I'm assuming you all haven't over looked the obvious error and it's solution in the FAQ?Cartsy wrote: Dec 4 00:06:42 cath-laptop zmc_dvideo1[9260]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Ubuntu 8.10, ZM 1.23.3-3 and no image --Now Bad image
Re: Ubuntu 8.10, ZM 1.23.3-3 and no image --Now Bad image
spcaxx driver works for such type of web cams but the packege from the developer's site also not installed and gives some error message # 2 during make.liviab wrote:I thinks that it is everything ok with the modules. The camera works fine with others programs.
i think this is the last way out. i purchased the A4Tech ZC0305 WebCam while thinking that linux supports the driver but alas ------------------------
Also hav a look at the article
http://jelkimantis.blogspot.com/2009/01 ... ebcam.html
Regards,
Hi, I'm joining you with the same problem Ubuntu 8.10, webcam Genius, but found as pac207 (Pixart). I've just posted in the other thread in more detail: http://www.zoneminder.com/forums/viewtopic.php?p=50251.
too me have the same problem
they are my log
Mar 13 17:51:15 lbfedora10 kernel: usb 2-1: new full speed USB device using uhci_hcd and address 5
Mar 13 17:51:15 lbfedora10 kernel: usb 2-1: configuration #1 chosen from 1 choice
Mar 13 17:51:15 lbfedora10 kernel: gspca: probing 046d:092f
Mar 13 17:51:16 lbfedora10 kernel: gspca: probe ok
Mar 13 17:51:16 lbfedora10 kernel: usb 2-1: New USB device found, idVendor=046d, idProduct=092f
Mar 13 17:51:16 lbfedora10 kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Mar 13 17:51:16 lbfedora10 kernel: usb 2-1: Product: Camera
Mar 13 17:51:16 lbfedora10 kernel: usb 2-1: Manufacturer:
Mar 13 17:51:20 lbfedora10 avahi-daemon[2501]: Received response with invalid source port 1175 on interface 'eth0.0'
Mar 13 17:51:44 lbfedora10 zmpkg[10919]: INF [Command: start]
Mar 13 17:51:45 lbfedora10 zmdc[10933]: INF [Server starting at 09/03/13 17:51:45]
Mar 13 17:51:48 lbfedora10 zmdc[10956]: INF ['zmc -d /dev/video0' started at 09/03/13 17:51:48]
Mar 13 17:51:48 lbfedora10 zmc_dvideo0[10956]: INF [Debug Level = 0, Debug Log = <none>]
Mar 13 17:51:48 lbfedora10 zmdc[10933]: INF ['zmc -d /dev/video0' starting at 09/03/13 17:51:48, pid = 10956]
Mar 13 17:51:48 lbfedora10 zmc_dvideo0[10956]: INF [Starting Capture]
Mar 13 17:51:49 lbfedora10 zmc_dvideo0[10956]: ERR [Sync failure for frame 1 buffer 2(1): Invalid argument]
Mar 13 17:51:49 lbfedora10 zmc_dvideo0[10956]: ERR [Failed to post-capture monitor 0]
Mar 13 17:51:49 lbfedora10 zmdc[10933]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Mar 13 17:51:49 lbfedora10 zmdc[10933]: INF [Starting pending process, zmc -d /dev/video0]
Mar 13 17:51:49 lbfedora10 zmdc[10964]: INF ['zmc -d /dev/video0' started at 09/03/13 17:51:49]
Mar 13 17:51:49 lbfedora10 zmdc[10933]: INF ['zmc -d /dev/video0' starting at 09/03/13 17:51:49, pid = 10964]
Mar 13 17:51:49 lbfedora10 zmc_dvideo0[10964]: INF [Debug Level = 0, Debug Log = <none>]
Mar 13 17:51:49 lbfedora10 zmc_dvideo0[10964]: INF [Starting Capture]
