, will solve the problem without altering the code.
Or one could make a new patch in the place of the old the patch for src/Makefile.in adding -D__arm__ to the DEFS variable.
That should get the compilation going.
This a harmless hack, i believe.
while in 7.0struct timeval {
long tv_sec;
suseconds_t tv_usec;
time_t is defined as int in both systems (i386 always).struct timeval {
time_t tv_sec; /* seconds */
suseconds_t tv_usec; /* and microseconds */
Floating point exception ...
hi
I have installed Your port on my freeBSD7 and it looks work, but I have an another problem with using it.
After new monitor configuration I try to use monitor and I'm getting following error in /var/log/messages:
zms[975]: ERR [Got signal (Floating point exception:
, crashing]
I'm using IVC-200G cards (Conexant FusionTM 878A x 4)
(http://www.voxtechnologies.com/Industri ... vc200g.htm)
dmesg show my cards properly:
pci2: <PCI bus> on pcib2
bktr0: <BrookTree 878> mem 0xdf000000-0xdf000fff irq 5 at device 4.0 on pci2
bktr0: [GIANT-LOCKED]
bktr0: [ITHREAD]
bktr0: Warning - card vendor 0x0000 (model 0xa155) unknown.
bktr0: Pinnacle/Miro TV, <no> tuner.
I've no idea what to do. Please help
Regards
mch
bktr0: [ITHREAD]
Regards
mch
