Video Setting -> Streaming Method (RTP over UDP)
Video Setting -> Encoder Type (MPEG4)
Make sure the default ports are enabled:
RTSP Port: 7070
Video Control Port: 6001
You will be better off at 640x480 @ 30FPS for now. You can test with higher resolutions but I don't believe Phil had access to megapixel cameras and the difference in frame rate may throw off the way Zoneminder is expecting to receive the data.
Obviously the 6600 PTZ functions will not work. However the API from ACTi spells out the functions (simple web requests) to control zoom / focus / pan / tilt....so you could hack together a script from the other PTZ scripts
jameso wrote:Glad I could keep people in in the loop.richw wrote:Thanks jameso for posting that.
Shame I'm stuck trying to do a openRTSP/ffmpeg/vpipe/vloopback solution!
I've not got any ACTi camera's yet and I don't have ZM setup but I'm intrested. To help me shortcut a lot of reading, any change you could direct me to info on running these camera's with the "openRTSP/ffmpeg/vpipe/vloopback solution".