Mar 13 17:51:49 lbfedora10 zmdc[10971]: INF ['zmfilter.pl' started at 09/03/13 17:51:49]
Mar 13 17:51:49 lbfedora10 zmdc[10933]: INF ['zmfilter.pl' starting at 09/03/13 17:51:49, pid = 10971]
Mar 13 17:51:49 lbfedora10 zmc_dvideo0[10964]: ERR [Sync failure for frame 1 buffer 2(1): Invalid argument]
Mar 13 17:51:49 lbfedora10 zmc_dvideo0[10964]: ERR [Failed to post-capture monitor 0]
Mar 13 17:51:49 lbfedora10 zmdc[10978]: INF ['zmaudit.pl -c' started at 09/03/13 17:51:49]
Mar 13 17:51:49 lbfedora10 zmdc[10933]: INF ['zmaudit.pl -c' starting at 09/03/13 17:51:49, pid = 10978]
Mar 13 17:51:50 lbfedora10 zmfilter[10971]: INF [Scanning for events]
Mar 13 17:51:50 lbfedora10 zmdc[10987]: INF ['zmwatch.pl' started at 09/03/13 17:51:50]
Mar 13 17:51:50 lbfedora10 zmdc[10933]: INF ['zmwatch.pl' starting at 09/03/13 17:51:50, pid = 10987]
Mar 13 17:51:51 lbfedora10 zmwatch[10987]: INF [Watchdog starting]
Mar 13 17:51:51 lbfedora10 zmwatch[10987]: INF [Watchdog pausing for 30 seconds]
Mar 13 17:51:51 lbfedora10 zmdc[10992]: INF ['zmupdate.pl -c' started at 09/03/13 17:51:51]
Mar 13 17:51:51 lbfedora10 zmdc[10933]: INF ['zmupdate.pl -c' starting at 09/03/13 17:51:51, pid = 10992]
Mar 13 17:51:51 lbfedora10 zmupdate[10992]: INF [Checking for updates]
Mar 13 17:51:54 lbfedora10 zmdc[10933]: INF [Starting pending process, zmc -d /dev/video0]
Mar 13 17:51:54 lbfedora10 zmdc[10933]: INF ['zmc -d /dev/video0' starting at 09/03/13 17:51:54, pid = 10996]
Mar 13 17:51:54 lbfedora10 zmdc[10996]: INF ['zmc -d /dev/video0' started at 09/03/13 17:51:54]
Mar 13 17:51:54 lbfedora10 zmc_dvideo0[10996]: INF [Debug Level = 0, Debug Log = <none>]
Mar 13 17:51:54 lbfedora10 zmc_dvideo0[10996]: INF [Starting Capture]
Mar 13 17:51:54 lbfedora10 zmc_dvideo0[10996]: ERR [Sync failure for frame 1 buffer 2(1): Invalid argument]
Mar 13 17:51:54 lbfedora10 zmc_dvideo0[10996]: ERR [Failed to post-capture monitor 0]
Mar 13 17:51:54 lbfedora10 zmdc[10933]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Mar 13 17:51:58 lbfedora10 zmupdate[10992]: INF [Got version: '1.23.3']
Mar 13 17:52:04 lbfedora10 zmdc[10933]: INF [Starting pending process, zmc -d /dev/video0]
Mar 13 17:52:04 lbfedora10 zmdc[11013]: INF ['zmc -d /dev/video0' started at 09/03/13 17:52:04]
Mar 13 17:52:04 lbfedora10 zmc_dvideo0[11013]: INF [Debug Level = 0, Debug Log = <none>]
Mar 13 17:52:04 lbfedora10 zmdc[10933]: INF ['zmc -d /dev/video0' starting at 09/03/13 17:52:04, pid = 11013]
Mar 13 17:52:04 lbfedora10 zmc_dvideo0[11013]: INF [Starting Capture]
Mar 13 17:52:04 lbfedora10 zmc_dvideo0[11013]: ERR [Sync failure for frame 1 buffer 2(1): Invalid argument]
Mar 13 17:52:04 lbfedora10 zmc_dvideo0[11013]: ERR [Failed to post-capture monitor 0]
Mar 13 17:52:04 lbfedora10 zmdc[10933]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
an other problem:
[root@lbfedora10 ~]# zmc -d /dev/video0
Abortito
[root@lbfedora10 ~]# sudo zmc -d /dev/video0
i have search in many forum the same problem but not have a solve problem
Bye
they are my log
an other problem:
Abortito
Bye
